Stage 8 - Test in Unity of wolfverine module
A project log for Multipurpose modular haptic control
This project has an intention to develop a haptic device that can control almost everything, it must be cheap, easy to build and implement.
Maximiliano RojasMaximiliano Rojas 08/18/2018 at 06:460 Comments
Is necessary obtain the equations that describe the position and orientation of the moving part of this module with respect to the base of the arm. We can start from the end effector because we already have the matrix that describes the arm structure, so, we only need to find the final position of the moving part with respect to the end effector (only position, because the orientation is not influenced by this, besides is the same in both cases). Is propper build two frames of reference:
Where {P} is the frame of reference for the end effector, {O} is for the moving part, p is the position of the end effector in {P}, and w is the position of the moving part in {O}, then:
Considering the rotation of the end effector:
To obtain w with respect {P} we just sum the components of p, so:
The end effector and moving part has the same rotation. A vídeo that show the test is:
