Different tissue types have different impedances, so when you send an AC current through it will take different paths dependent on the material that is in it's way. The picture below describes the basic re-routing that is done by current that enables an image to be reconstructed. It's interesting as this is non-ionising radiation meaning it can be done much more safely than say an Cat scan which can cause cancer over time.
jean
