Big Version PCB
A project log for PewPew Standalone
A Python-based micro game console, optimized for game development workshops.
deshipudeshipu 09/28/2018 at 08:333 Comments
I resisted for a long time, but when three more color versions of the big 60x60mm LED matrix arrived, I gave up and designed a PCB for them. You might recall that I already experimented with them before, a few logs ago, just connecting them with wires. Now I prepared a proper PCB:
I switched to silicon buttons, like in the #µGame, and a bigger through-hole power switch. Also, the battery holder is now on the front side (so the whole thing is thinner) and uses inline configuration of the batteries. There are also two prototyping areas on the sides, and two large holes for a lanyard if you wanted to use it as a badge of some sort. The back side is clear (except for the prototyping areas, of course).
I ordered the PCBs from @Elecrow this time, and they have already fabricated and sent it to me, now I'm just waiting for it to reach me:
titimoby wrote 10/02/2018 at 14:39 point
that's nice. This month I have 3 workshops so I'm quite busy and I already will show them a lot of boards (including a uGame) :)
But sure, count me in when available on Tindie
titimoby wrote 10/02/2018 at 14:24 point
It also looks nice in that format.
When you think that external experiment can happen, just say it, I'll give a try at both
deshipu wrote 10/02/2018 at 14:34 point
Well, I should have the regular PewPews in about a month (they will be available on Tinidie), and I think that those PCBs here should also arrive withing a week or two.
