TODO:
- Cisco HWIC-3G-CDMA.(EP2C35F484C8) 5-10$
- Cisco VWIC3-2MFT-T1/E1 (EP2S30F484C5N) 10-15$
- NVIDIA PNY VCQFXSDIOPT2 (EP2SGX30CF780CSN) 15-20$
- MM5453CN1G Micro Memory NVRAM 1GB (XC5VLX30T) 10-15$
- HP 512MB FLASH BACKED WRITE CACHE (EP3C10F256C7N) 4$
- Comtech AHA AHA363PCIE0301G (Altera Arria GX) 10$
- IBM BladeCenter KVM Feature Card 13N0842 (EP1C12F256I7) 5-10$
- Dell S2716DGR, etc (Altera Arria V GX 5AGXMA3D4F...) 35-55$
- Napatech NT20X (xc4vfx100) 5-10$
https://github.com/MorriganR/c2hwic
VWIC3-1MFT (EP2S15)
SDI in/out, DVI in
JTAG pinout:
RU http://www.nedopc.org/forum/viewtopic.php?f=68&t=18524
JTAG pinout:
Here's my write-up on the HWIC-3G-CDMA: https://tomverbeure.github.io/2019/11/11/Cisco-HWIC-3G-CDMA.html
In additional to getting a blinky, I also have the SDRAM half-way up: it's not fully working because Quartus refuses to apply all timing constraints for reasons so far unknown. But I hope to clear the hurdle soon.
The MegaCore DDR controller is time limited unfortunately and only works when your board is tethered over JTAG to the PC. Hopefully somebody can make it work with an open source DDR SDRAM controller (like the LiteX DRAM controller.)
