Moving on
A project log for TS350 True Sine Inverter
350 Watt inverter that converts 12VDC to 120VAC @ 60Hz.
brian-cornellBrian Cornell 03/30/2019 at 18:520 Comments
This project has served me well and I've probably taken it as far as it can go in it's current form.  I've hacked it countless times modifying the firmware, testing thermal management, different output filter configurations, etc.
I'm hoping it's work will live on in a redesign.  Boards are at the fab and once assembled I'll start posting under a new project.
