New Year, New Prototypes, New Problems
A project log for FCThermostat: Another overengeneered IOT device
A new way of thinking to a IOT thermostat:
nicolNicolò 01/13/2019 at 07:260 Comments
Although I have ordered PCBs several months ago, they have only been delivered this week!
I have no idea how they managed to pack together all this stuff. I had to split it up into 3 different boxes after opening the package!
The boards quality looks good to me!
So I proceeded to assemble the Baseboard, everything went smoothly. The Phoenix connector fits perfectly, I had to move some connectors but in this way I got:
As already mentioned, reducing the size has also caused some boredom on other boards. One of these is the programming card.
The latter has been updated to have a USB / Serial adapter so as to reprogram the Atmega 328p on the fly.
In addition to serial programming, the programming module has pogo-pins to write the bootloader to the MCU.
The board works perfectly, pity for a small mistake: I have not moved the pogo pin pads after resizing the baseboard, this translates into having the pins diagonally. (The important thing is that it works)
NB-IOT, the module is assembled, AT commands the SIM7020 module responds correctly but I can not connect to a network. I'm looking for information at local TLC to understand if I need a particular sim.
The board itself with the SIM800C should work perfectly! (I have not yet been able to assemble one)
The final result:
