although the first badge turn out fine (apparently), it needed a little rework in order to work properly
my initial test in the LED matrix was unsuccessful, I thought that it was due to the initial random values that the shift registers can have sometimes, but i tried some rework on the led matrix
this didn't work, so I stopped there and started to program the program for the other peripherals
RRichmond
