BUILDING/WIRING THE BRIDGE RECTIFIER
A project log for Battery Charging Through Shoes
A Project About Power Generation With The Movement Of Steps.
wasim-sahuWasim Sahu 07/16/2018 at 06:590 Comments
BUILDING THE BRIDGE RECTIFIER:
Ok, so for those of you who do not know how to read a circuit diagram, those 4 line segments with arrows on them represent diodes. The arrows always point to the side of the diode that is marked, also known as the positive side. If you have small, rectangular diodes like me, the positive sides are not marked by coloration, but rather small, engraved lines/notches. By following this diagram, you should be able to create the bridge diode.
WIRING THE BRIDGE RECTIFIER:
