battery mount - Part 1.stlBasic battery mount STL. Definitely use the onshape link to edit/incorporate this into a design!Standard Tesselated Geometry - 312.29 kB - 07/16/2018 at 22:50 |
duo mount - Part 1.stlA directly-usable / printable back-to-back mount with mounting eyelets and balance connectors. Prints vertically without support.Standard Tesselated Geometry - 0 bytes - 07/16/2018 at 22:52 |
topside mount - Part 1.stlPart-1 of a lay-flat mount designed for a skateboard, but with eyelets for easy alternative mounting.Standard Tesselated Geometry - 1.95 MB - 07/16/2018 at 22:52 |
Standard Tesselated Geometry - 1.98 MB - 07/16/2018 at 22:52 |
