Enhancing the Blinder
A project log for Face Controlled Santa's Shop Window Display
Standing on the sidewalk, your smile or facial position controls elements of a "behind the glass" animated window display.
mike-rigsbyMike Rigsby • 07/19/2018 at 20:52•0 Comments
I needed something more permanent than a sheet of paper to tweak the blinder's upward vision, so I 3d printed an enhanced shield.
I taped this in place using masking tape to see if it worked as I desired.
It worked great--so I melted it into place using a soldering iron.
With the elf sitting on the box, the camera lens is only visible if your head is not more than 42 inches from the ground.
