Z80-MBC2: 4ICs homemade Z80 computer
8MHz Z80, 128kB banked RAM, RTC, Disk on SD, Basic and Forth interpreters, CP/M 2.2 and 3, cross Assembler and C (SDCC) toolchains
The Z80-MBC2 is an easy to build Z80 SBC (Single Board Computer).It is the "evolution" of the Z80-MBC (https://hackaday.io/project/19000-a-4-4ics-z80-homemade-computer-on-breadboard), with a SD as "disk emulator" and with a 128KB banked RAM for CP/M 3 (but it can run CP/M 2.2 and QP/M 2.71 too).
It has an optional on board 16x GPIO expander, and uses common cheap add-on modules for the SD and the RTC options. It has an "Arduino heart" using an Atmega32A as EEPROM and "universal" I/O emulator (so a "legacy" EPROM programmer is not needed).
It is a complete development "ecosystem", and using the iLoad boot mode it is possible cross-compile, load and execute on the target an Assembler or C program (using the SDCC compiler) with a single command (like in the Arduino IDE).
* * HARDWARE OVERVIEW * *
The needed ICs for the "base system" are:
  • Z80 CPU CMOS (Z84C00) 8Mhz or greater
  • Atmega32A
  • TC551001-70 (128kB RAM)
  • 74HC00
If you want the 16x GPIO expansion (GPE option) add a MCP23017 too.
The schematic and the BOM are attached in the Files section. The MCU Atmega32A is used as universal I/O subsystem, as Eeprom, and as reset and 4/8MHz clock generator for the Z80 CPU.
Inside the Atmega32A it is flashed an Arduino bootloader taken from here, and it is possible to use the Board Manager of the Arduino IDE to "import" it.
Flash the Arduino bootloader at first (with the method you prefer), next you can upload the IOS "sketch" (the I/O Subsystem that interacts with the Z80 bus and "virtualizes" the EEPROM and all the peripherals seen by the Z80 CPU) using Arduino IDE.
You can use the on board ICSP port J3 (also called ISP port) to write the bootloader, but remember to disconnect any other connector when using it. Also both SD and RTC modules (if present) must be removed from the board when the ICSP port is in use.
As clock source for the Z80 CPU it is used the 16MHz Atmega32A oscillator, so the "external 16MHZ osc." bootloader variant must be chosen when flashing the bootloader from the Arduino IDE!.
The 74HC00 is used as RS flipflop to stop the Z80 CPU during I/O operation, giving the needed time to the Atmega32A to interact with the Z80 bus, and as part of the MMU.
... Read more »
S220718-R260119_IOS-Z80-MBC2.zip
The sketch for the IOS (with the needed libraries). Unzip into a folder and open the .ino file (with Arduino IDE). IOS is required for CP/M 2.2, CP/M 3.0 and QP/M 2.71 (the SD module is mandatory). Adds the XMODEM protocol support. NOTE: now the default serial speed is 115200 bps.
Zip Archive - 38.24 kB - 03/10/2019 at 15:19
Download
SD-S220718-R260119-v1.zip
The content of the microSD needed to run CP/M 2.2, CP/M 3.0 and QP/M 2.71 with IOS S220718-R260119. Adds the XMODEM protocol support.
Zip Archive - 2.70 MB - 03/10/2019 at 15:20
Download
S220718-R260119_IOS-Z80-MBC2.ino.with_bootloader_atmega32_16000000L.hex
The sketch for the IOS in executable format (.HEX) with the bootloader. This executable file is intended for use with a programmer as the Atmel Ice or AVRISPmkII or others.
x-hex - 55.75 kB - 03/12/2019 at 16:41
Download
STARTREKV2.BAS
The famous game Super Startrek kindly debugged by a RetroBrew Computer Forum user. Play with Caps-Lock activated! Now the animation works...
bas - 20.18 kB - 08/07/2018 at 16:32
Download
TREKINST.BAS
Instructions for STARTREKV2.BAS
bas - 6.80 kB - 08/04/2018 at 21:48
Download
View all 11 files
  • 1 × See the file "A040618 BOM v2.ods" in the FILES section.
  • New IOS for XMODEM support
    Just4Fun03/10/2019 at 10:54 2 comments
    * * * UPDATE!!! * * *
    There is a problem with this new IOS with the MBASIC Basic interpreter. The "GPELED.BAS", "RTC.BAS" and "USERLED.BAS"  example programs don't work anymore. It seems that the way MBASIC does some I/O checks using the new virtual serial port interferes with others virtual I/O ports. Further analysis is required...
    * * * UPDATE 2 * * *
    I think to have found the origin... now thinking to a possible solution...
    * * * UPDATE 3 * * *
    I've uploaded on the FB user group a patch (for the SD) to solve the MBASIC issue only for CP/M 2.2. The patch is for testing.
    Because some people requested to use the XMODEM protocol to exchange files through the serial port, I've added the support for this protocol into CP/M 2.2 and CP/M 3 (banked only).
    XMODEM needs a full 8 bit binary data transfer, and this is not possible with the CON port (the CP/M port used for the console) with a "legacy" CP/M system installation because the CP/M Alteration Guide says to strip the eight parity bit when reading a byte from the console input.
    More, because the Z80-MBC2 uses a virtual serial port without handshaking there is also a timing problem when dealing with the 128 bytes packets used by the XMODEM protocol.
    So the support to the XMODEM protocol has requested changes in the IOS and  in the CP/M BIOS, and also in the Arduino core to extend the serial input buffer.
    Please note that with the new IOS the default speed of the serial port is now 115200 bps.
    To have the XMODEM support active, before the update of the new IOS firmware and the new SD image (see in the Files section),  you have to manually create a new "board variant" in the Arduino IDE and then change the default Rx input buffer size to 128 bytes in the "core" of this new variant.
    If you aren't interested into the XMODEM support, you can simply update the IOS and the new SD image as usual  without the need to create the new board variant. In this case the XMODEM will not work in the receive direction, but only in the send direction (from the Z80-MBC2 to a PC with a terminal emulator).
    HOW MANUALLY CREATE A NEW BOARD VARIANT (LINUX)
    In the following I'll assume an Arduino IDE 1.8.5 installation on a linux host and the MightyCore ver. 1.0.8. Anyway I've tried to make the procedure enough general to be used for other versions too.
    The first thing is find the directory where the MightyCore is located.
    If you...
  • uTerm preview: a VT100 terminal for the Z80-MBC2...
    Just4Fun12/28/2018 at 10:16 0 comments
    Currently working on a VT100 terminal with VGA out and  PS/2 keyboard with a power supply (for the Z80-MBC2 too). It has a "transparent" USB-TTL adapter connector, so you can upload firmware or load an Intel-Hex file (with iLoad) while the card is inserted. Both the "mixed" power supply scenarios (USB-TTL adapter not powered from USB but Z80-MBC2 powered and vice-versa) are managed. The video terminal is based on the ChibiTerm (https://hw-by-design.blogspot.com/2018/07/low-cost-vga-terminal-module-project.html).
    Stay tuned...
    Working on a new revision (A071218-R250119):
  • Overclocking the Z80-MBC2...
    Just4Fun11/02/2018 at 09:51 0 comments
    Because the Mighty Core gives the chance to choice a 20MHz bootloader, I've decided to try to "overclock" the Atmega32A using a 20MHz quartz:
    You don't need others HW changes, just use a 20MHz quartz instead of a 16MHz one. The Z80 clock speed will be at 10MHz.
    You have to select the "20MHz external" option in the "Toos" menu of Arduino IDE before flashing the 20MHz bootloader:
    Of course you need to load the sketch again (using the "20MHz external" option). IOS will display the new clock speed:
    Remember that using a 20MHz quartz you are out of the Atmega32a specifications (the Atmega32a is rated at 16MHz max.), so you are in a "grey area" where things "may works"...
  • CP/M 3 up and running on the Z80-MBC2!
    Just4Fun10/11/2018 at 06:58 0 comments
    With the latest IOS revision and the corresponding new SD image (see the Files section) there is one more option: the CP/M 3.0!
    With CP/M 3.0 it is possible use the 128KB banked RAM to have a wider user area (TPA) for programs and a more "evoluted" OS.
    TWO VERSIONS
    Just as example of how it is easy with CP/M 3.0 manage multiple configurations, I've done also a "non-banked" 64KB version. The switch from one version to the other can be done simply running a batch from the console itself.
    I've prepared two simple batch files to do that. From drive A: the command:
    submit sys64
    will set the 64KB "non-banked" version and then reboot the system.
    To activate again the 128KB "banked" version give the command (from drive A:):
    submit sys128
    NEW DISKDEFS FILE
    To use cpmtools or cpmtoolsGUI with the virtual disks of the CP/M 3.0 environment, you must update the DISKDEFS definition file (from the SD in the folder <SD>/cpmtools/) and use the "z80mbc2-cpm3" entry for all the 16 disks:
    Please note that for the CP/M 3.0 environment all the 16 virtual disks have the same structure and for this there is only one entry for all the CP/M 3.0 virtual disks.
    AUTOEXEC
    The AUTOEXEC switch for CP/M 3.0 works in a different way from the CP/M 2.2 and QP/M 2.71 implementations.
    Now there is a custom utility (AUTOEXEC) that checks the IOS flag and sets the exit code accordingly (using the BDOS function 108). This allow to use the CP/M 3.0 batch conditional execution (see the CP/M 3 Programmer Guide par. 1.6.3) to run any wanted command or program based on the status of the IOS AUTOEXEC flag.
    I've prepared an example using an other CP/M 3.0 feature, the "PROFILE.SUB" batch that is automatically executed at cold boot (if it exists). To activate it (in the drive A:) rename the file PROFILE.SU as PROFILE.SUB with the command:
    ren profile.sub=profile.su
    Now you can see how it works setting the AUTOEXEC flag on or off with the IOS "Select boot mode or system parameters" menu.
  • QP/M 2.71 up and running (with IOS multi-boot management...)!
    Just4Fun09/17/2018 at 18:26 0 comments
    With the latest IOS revision and the corresponding new SD image (see the Files section) there is an interesting alternative to CP/M developed by MICROCode Consulting that supports also file timestamping, and it is 100% CP/M 2.2 "compatible".
    MICROCode Consulting has released the original installation files and all the documentation in their site with the "restricted usage" condition, that means free for non-commercial use and for personal use only.
    To enable timestamping (see upper screenshot) you need to install the optional RTC module.
    I suggest to read the QP/M documentation for the various commands (see the Downloads section in their site).
    AUTOEXEC
    The QP/M uses for the batch file the .QSB extension. So the AUTOEXEC file is now renamed AUTOEXEC.QSB. To enable the AUTOEXEC execution after the cold boot change the corresponding state to ON from the usual IOS boot selection menu. In the drive A: there is an example of AUTOEXEC.QSB file ready to run.
    IOS MULTI-BOOT MANAGEMENT
    Now the IOS has a new entry (8) in the boot menu to manage the OS multi-boot configuration:
    Each OS is associated with a set of virtual disks called "Disk Set", and changing the "Change Disk Set..." entry (8) will switch all the virtual disks of his "environment".
  • CP/M 2.2 up and running on the Z80-MBC2!
    Just4Fun09/08/2018 at 18:24 0 comments
    The new IOS is out, and the CP/M 2.2 OS with it, and 16 disks are available (from A: to P:), each 8Mbyte large.
    With IOS (not for IOS Lite) the SD module is mandatory to run not only CP/M 2.2 but also for the stand-alone Basic and Forth interpreters. You need a microSD card (FAT16 and FAT32 are both supported) to store the content of the SD image file, retaining the directory structure.
    Pay attention on how the modules are inserted because their positions are fixed and absolutely not swappable (see the upper photo).
    To add, extract or delete files inside a virtual disk (virtual disks filenames on SD are "DS0Nxx.DSK", where "xx" is the disk number) it is possible use the cpmtools or cpmtoolsGUI utilities, with the diskdefs file in the \cpmtools directory of the SD zipped file.
    I suggest to use  cpmtoolsGUI (only for Windows) because is very easy.
    Unzip it into a folder and put the diskdefs file in the same folder.
    Select "z80mbc2-d0" only for disk 0, and "z80mbc2-d1" for the others (disk 1 - 15):
    NOTE: use cpmtoolsGUI only to add, extract or delete files inside a virtual disk. Not try to create new virtual disks files with cpmtools or cpmtoolsGUI because further processing is required for a valid virtual disk file.
  • How use the ICSP port with the USBasp programmer under linux to burn the bootloader
    Just4Fun07/27/2018 at 15:57 0 comments
    A cheap and easy way to burn the Arduino bootloader is to use an USBasp programmer that is commonly available:
    The USBasp is also capable to give the power to the "target" using the VCC pin, but remember to check that the JP1 jumper is set to provide 5V to the target (as shown in the photo).
    Please note that the pinout of the USBasp is a little different from the "standard" ICSP (os ISP) pinout:
    In the previous picture it is possible see that pins 4 (TXD) and 6 (RXD) are not at GND as expected  by the standard ICSP port, and pin 3 is not NC.
    See the following picture showing the standard 10 pin ICSP pinout:
    So you must consider this when connecting the USBasp to the 6 pins ICSP port (J3) on the Z80-MBC2 (see the schematic):
    To avoid problems I suggest to use as GND pin 10 of the USBasp connector, and connect the other pins (VCC, MISO, MOSI,SCK, RST) accordingly.
    An handy way to connect the USBasp to the 6 pin ICSP port (J3) of the Z80-MBC2 could be to use a commonly available "10pin to 6pin" adapter like this:
    but you cannot use it "as is" because its internal connections are done for a "standard" ICSP port, and we have seen that the USBasp connector differs from the standard one.
    The schematic of the adapter shows that isn't compatible "as is" with the UABasp connector:
    To use it is a good idea isolate the pins 4, 5 and 6 cutting the trace on the PCB of the adapter that connects those pins together, and then check with a tester.
    In the following photo are shown the three cuts (thin red lines inside the green "circle") to do:
    BURNING THE BOOTLOADER FROM ARDUINO IDE:
    To easily burn the bootloader follow these "quick and dirty" steps (tested on a linux Mint OS with Arduino IDE 1.8.5):
    STEP 1: Connect the 10 pins connector of the USBasp programmer to the 6 pins ICSP port (J3) of the Z80-MBC2 (using wires or a modified adapter as discussed before);
    STEP 2: Verify carefully that any other connector of the Z80-MBC2 is not used, and verify that both the SD and RTC modules (if present) are removed from the board;.
    STEP 3: Only at this point connect the USB side of the USBasp programmer to an USB port of your workstation;
    STEP 4: Open a "terminal" window on your workstation and go to the directory where there are the Arduino IDE executables, and get the root privileges with the command:
    sudo su
    then run the Arduino IDE with the command:
    ./arduino
    STEP 5: Because Arduino IDE is running as the root user it is necessary re-install the "core" for the Atmega32. Open the Board Manager as you already did (anyway  the guide is here). Note that you must do this step only the first time you execute the Arduino IDE as root;
    STEP 6: Now from the Tools menu of Arduino IDE select "Atmega32" as "Board", "16 MHz external" as "Clock", and "USBasp" as "Programmer". Then you can burn the right bootloader (without playing with the FUSE setting) selecting "Burn Bootloader" from the same "Tools" menu.
    All done!
View all 7 project logs
SupraJames wrote 11/13/2018 at 21:51 point
i noticed that the old MBC was using the serial port at 38400 baud but the new one is 9600 only. Is there a technical reason for that?
Jeff Davis wrote 11/14/2018 at 08:47 point
I changed the avr ios program's serial from 9600 to 38400, compiled and uploaded to the avr, and it seems to run just fine (played startrek), which makes sense since the serial port is handled by the avr cpu. 9600 just feels more retro I think since the terminal draws a lot faster at 38400.
nemfield wrote 11/11/2018 at 21:05 point
Hi. I have read through this (mostly) and it looks like fun.  I live in Ontario Canada and if anyone has a spare PCB I'd appreciate it. I can paypal you for the cost. Thank you.  Gabe (nemfield@gmail.com).
nemfield wrote 11/11/2018 at 22:33 point
OK. Replying to my own comment. I ordered 5 boards. I used China Post. I'm in Canada. when I get them I'll share them for postage costs to others near me. I advice you do NOT use DHL. Here in Canada they always add some silly brokerage fee and hold you hostage unless you pay it. They are a great service, but do not come clean on all charges.
Yann Guidon / YGDES wrote 11/11/2018 at 22:35 point
That's basically their business model...
Bartosz Makara wrote 11/12/2018 at 09:35 point
I'm living in Germany and when I'm ordering from outside the EU I'm always trying not to choose DHL because I know I have to pay some extra fees. It's terrible! If you order ar PCBway you can also choose E-Packet. I think this is a little bit faster than China Post and costs only a little bit more. And I've never had any problem with extra costs with this shipping way.
Bartosz Makara wrote 11/11/2018 at 13:59 point
Hello, I have two questions about the used parts where I am not completly sure about.
1. question: The "user LED" should be a 2.7V version or higher but what about the voltage of the other five LEDs? Since nobody else asked this here I'm pretty sure I've overseen some information or simply I'm too stupid. :D
2. question: The two tactile switches used in the schematics are per default closed and interrupt the ground line, right? Or do I have to use a reversed switch version? The more I'm trying to get it the less I'm sure about this.
villaromba wrote 11/11/2018 at 20:13 point
Q1: ther 5 LEDs aren't 'critical' but if you want to keep to the original design I've copied below from the BOM. (In FILES)
D1  LED-3MM  HALT Red
D11 LED-3MM SD Red
D2 LED-3MM  DMA White
D3 LED-3MM  IO_OP White
D4 LED-3MM  IOS Green
D5 LED-3MM  USER Blue
Q2: The 2 switches are normally open (standard tactile switch!) as per the schematic. Depress switch to operate.
Bartosz Makara wrote 11/12/2018 at 09:33 point
Oh great, thank you very much! :)
I knew I'm overlooking something!
Bartosz Makara wrote 11/07/2018 at 07:48 point
Does anybody know a good DIY project to build a serial terminal with a samll display which would work with this little Z80-machine? Probably something based on an Arduino Uno (I have a sapre one here ;). Unfortunately I'm not good in developing something like this for myself.
Mc John wrote 11/07/2018 at 08:13 point
This is a complete ASCII VT100 compatible video terminal in a single chip RS232/USB
http://geoffg.net/terminal.html
Bartosz Makara wrote 11/07/2018 at 12:09 point
Awesome! :) Thank you very much!
mustower wrote 11/03/2018 at 17:07 point
Hi, I am new to hackaday.io. This project ist really amazing. I wondering how I can get a PCB ? Any help/infos are apreciated.
Just4Fun wrote 11/03/2018 at 17:24 point
Thanks!. I've prepared an "easy link" to order a small lot (5 pcs min.) here: https://www.pcbway.com/project/shareproject/Z80_MBC2__4ICs_homemade_Z80_computer.html or you may ask if someone has a spare PCB... (my last spare PCB is now in Sweden...)
SupraJames wrote 11/03/2018 at 22:04 point
if you are in the UK I’d be happy to post you one of my PCBs which should be here in a couple of weeks
villaromba wrote 11/04/2018 at 16:06 point
I too have a spare PCB  you can have FOC  if you are in the UK !!!
SupraJames wrote 11/01/2018 at 21:57 point
Got bored of waiting for my PCBs so got it all up and running on breadboard. It booted first time which was unexpected! CP/M 3 also works. Really happy I found this project! https://imgur.com/gallery/kduyfE3 Next step, an LCD display module!
Just4Fun wrote 11/02/2018 at 08:31 point
Wow... That remembers me the first previous version (Z80-MBC) I made on breadboard (now destroyed... sigh...) .
Great!
SupraJames wrote 11/02/2018 at 10:50 point
I'm finding it a little hard to get started with 'bare bones' development. I want to try writing assembler and then presumably load it with iLoad. I've tried running TASM but it refuses to work on 64 bit windows, so I compiled z80-asm from http://wwwhomes.uni-bielefeld.de/achim/z80-asm.html on Linux, but it seems not to like your example .asm files.
Can you advise what I should be using as my toolchain here please? :)
Just4Fun wrote 11/02/2018 at 13:23 point
Give a look here: https://hackaday.io/project/19000-a-4-4ics-z80-homemade-computer-on-breadboard/log/52682-new-iload-boot-mode-and-an-automated-assembler-toolchain
It was for the Z80-MBC, but will work with the MBC2 too. I use a VM with WinXP to run TASM... (on a linux host)
SupraJames wrote 11/02/2018 at 14:55 point
Nice one. Well I actually found my own solution. zasm (https://k1.spdns.de/Develop/Projects/zasm/) generates .hex files perfectly for iLoad. So that's another way to do it.
Would be cool also if we had an assembler under CP/M too!
villaromba wrote 11/02/2018 at 16:23 point
I still have my v1 breadboard (something to pass on to the grandchildren!!!) but I love v2. Have added an LCD display and LED backback (4digit) onto the i2c buss by adding some new OPCODEs .  Big learning curve for me on the programming side. Also added a relay board on to the GPIO - just because!!!
SupraJames wrote 11/02/2018 at 18:11 point
@villaromba are you me? I just came here to say the same thing! Took an hour or so to get my head around the opcodes business, but I can write to my LCD from BASIC and assembler, so I'm well happy. THIS is how you learn how a computer works. https://imgur.com/gallery/d7qgD2P
Jeff Davis wrote 10/31/2018 at 04:56 point
I've build my board and after fixing a bad solder joint on the sd card slot it boot up and runs, but my leds are not working as expected.
Since I plan to put my board in a case, I soldered in 0 ohm resistors for the 6 leds, and soldered in jumper pins where the leds would go.
I now have a breadboard with resistors and leds hooked up, and after the board boots the IOS, DMA, and IO_OP leds stay lit all the time. In fact it seems like they are acting logically backwards - when I do "stat a:" the DMA and IO_OP leds flash, like the led is indicating work happening by going to 0 volts and not lighting the leds, then when work is done they go back to on again. Anyone have any ideas?
Here's my breadboard for context: https://drive.google.com/file/d/1kBfibaxGbCGJAtdZY2VeKpLQNkp1D6As/view?usp=sharing
Just4Fun wrote 10/31/2018 at 12:57 point
That seems normal (see the video)...
Jeff Davis wrote 11/01/2018 at 08:09 point
Ah I see, most of the leds are connected to active low pins. I modified your cpu test program that used HALT to test most of the leds; I couldn't figure out how to get the z80 to assert BUSACK so the DMA led is skipped. See https://drive.google.com/open?id=1uFqvNtlX2qfkbOiuGQzfBF28c3NXDE-Y
Bartosz Makara wrote 10/29/2018 at 09:54 point
Hey this is an awesome project. I've never used CP/M before but I love old computers and related matters. I've ordered 10 PCBs at pcbways.com and all needed parts in China. Now I have to be patient. ;)
I'm not very good in these things so probably this is a stupid question: Is there any possibility to access the GPIO with BASIC somehow? Or differnetly asked: How can I interact with the GPIO and the system?
SupraJames wrote 10/29/2018 at 13:02 point
Look at Examples with Basic.txt in the Files section - it shows how you can access the I/O ports from Basic.
Bartosz Makara wrote 10/29/2018 at 14:28 point
Oh yes, that's it! Thank you very much! :)
SupraJames wrote 10/26/2018 at 20:13 point
Hi! I'm going to build this and my PCBs are being fabricated. Yay!
I actually have an RTC module and an SD module already from playing with Arduino and wonder if they are suitable.
The SD module is https://imgur.com/gallery/Rzh1O1i and seems to be fairly generic, but not sure how to map the pins.
The RTC module is https://imgur.com/gallery/VnwoS8V and based on a DS1307 chip.
Would these work at all? Pin layout aside?
SupraJames wrote 10/26/2018 at 20:57 point
OK so I might have at least answered my own question regarding the RTC module. It looks like it will not work out-of-the-box but I could probably modify the IOS sketch to support it, which sounds like fun.
According the data sheets, the I2C address is the same, but the DS1307 is less accurate and does not have a status register, so no Oscillator Stop Flag. Also no temperature sensor to read.
It might need initialising in a different way - there's a CH flag in register 0 which needs to be set on power up.
Apart from that I think the time registers are the same.
Just4Fun wrote 10/26/2018 at 21:22 point
Hi, that SD module seems have an on board 3.3V regulator and level adapter, so just pay attention to use the right pins...
About the RTC, as you said you should tweak the code just a little... (no temperature sensor, but I think you can live happily without that one too...)
SupraJames wrote 10/26/2018 at 21:42 point
Great, thanks! Looking forward to getting started. The only other deviation from the design I am planning is the use of a different memory chip. It's an Alliance AS6C1008-55PCN - https://uk.farnell.com/alliance-memory/as6c1008-55pcn/sram-1mb-2-7v-5-5v-128kx8-pdip32/dp/1562896
Pinout is the same, it's just a faster chip. You think I'll be OK?
Just4Fun wrote 10/27/2018 at 06:41 point
Yes, it is ok!
SupraJames wrote 10/28/2018 at 20:17 point
Well I'm rather confused about the SD reader. I have mocked up the Arduino parts of the MBC2 on breadboard (No Z80 and no SRAM) as per your schematic. The built-in SD library from Arduino works fine, and I can list all the files on the FAT32 formatted SD card I have using the CardInfo example sketch, so I know the wiring and hardware is good.
However, when I flash the IOS, I get a brief flash of the SD LED and:
IOS: SD error 2 (NOT_READY on MOUNT operation)
IOS: Check SD and press a key to repeat
Get the same with two different cards. Any ideas?
Just4Fun wrote 10/31/2018 at 13:05 point
The error means that is not possible initialize the SD due to a hard error or no medium...
Try to power off the Z80-MBC2 and power on it again (after a few seconds) with the SD adapter connected and the SD into it.
SupraJames wrote 11/01/2018 at 15:37 point
Update with the SD card module, I actually ordered a new module similar to the ones you suggested, mainly to get the correct order of pins for the PCB, and the new module works fine. So there must have been something odd about my one which meant it worked OK with the arduino SD library but not with picofat.
George Warner wrote 10/23/2018 at 11:33 point
I’m working on bringing up CP/M 3.0 banked on Bill Shen’s z280rc board… but could use some clues… is your banked BIOS sources available anywhere?
Just4Fun wrote 10/23/2018 at 11:43 point
All the custom BIOS sources are in the SD zip file under "/src".
George Warner wrote 10/23/2018 at 11:45 point
Thank you. Much appreciated.
villaromba wrote 10/13/2018 at 08:52 point
If you do need to use the TL866 direct, the only fuse settings you need to select are :-  SUT0, SUT1, SPIEN, BOOTSZ1, BOOTSZ0 - (this gives CF & D9) - make sure everything else is not selected. I've used these settings every time - and every time a success!!!
scottie4442 wrote 10/12/2018 at 13:56 point
OK, just got the new IOS for cp/m 3 uploaded and copied the sd image to a blank fat32 formated sd card.  when I boot the z80-mbc2 I get the menu. I set the rtc to the correct time and change diskset to 2, the CP/M 3 set. when I try to boot the os I get Z80 is running from now I either get the prompt again and cannot type or I get nothing, it looks like it just hangs. I have run down the menu and I get this same behavior from basic, forth, CP/M 2.2, QP/M 2.71 and CP/M 3.0. not sure what to do now.
Just4Fun wrote 10/12/2018 at 14:20 point
Try to flash IOS-LITE ( https://cdn.hackaday.io/files/1599736844284832/S220618_IOS-LITE-Z80-MBC2.ino ) and tell me if the various options work...
PS: this is the first time you run the board...?
scottie4442 wrote 10/12/2018 at 15:43 point
OK, I uploaded the IOS-LITE and I get the same thing, when I try to load basic, forth or the iload, I get Z80 is running from now and then nothing it just sits there and I get nothing else.  I tried to reset and the menu come back but when I make a selection it does the same thing.  I have check that my soldering is ok and that the chips are seated properly.
Just4Fun wrote 10/12/2018 at 16:11 point
An other user had exactly the same issue... it was a faulty SRAM (it could be a faulty Z80 or 74HC00 too, but the SRAM is at first place).
The Atmega seems work properly.
PS: Are you sure to have a CMOS Z80...?
scottie4442 wrote 10/12/2018 at 16:47 point
chips are :
Zilog z84c0008PEG
Atmel ATMEGA32A
TI SN74HCT00N
MCP23017-E/SP
All these are brand new chips from Mouser
Just4Fun wrote 10/12/2018 at 16:54 point
Chips numbers seem ok.
Which method have you used to flash the bootloader?
scottie4442 wrote 10/12/2018 at 21:57 point
with usbasp and arduino ide. I did remove the rtc and sd card reader as suggested and plugged the usbasp in according to the info above.  I also have a tl866 programmer that I can program the atmega32a with but I was not sure of the fuse settings.
Just4Fun wrote 10/13/2018 at 09:36 point
Ok, given that all seems as expected and excluding ghosts and black magic, the suspects are on the SRAM and CPU again...
I've prepared a IOS-LITE modified test version to test the CPU only. This simple test will force the Z80 into HALT, so the HALT led will turn on. The SRAM is not used, so this test can be run also without any SRAM chip installed.
The sketch is downloadable from here: https://drive.google.com/open?id=1irVxE3IF_Ilte1c547ZSuzLTaaWIfeeC
If you press RESET, the HALT led will turn off for about one second, then it will turn on again.
scottie4442 wrote 10/13/2018 at 13:32 point
OK, I think I found part of the problem (I am an idiot sometimes).  I went back to start fresh and  when I did the boot loader step I realized there is a USBasp and a USBasp(MightCore). I chose the USBasp(MightCore) this time and it is getting further seem like, but now when I try to load Basic, Forth or iLoad, the IOS and Halt led's are solid and the DMA is blinking occasionally the goes out. Hopefully this is progress. Oh I used IOS again for this not IOS-LITE
Just4Fun wrote 10/05/2018 at 22:00 point
Jay Sissom wrote 10/05/2018 at 18:58 point
Hello, I can't find the vendor and model number of the RTC and SD card adapters.  Can you  please provide that?  Thanks.
scottie4442 wrote 09/30/2018 at 18:26 point
I see an your info that you say to use cpmtools or cpmtoolGUI to make the sd cards to run cpm 2.2 and/or qpm 2.71. is there some place that shows the steps by step to create the d card from empty, I have a 32gb sd card formatted with fat32 and not sure what to do to start the process.
Just4Fun wrote 09/30/2018 at 18:37 point
Hi, to run CP/M or QP/M you only need to unzip the SD zipped file into the SD with your PC.
Cpmtools or cpmtoolGUI are only needed to add, extract or delete a file  * inside * a CP/M or QP/M virtual disk.
scottie4442 wrote 09/30/2018 at 20:07 point
ok, that lets me know what I needed.  I have worked on trs-80, apples, etc, been in computer for 40 years, just not worked with cp/m in 30 years so having ro recall with my OLD brain how this works.
Just4Fun wrote 09/30/2018 at 21:09 point
Great! If you want a "preview" of CP/M 3 you can try this too: https://twitter.com/Just4Fun_J4Fun/status/1045730075398803456
Boris wrote 09/26/2018 at 10:17 point
I built mine and after a lot of debugging with a scope, something is very strange.  For debugging purposes I wrote a sketch to ask for pin number and 1/0 value to place on any pin, and exercising it shows that all the correct signals propagate properly from the ATMEGA to everywhere they should.  But during this, something really unusual is happening: the IOREQ pin of the Z80 activates low for no apparent reason.  I mean, it just received the "single-pulses reset".  There is no clock coming -- pin 6 is sitting at 0.  Nothing is happening, and the ATMEGA is just waiting for console input, yet somehow, spontaneously, after a few seconds Z80's pin 20 pulls to 0.  I am at the end of my wit...
Just4Fun wrote 09/26/2018 at 11:33 point
I have no idea about your test, but reading your note it seems that you have some Atmega GPIO pins left in HiZ.... (I mean as INPUT without PULLUP).
villaromba wrote 09/17/2018 at 22:09 point
QP/M  - Love the progression of this project., particularly the ease of getting software onto the SD card via CPMTOOLS guii - a good find!!!
john wrote 09/11/2018 at 23:54 point
What are you guys using for terminal emulation settings?  Specifically, have you gotten backspace to work?
Just4Fun wrote 09/12/2018 at 09:48 point
Using Tera Term it works out of the box (if I remember well)...
john wrote 09/12/2018 at 23:38 point
Thanks - I tried TeraTerm and it works fine.  Was using Putty and had to change the keyboard to send ctrl-H instead of ctrl-? under keyboard settings.  That makes things much easier!
Jeff Davis wrote 09/09/2018 at 08:37 point
Just4Fun: On the BOM sheet, RN1 and RN2 are listed as a SIP8 (8 pins), but the board has 9 pins (8 resistor + 1 common 5v). Should the sheet say SIP9 (which has 9 pins, 8 resistors and 1 common)?
Just4Fun wrote 09/09/2018 at 10:44 point
Yes is SIP9 (which has 9 pins, 8 resistors and 1 common). I'll change it in the BOM...
Jeff Davis wrote 09/05/2018 at 06:48 point
Just4Fun: I just ordered 10 PCBs (in black) from pcbway, thanks for setting up that shared project to make it easy to order. When I ordered, buying 10 boards was the same price as 5, with a little extra shipping cost.
I'm looking at ordering parts now, and I see on the BOM that C1,C2,C5,C6,C8,C9,C12 are all ".1uF", while C10 is "0.1uF". Are those all 0.1uF, or is one of the values listed wrong?
Just4Fun wrote 09/05/2018 at 07:36 point
No, it's the same value... (.1uF = 0.1uF). Because it is on an other sheet, I've forgotten to follow the same "convention" of the other sheet.... :)
Don't miss the Twitter "channel" with "some" preview and "spoilers": https://twitter.com/Just4Fun_J4Fun
