PCB coil joule thief
Experimental PCB single layer transformer - proof of concept
Starting from
has orders / reviews
Ships from
This year is Year of PCB coils ;-) 2x 29turns 6/6mil I know that it is not effective, stupid, expensive, unpractical but it is great education tool :)
PCB coil joule thief  is certified as open source hardware by the Open Source Hardware Association.
Some boards from first batch are for sale on TINDIE PCB coil joule thief
Mini version is here square-inch-pcb-coil-joule-thief
JouleThief-PCBCOIL.sch
sch - 409.15 kB - 07/13/2018 at 21:58
Download
JouleThief-PCBCOIL.brd
brd - 99.88 kB - 07/13/2018 at 21:58
Download
  • 1 × BC546B Discrete Semiconductors / Transistors, MOSFETs, FETs, IGBTs
  • 1 × LED - White Fiber Optics / Emitters
  • 1 × Magic PCB with coil transfomer
  • 1 × Side switch
  • 1 × Battery holder
View all 6 components
View all 7 project logs
  • 1
    PCB
    Order magic PCB with coil, Eagle boards files are included.
    All other components you can found in your drawer :)
  • 2
    Assembly
    Solder components, Transistor, Resistor, LED, Switch and battery holder, no more components required.
    No wires for transformer coils:), there is all on PCB :)
  • 3
    Battery
    Insert battery to holder, minimum battery voltage is 0.5V
View all 4 instructions
BillSF9c wrote 08/10/2018 at 18:45 point
Yes, but for edu purposes, think, a 1.5cm ring, die led flashing 1x/sec, small button battery... or, it flashes faster uf your hand is near emf. LED should be green, of course. 😉
Odie wrote 08/01/2018 at 05:35 point
Hi. The new design looks much better than the old one. I'm in a hurry to make a clone . So, do you have a plan to upload the new layout file?
Sulivvan wrote 07/20/2018 at 15:26 point
Can you post the calculations for the coil, about a year ago i was making joule thiefs and i couldn't get the right calculations for the coil so i just made it by trial and error
K.C. Lee wrote 07/20/2018 at 15:45 point
Eagle CAD has a calculator inside for flat coil. Tools/Calculate Print Inductance
 I hit the menu by accident yesterday.  Also http://www.circuits.dk/calculator_planar_coil_inductor.htm
Sulivvan wrote 07/22/2018 at 10:12 point
Lol i didnt notice , i will try it thank you!
bobricius wrote 07/20/2018 at 19:56 point
no calculation, I just draw biggest possible coil on 5x5cm board :)
Sulivvan wrote 07/22/2018 at 10:13 point
Dam i wonder if it works on a smaller size
bobricius wrote 07/23/2018 at 09:01 point
I think yes, maybe I try sometime, but everything bigger is better :)
bobricius wrote 09/07/2018 at 21:00 point
https://hackaday.io/project/160271-square-inch-pcb-coil-joule-thief smaller version also working ... and little better
