Hackaday.io Hackaday.io
Sign up Log in
EDGE IoT DATA COLLECTION DEVICE
An edge device to collect, store, analyze and react to IoT Data, plus sensors
david-g-simmonsDavid G. Simmons
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
0 comments
770 followers
  • Description
  • Details
  • Files 0
  • Components 6
    • View all
  • Logs 0
  • Instructions 1
    • View all
  • Discussion 0
View Gallery
Public Chat
890
0
770
4
Team (1)
  • david-g-simmonsDavid G. Simmons
Join this project's team
  • Blog
completed project
hardware
Software
iot DATA COLLECTION influxdb
This project is submitted for
  • Hackaday.com Tip Line
This project was created on 07/24/2018 and last updated 7 years ago.
Description
I wanted to build a system to be able to collect, store, analyze and react to IoT data at the edge. I wanted to be able to collect IoT data from LoRA, BLE, WiFi sensors, and have nice custom dashboards showing what each sensor was doing. This project uses all open-source hardware and software -- well, almost -- to build the data collector and the sensors.
Components
  • 1 × Pine-64 LTS Pine-64 embedded linux board https://www.pine64.org/?product=pine-a64-lts
  • 1 × Pine-64 7" LCD https://www.pine64.org/?product=7-lcd-touch-screen-panel
  • 1 × Pine-64 Project Box https://www.pine64.org/?product=pine64-playbox-enclosure
  • 1 × Pine-64 WiFi/BLE https://www.pine64.org/?product=wifi-802-11bgn-bluetooth-4-0-module
  • 1 × LiPo Battery https://www.pine64.org/?product=lithium-polymer-battery-us-only
View all 6 components
Build Instructions
Collapse
  • 1
    It's all here....
    See here, or here
View all instructions
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Adelaide city, a city with very limited water resources, has an issue with burst pipes
Project Owner Contributor
City wide water leakage monitoring
marcus-bergMarcus Berg
low cost sensor node project I am exploring to contribute data to the Things Network and eventually to city Open Data portal.
low cost open outdoor sensor node
mM
The 2018 Hackaday Prize
We built hardware to collect time series data and software to analyze the data in order to diagnose diseases earlier than doctors can.
Early Diagnosis of Life Threatening Diseases
will-buxtonWill Buxton
The LASS stands for “Location Aware Sensor System”. It is an open project and was started only in the interest of public welfare.
MQTT - Upload PM2.5 Data to LASS System
splendidemendaxSplendide_Mendax
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "EDGE IoT DATA COLLECTION DEVICE", please tell us the reason.
Send message
Remove Member
