AT+CPIN? +CME ERROR: SIM not inserted
A project log for FCThermostat: Another overengeneered IOT device
A new way of thinking to a IOT thermostat:
nicolNicolò 08/31/2018 at 17:180 Comments
I started cheking power lines for the SIM, it wasn't fine with the multimeter. Then I checked with the scope and I got a similar resoult like this one.
According to that topic I moved on to see if there was some cold joints. In fact looks like that the module is really sensible of the soldering temperature. So I cheked the circuit with the multimeter and all was looking fine. I then tested with the scope each sim tray pin. And probing the DATA pin I got a simple pulse.... like a RESET.
Dammit it happened again!
I have no idea how this could have happened but I reversed the two signals during the shematic phase of this board. (How can I have missed that, NO ERC was coming up)
With a some patience I removed the SIM slot and soldered it with wires directly to the SIM800
At the end I got it working, I received the test SMS and the call.
I'm still testing all the features of the module, for now I have seen that some don't works:
I'm not sure if it is due to the provider or the module itself. The antenna is also working fine the AT command replayed with a -60dBm as signal value. Also without the antenna the module is able to connect to the network but with a very low signal!
