Group Gets has created a store entry for a tCam kit. You can find it here. It includes
- tCam-mini Rev4 (onboard antenna)
- gCore (pre-flashed with tCam-firmware)
3D Printed Enclosure
- Hardware:
- 4x M2x10 machine screws
- 4x 4-20 x 1/4 screws
- 8-Pin Female Header
- 10-Pin Male Header
- 2-Pin Jumper
- Lithium Ion Battery 2000mAh
You'll have to add a Lepton. I recommend the Lepton 3.5 instead of the Lepton FS because you're guaranteed accurate radiometric (temperature) data from the 3.5. But the FS is a little cheaper.
You can also add a Micro-SD card for local image storage.
There's also a link to the video showing how to assemble the camera. Instructions for use and links to all the supporting software in the github repository.
