Dual 6581 SID Emulator
A dual SID chip replacement for the commodore 64 using teensy 3.6
This is a weekend project I had in mind for some time now. I used a teensy 3.6 and a couple of level shifting boards to intercept address and data lines of SID Chip.<br>On software side I used teensy audio library and ReSID by Frank Boesing as a sound engine.<br>Sound is dual-sid stereo using both dac pins of the teensy.<br>There are also plans for a led visual equalizer. You can find my source code on my github account.<br> I would like to thank:<br>Stephen White the creator of Pi1541 for this guidance and tips on how to proceed with this project.<br>And my friends at <a target="_blank" rel="noopener noreferrer" href="http://iamretro.gr">iamretro.gr</a> forum for providing me with enough information of how the chip works and especially users GeoAnas and DAT-ALEX.
  • 1 × LM7805 Power Management ICs / Linear Voltage Regulators and LDOs
  • 1 × 0.33uf capacitor
  • 1 × 0.1uf capacitor
  • 1 × Teensy 3.6 Teensy Microcontroller
  • 2 × Voltage Level Shifting board bi-directional 8 port
View all 6 project logs
  • 1
    Building instructions
    All the instructions you need to recreate this project are included inside the arduino sketch. Its just connecting lines to pins.
    I will create a schematic to upload to github asap.
View all instructions
Petros Kokotis wrote 08/31/2019 at 17:40 • point
nope
patzik wrote 01/09/2019 at 07:26 • point
Is the project dead?
