posAndOrientationAcquisitionSystem.igesCad files in .iges format (tested, include test module)iges - 18.00 MB - 08/18/2018 at 07:27 |
DeltaRobot.igesCad files in .iges format (tested)iges - 9.19 MB - 08/18/2018 at 07:27 |
wolfverineModule.igesCad files in .iges format (tested)iges - 6.26 MB - 08/18/2018 at 07:27 |
DeltaRobot.f3dCad files for Fusion 360f3d - 1.29 MB - 08/18/2018 at 07:26 |
wolfverineModule.f3dCad files for Fusion 360f3d - 1.19 MB - 08/18/2018 at 07:26 |
posAndOrientationAcquisitionSystem.f3dCad files for Fusion 360 (include test module)f3d - 2.94 MB - 08/18/2018 at 07:26 |
WolfverineVr.inoThis Arduino program contains the new equations and is the base for Vr-Unity example in stage 8, it sends the position and orientation of the end effector and the moving part to Unity .ino - 4.43 kB - 08/18/2018 at 07:01 |
posWolf.csThis is a C# program that receives information from the Arduino and moves the cube related to the moving part of the wolfverine module (is attached to a cube) used in stage 8.cs - 1.78 kB - 08/18/2018 at 07:00 |
posAcquisitionsystem.csThis is a C# program that receives information from the Arduino used in stage 8, is the same as ArduTest.cs but with a little modification to receive the position of the moving partcs - 1.75 kB - 08/18/2018 at 06:57 |
ArduTest.csThis is a C# program that receives information from the Arduino and moves the cube (is attached to the cube) used in stage 6.cs - 1.69 kB - 08/16/2018 at 05:24 |
ControlTestV2.inoThis Arduino program contains the NEW equations and is the base for Vr-Unity examples, it sends information to Unity too.ino - 3.47 kB - 08/16/2018 at 05:22 |
ControlTestV1.inoThis Arduino program contains the equations and is the base for MouseTestV1 and TestCarGameV1ino - 4.25 kB - 07/24/2018 at 18:55 |
MouseTestV1.inoIs the Arduino program used in Stage 3 to move a mouse, an Arduino due requiredino - 6.21 kB - 07/24/2018 at 18:55 |
TestCarGameV1.inoIs the Arduino program used in Stage 3 to drive a car in the video game, an Arduino due requiredino - 5.03 kB - 07/24/2018 at 18:55 |
