ARDUINOIRC Library updated
08/08/2018 at 14:25 • 0 commentsI updated the .ino file so that it works with the library out of the gate. I forgot that I had to change the .cpp file in the IRC library to make it work. Brian Lough and Fredi Machado updated the library so there is no need to update the .cpp file. Everything should just be plug and play now. Special thanks to both Brian and Fredi twitch.tv/brianlough twitch.tv/fredimachadotv
