PCB coil joule thief is certified as open source hardware by the Open Source Hardware Association.
Some boards from first batch are for sale on TINDIE PCB coil joule thief
Mini version is here square-inch-pcb-coil-joule-thief
Experimental PCB single layer transformer - proof of concept
sch - 409.15 kB - 07/13/2018 at 21:58 |
brd - 99.88 kB - 07/13/2018 at 21:58 |
PCB coil joule thief has now officially been certified as open source hardware by the Open Source Hardware Association.
Promised new board photos ...
Little enlarged for AA battery, LED moved to center
It can not believe, I soldered all components .... slide switch to ON and LED shine :)
All at first attempt.
Some measurements
And last one bright photo ;-)
huraaaa board received from factory, super speed DHL, Lets go to asemblyyyyyyyyyyyyyy !!!!!
I am waiting on big surprise in Monday to watch if it work
I just finished board and waiting for surprise :)
Order magic PCB with coil, Eagle boards files are included.
All other components you can found in your drawer :)
Solder components, Transistor, Resistor, LED, Switch and battery holder, no more components required.
No wires for transformer coils:), there is all on PCB :)
Insert battery to holder, minimum battery voltage is 0.5V
Hi. The new design looks much better than the old one. I'm in a hurry to make a clone . So, do you have a plan to upload the new layout file?
Can you post the calculations for the coil, about a year ago i was making joule thiefs and i couldn't get the right calculations for the coil so i just made it by trial and error
Eagle CAD has a calculator inside for flat coil. Tools/Calculate Print Inductance
I hit the menu by accident yesterday. Also http://www.circuits.dk/calculator_planar_coil_inductor.htm
no calculation, I just draw biggest possible coil on 5x5cm board :)
I think yes, maybe I try sometime, but everything bigger is better :)
https://hackaday.io/project/160271-square-inch-pcb-coil-joule-thief smaller version also working ... and little better
Yes, but for edu purposes, think, a 1.5cm ring, die led flashing 1x/sec, small button battery... or, it flashes faster uf your hand is near emf. LED should be green, of course. 😉
