Original design files posted
A project log for TS350 True Sine Inverter
350 Watt inverter that converts 12VDC to 120VAC @ 60Hz.
brian-cornellBrian Cornell 07/10/2018 at 16:500 Comments
These are for the original design and include source code & PCB.  Helpful if you're following along or a starting point for your own derivative.
Will post revisions when available.
