Z80-MBC2: 4ICs homemade Z80 computer
8MHz Z80, 128kB banked RAM, RTC, Disk on SD, Basic and Forth interpreters, CP/M 2.2 and 3, cross Assembler and C (SDCC) toolchains
The Z80-MBC2 is an easy to build Z80 SBC (Single Board Computer).It is the "evolution" of the Z80-MBC (https://hackaday.io/project/19000-a-4-4ics-z80-homemade-computer-on-breadboard), with a SD as "disk emulator" and with a 128KB banked RAM for CP/M 3 (but it can run CP/M 2.2 and QP/M 2.71 too).
It has an optional on board 16x GPIO expander, and uses common cheap add-on modules for the SD and the RTC options. It has an "Arduino heart" using an Atmega32A as EEPROM and "universal" I/O emulator (so a "legacy" EPROM programmer is not needed).
It is a complete development "ecosystem", and using the iLoad boot mode it is possible cross-compile, load and execute on the target an Assembler or C program (using the SDCC compiler) with a single command (like in the Arduino IDE).
* * HARDWARE OVERVIEW * *
The needed ICs for the "base system" are:
  • Z80 CPU CMOS (Z84C00) 8Mhz or greater
  • Atmega32A
  • TC551001-70 (128kB RAM)
  • 74HC00
If you want the 16x GPIO expansion (GPE option) add a MCP23017 too.
The schematic and the BOM are attached in the Files section. The MCU Atmega32A is used as universal I/O subsystem, as Eeprom, and as reset and 4/8MHz clock generator for the Z80 CPU.
Inside the Atmega32A it is flashed an Arduino bootloader taken from here, and it is possible to use the Board Manager of the Arduino IDE to "import" it.
Flash the Arduino bootloader at first (with the method you prefer), next you can upload the IOS "sketch" (the I/O Subsystem that interacts with the Z80 bus and "virtualizes" the EEPROM and all the peripherals seen by the Z80 CPU) using Arduino IDE.
You can use the on board ICSP port J3 (also called ISP port) to write the bootloader, but remember to disconnect any other connector when using it. Also both SD and RTC modules (if present) must be removed from...
SD-S220718-R260119-v2.zip
The content of the microSD needed to run CP/M 2.2, CP/M 3.0 and QP/M 2.71 with IOS S220718-R260119. Adds the XMODEM protocol support. Fixes a issue with MBASIC.
Zip Archive - 2.76 MB - 03/24/2019 at 17:15
Download
S220718-R260119_IOS-Z80-MBC2.zip
The sketch for the IOS (with the needed libraries). Unzip into a folder and open the .ino file (with Arduino IDE). IOS is required for CP/M 2.2, CP/M 3.0 and QP/M 2.71 (the SD module is mandatory). Adds the XMODEM protocol support. NOTE: now the default serial speed is 115200 bps.
Zip Archive - 38.24 kB - 03/10/2019 at 15:19
Download
S220718-R260119_IOS-Z80-MBC2.ino.with_bootloader_atmega32_16000000L.hex
The sketch for the IOS in executable format (.HEX) with the bootloader. This executable file is intended for use with a programmer as the Atmel Ice or AVRISPmkII or others (Fuse bits: High Byte 0xD6, Low Byte 0xAF, Lock Byte 0xCF)
x-hex - 55.75 kB - 03/12/2019 at 16:41
Download
STARTREKV2.BAS
The famous game Super Startrek kindly debugged by a RetroBrew Computer Forum user. Play with Caps-Lock activated! Now the animation works...
bas - 20.18 kB - 08/07/2018 at 16:32
Download
TREKINST.BAS
Instructions for STARTREKV2.BAS
bas - 6.80 kB - 08/04/2018 at 21:48
Download
View all 11 files
  • 1 × See the file "A040618 BOM v2.ods" in the FILES section.
  • uCom is out!
    Just4Fun05/29/2019 at 09:20 0 comments
    I've done a separate "project page" for uCom (RS232 add-on card for the Z80-MBC2) here.
    The uCom board, as the uTerm VT100 board, has a "transparent" USB-serial adapter connector, so you can upload firmware to the Z80-MBC2 (using Arduino IDE) or load an Intel-Hex file (with iLoad) or use XMODEM to exchange files with a PC (running a terminal emulator that supports XMODEM file transfer) while the uCom is in use.
    Both the "mixed" power supply scenarios (USB-serial adapter not powered from USB but Z80-MBC2 powered and vice-versa) are managed by the HW, so you don't need to worry about it.
    uCorm can be mounted horizontally or vertically to the Z80-MBC2.
    The 3D printed custom angled brackets .STL files are the same of the uTerm.
    Here connected with a "vintage" RS232 terminal (Ampex 210 relabeled Kyber):
  • FuzixOS preview: Unix for Z80!...
    Just4Fun05/21/2019 at 17:14 1 comment
    First test with FuzixOS on the Z80-MBC2 (many many thanks to Alan Cox...)!:
    Stay tuned...
  • uTerm is out!
    Just4Fun05/14/2019 at 07:40 0 comments
    I've done a separate "project page" for uTerm here.
    uTerm can be mounted horizontally or vertically to the Z80-MBC2.
    All the details including the 3D printed custom angled brackets .STL files are there.
    uTerm is a VT100 terminal with VGA out and  PS/2 keyboard with a power supply (for the Z80-MBC2 too). It has a "transparent" USB-TTL adapter connector, so you can upload firmware or load an Intel-Hex file (with iLoad) while the card is inserted. Both the "mixed" power supply scenarios (USB-TTL adapter not powered from USB but Z80-MBC2 powered and vice-versa) are managed. The video terminal is based on the ChibiTerm (https://hw-by-design.blogspot.com/2018/07/low-cost-vga-terminal-module-project.html).
  • uCom preview: a RS232 adapter for the Z80-MBC2...
    Just4Fun04/05/2019 at 17:00 0 comments
    Currently working on a RS232 add-on card for the Z80-MBC2.
    As the uTerm board, it has a power supply for the Z80-MBC2 and a "transparent" USB-TTL adapter connector, so you can upload firmware or load an Intel-Hex file (with iLoad) while the card is inserted. Both the "mixed" power supply scenarios (USB-TTL adapter not powered from USB but Z80-MBC2 powered and vice-versa) are managed.
    Here connected to an Ampex 210 terminal (sold and relabeled by Kyber):
    Stay tuned...
  • New IOS for XMODEM support
    Just4Fun03/10/2019 at 10:54 4 comments
    * * * UPDATE!!! * * *
    There is a problem with this new IOS with the MBASIC Basic interpreter. The "GPELED.BAS", "RTC.BAS" and "USERLED.BAS"  example programs don't work anymore. It seems that the way MBASIC does some I/O checks using the new virtual serial port interferes with others virtual I/O ports. Further analysis is required...
    * * * UPDATE 2 * * *
    I think to have found the origin... now thinking to a possible solution...
    * * * UPDATE 3 * * *
    The new SD image (SD-S220718-R260119-v2.zip) is out in the Files section. It fixes the MBASIC issue for CP/M 3 and 2.2. Please update your SD image.
    Because some people requested to use the XMODEM protocol to exchange files through the serial port, I've added the support for this protocol into CP/M 2.2 and CP/M 3 (banked only).
    XMODEM needs a full 8 bit binary data transfer, and this is not possible with the CON port (the CP/M port used for the console) with a "legacy" CP/M system installation because the CP/M Alteration Guide says to strip the eight parity bit when reading a byte from the console input.
    More, because the Z80-MBC2 uses a virtual serial port without handshaking there is also a timing problem when dealing with the 128 bytes packets used by the XMODEM protocol.
    So the support to the XMODEM protocol has requested changes in the IOS and  in the CP/M BIOS, and also in the Arduino core to extend the serial input buffer.
    Please note that with the new IOS the default speed of the serial port is now 115200 bps.
    To have the XMODEM support active, before the update of the new IOS firmware and the new SD image (see in the Files section),  you have to manually create a new "board variant" in the Arduino IDE and then change the default Rx input buffer size to 128 bytes in the "core" of this new variant.
    If you aren't interested into the XMODEM support, you can simply update the IOS and the new SD image as usual  without the need to create the new board variant. In this case the XMODEM will not work in the receive direction, but only in the send direction (from the Z80-MBC2 to a PC with a terminal emulator).
    HOW MANUALLY CREATE A NEW BOARD VARIANT (LINUX)
    In the following I'll assume an Arduino IDE 1.8.5 installation on a linux host and the MightyCore ver. 1.0.8. Anyway I've tried to make the procedure enough general to be used for other versions too.
    ... Read more »
  • uTerm preview: a VT100 terminal for the Z80-MBC2...
    Just4Fun12/28/2018 at 10:16 2 comments
    Currently working on a VT100 terminal with VGA out and  PS/2 keyboard with a power supply (for the Z80-MBC2 too). It has a "transparent" USB-TTL adapter connector, so you can upload firmware or load an Intel-Hex file (with iLoad) while the card is inserted. Both the "mixed" power supply scenarios (USB-TTL adapter not powered from USB but Z80-MBC2 powered and vice-versa) are managed. The video terminal is based on the ChibiTerm (https://hw-by-design.blogspot.com/2018/07/low-cost-vga-terminal-module-project.html).
    Stay tuned...
    Working on a new revision (A071218-R250119):
    Waiting the new PCB, I'm playing with the current PCB "patched" to perform like the new one.
    Here a session with Wordstar 4 configured to use all the 30 rows of uTerm:
    In the photo you can see that also the serial-USB adapter is attached to the uTerm using the "transparent" port. This allows to use two keyboards and two monitors in the "same" time (one keyb and monitor attached directly to the uTerm, and another keyb and monitor of the terminal emulator on a PC connected with the serial-USB). This allows also to use XMODEM (e.g. between the Z80-MBC2 and a PC) or to flash the Atmega firmware with the uTerm connected.
    Or you can use the monitor attached to the uTerm and the keyboard of the terminal emulator on a PC. This is exactly the "configuration" I used in the photo to make the test (as you can see, there isn't any keyb attached to the uTerm).
    Catchum demo with uTerm (a sort of Pacman...). Leaving the game alone, after a while the "demo mode" starts:
    Here last version assembled horizontally with the Z80-MBC2:
    Currently making custom 3D printed mounting brackets for a solid vertical assembling:
  • Overclocking the Z80-MBC2...
    Just4Fun11/02/2018 at 09:51 2 comments
    Because the Mighty Core gives the chance to choice a 20MHz bootloader, I've decided to try to "overclock" the Atmega32A using a 20MHz quartz:
    You don't need others HW changes, just use a 20MHz quartz instead of a 16MHz one. The Z80 clock speed will be at 10MHz.
    You have to select the "20MHz external" option in the "Toos" menu of Arduino IDE before flashing the 20MHz bootloader:
    Of course you need to load the sketch again (using the "20MHz external" option). IOS will display the new clock speed:
    Remember that using a 20MHz quartz you are out of the Atmega32a specifications (the Atmega32a is rated at 16MHz max.), so you are in a "grey area" where things "may works"...
  • CP/M 3 up and running on the Z80-MBC2!
    Just4Fun10/11/2018 at 06:58 0 comments
    With the latest IOS revision and the corresponding new SD image (see the Files section) there is one more option: the CP/M 3.0!
    With CP/M 3.0 it is possible use the 128KB banked RAM to have a wider user area (TPA) for programs and a more "evoluted" OS.
    TWO VERSIONS
    Just as example of how it is easy with CP/M 3.0 manage multiple configurations, I've done also a "non-banked" 64KB version. The switch from one version to the other can be done simply running a batch from the console itself.
    I've prepared two simple batch files to do that. From drive A: the command:
    submit sys64
    will set the 64KB "non-banked" version and then reboot the system.
    To activate again the 128KB "banked" version give the command (from drive A:):
    submit sys128
    NEW DISKDEFS FILE
    To use cpmtools or cpmtoolsGUI with the virtual disks of the CP/M 3.0 environment, you must update the DISKDEFS definition file (from the SD in the folder <SD>/cpmtools/) and use the "z80mbc2-cpm3" entry for all the 16 disks:
    Please note that for the CP/M 3.0 environment all the 16 virtual disks have the same structure and for this there is only one entry for all the CP/M 3.0 virtual disks.
    AUTOEXEC
    The AUTOEXEC switch for CP/M 3.0 works in a different way from the CP/M 2.2 and QP/M 2.71 implementations.
    Now there is a custom utility (AUTOEXEC) that checks the IOS flag and sets the exit code accordingly (using the BDOS function 108). This allow to use the CP/M 3.0 batch conditional execution (see the CP/M 3 Programmer Guide par. 1.6.3) to run any wanted command or program based on the status of the IOS AUTOEXEC flag.
    I've prepared an example using an other CP/M 3.0 feature, the "PROFILE.SUB" batch that is automatically executed at cold boot (if it exists). To activate it (in the drive A:) rename the file PROFILE.SU as PROFILE.SUB with the command:
    ren profile.sub=profile.su
    Now you can see how it works setting the AUTOEXEC flag on or off with the IOS "Select boot mode or system parameters" menu.
  • QP/M 2.71 up and running (with IOS multi-boot management...)!
    Just4Fun09/17/2018 at 18:26 0 comments
    With the latest IOS revision and the corresponding new SD image (see the Files section) there is an interesting alternative to CP/M developed by MICROCode Consulting that supports also file timestamping, and it is 100% CP/M 2.2 "compatible".
    MICROCode Consulting has released the original installation files and all the documentation in their site with the "restricted usage" condition, that means free for non-commercial use and for personal use only.
    To enable timestamping (see upper screenshot) you need to install the optional RTC module.
    I suggest to read the QP/M documentation for the various commands (see the Downloads section in their site).
    AUTOEXEC
    The QP/M uses for the batch file the .QSB extension. So the AUTOEXEC file is now renamed AUTOEXEC.QSB. To enable the AUTOEXEC execution after the cold boot change the corresponding state to ON from the usual IOS boot selection menu. In the drive A: there is an example of AUTOEXEC.QSB file ready to run.
    IOS MULTI-BOOT MANAGEMENT
    Now the IOS has a new entry (8) in the boot menu to manage the OS multi-boot configuration:
    Each OS is associated with a set of virtual disks called "Disk Set", and changing the "Change Disk Set..." entry (8) will switch all the virtual disks of his "environment".
  • CP/M 2.2 up and running on the Z80-MBC2!
    Just4Fun09/08/2018 at 18:24 0 comments
    The new IOS is out, and the CP/M 2.2 OS with it, and 16 disks are available (from A: to P:), each 8Mbyte large.
    With IOS (not for IOS Lite) the SD module is mandatory to run not only CP/M 2.2 but also for the stand-alone Basic and Forth interpreters. You need a microSD card (FAT16 and FAT32 are both supported) to store the content of the SD image file, retaining the directory structure.
    Pay attention on how the modules are inserted because their positions are fixed and absolutely not swappable (see the upper photo).
    To add, extract or delete files inside a virtual disk (virtual disks filenames on SD are "DS0Nxx.DSK", where "xx" is the disk number) it is possible use the cpmtools or cpmtoolsGUI utilities, with the diskdefs file in the \cpmtools directory of the SD zipped file.
    I suggest to use  cpmtoolsGUI (only for Windows) because is very easy.
    Unzip it into a folder and put the diskdefs file in the same folder.
    Select "z80mbc2-d0" only for disk 0, and "z80mbc2-d1" for the others (disk 1 - 15):
    NOTE: use cpmtoolsGUI only to add, extract or delete files inside a virtual disk. Not try to create new virtual disks files with cpmtools or cpmtoolsGUI because further processing is required for a valid virtual disk file.
View all 11 project logs
Peabody1929 wrote 02/12/2019 at 21:40 point
I built a second system.  It is up and running just fine with a HM628128ALP-7 SRAM as well.  To test the board I booted CP/M and ran MBASIC.  I opened the "Examples with Basic" on my PC, copied the USER LED BLINK example and pasted it into Tera Term at the MBASIC prompt.  This is a very easy way to get a program into the system.  Then I did SAVE "BLINK",A to put the app into the SD Card disk file.  RUN executed the app and blinked the LED.  All in all, it took about a minute the run the app to test the LED.  Very nice!
Linker3000 wrote 02/09/2019 at 13:55 point
Just FYI, the board works fine with HM628128ALP-7 SRAM and should also be OK with AS6C1008-55PCN.
asorc wrote 02/07/2019 at 16:15 point
Hello,
Let's see if some of you have had the same or a similar issue. So, I do not have a way to upload sketches in windows 7, but I do have a raspberry pi model b. Therefore, I use it to upload hex files to a blank atmega32a. I compile the sketches with the mightycore library, wire, etc. in windows 7, using arduino ide, and then take the hex files to burn them with the raspberry pi to the atmega32a using six wires and the GPIO connections of the raspberry pi. The result I get when I set up the computer to power it on and start the serial monitor of arduino ide, is that the IOS led starts to blink, but at a quite slow rate, and when I open the terminal, nothing happens. Has any of you had a similar problem? I uploaded a hex file that has the bootloader included according with its name, but I do not know if everything has gone really well, apparently avrdude tells me so, or if any IC is damaged. Thanks to all, in advance.
jmarik wrote 02/07/2019 at 21:16 point
Are the fuses set correctly? I used CF, D9.
asorc wrote 02/07/2019 at 22:24 point
I don't remember which ones come in the configuration of avrdude, because I have not touched anything else appart from the GPIO pins I use. I will have a look at it.
Linker3000 wrote 02/09/2019 at 14:09 point
Confirming the fuses (CF D9).
I ended up using a TL866 programmer because I could not get ICSP/USBASP to work. When I went back to basics later, I found that one of the wires in the ribbon cable I was using between the USBASP and the board header was open circuit! I only discovered this later when I could not get serial comms to work using the same cable! It's always the 'little things'!
asorc wrote 02/10/2019 at 01:01 point
Are these fuses the high and the low respectively? What about the lock byte?
I see there are different settings. I have seen the boards.txt of mightycore library, but It is not entirely clear to me which fuses It burns.
Frank N. Stein wrote 02/08/2019 at 09:00 point
I used "optiboot_flash_atmega32_UART0_115200_16000000L.hex" with
High Byte 0xD6
Low  Byte 0xAF
Lock Byte 0xCF
and it works very well...
asorc wrote 02/08/2019 at 12:48 point
Thanks for showing me where the problem is mostramos likely to be. I am checking the avrdude.conf file, in the m32 section, and I see some subsections memory lfuse, memory hfuse and memory lock, and below, without a write option, memory signature, memory calibration.
Definitely I have to get more knowledge. I guess these are some default values I can change there or externally, without modifying this. I have seen ways to do It with avrdude. I will have a look at it.
Thanks, any help is very very welcome.
Frank N. Stein wrote 02/06/2019 at 13:27 point
Hi, has anyone managed to send files with Kermit, Xmodem, Qterm or similar via the console interface? I have tried different versions of Kermit (with Terraterm on the PC side) that should have worked - unfortunately without success...
Z80-MBC2 does not support hardware handshaking, but Kermit should also work without it... :-(
Any help is appreciated!
RWDEANE wrote 02/12/2019 at 15:22 point
Currently there is  probably a bug in the z80mbc2 serial handling. An earlier message states that xmodem needs hw handshaking but this is untrue if configured correctly. Xmodem for RC2014 works by default without handshaking using console con: rather than more specific hardware access, I have used that on several flavours of rc2014 computer. I would expect the same version of xmodem to work on z80mbc2. Xmodem is expected to work to the same port that the serial terminal console is using (i.e. the one CON:)
Generic Kermit should work if the system bios supports IOBYTE (it does on rc2014) but I've never tried that on a one serial port system. It is possible that use of Kermit to con: would conflict with use on the same con: for the system console. If Z80MBC2 supported Xmodem and CPM BIOS IOBYTE then I would try Kermit to see how it behaves.
I believe Qterm makes too much detailed access to hw ports which are not virtualised in Z80MBC2 so Qterm cannot work. It may be possible that someone has made a more generic patch for Qterm, but again only worth considering when Xmodem is known to work.
It would really turn Z80MBC2 into an ace system if it supported Xmodem, currently that is blocking me from giving the system a higher star rating.
Michael Fong wrote 01/22/2019 at 07:43 point
vt100 card is a great addition.  If you're looking at doing another revision, I wonder if you'd consider some additional mounting holes at each corner of the card for horizontal mounting? Then you could mount it in a flat rectangular box.
Just4Fun wrote 01/22/2019 at 08:46 point
Hi, there are already two more holes for horizontal assembling... they aren't exactly on the corner, but a little more internal.
I'm "running" an other addition board, uCom (https://twitter.com/Just4Fun_J4Fun/status/1083675698412249089) that shares same dimension and holes position...
Michael Fong wrote 01/22/2019 at 11:31 point
Ooopppsss sorry didn't see them. Nice!  My friend and I really looking forward to building it.
Great work :-)
RWDEANE wrote 01/21/2019 at 21:48 point
I've just launched my Z80MBC2 with CPM3. I like it! I had a problem initially in getting the software into the atmega32 via serial or ISP. My serial didn't support DTR. Took me a while to figure out that I need to hold shift while starting upload in Arduino IDE via ISP, otherwise I just get another upload of MightyCore bootloader.
Now I'm looking for a version of XMODEM with generic CPM3 support of CON: so that I can upload and download files within CPM3 via the single serial connection. Does anyone know of an xmodem version that works for this?
Any chance of a Z80MBC3 design with a second serial port ?  :) And faster?
RWDEANE wrote 01/22/2019 at 08:08 point
I am told that the xmodem from the cpm section on foxhollow.ca (popular with RC2014) works unmodified on cpm3 but I cannot get it to work under  z80mbc2 with cpm3. Can anyone else get it to work? I've only tried so far under cpm3.
Just4Fun wrote 01/22/2019 at 08:48 point
Hmmm, I don't know... may be... it's too early to think about a  Z80-MBC3...
Frank N. Stein wrote 01/24/2019 at 13:59 point
First of all (@Fabio): MANY, MANY THANKS FOR THIS FANTASTIC PROJECT!
And then:
It looks like XMODEM needs a hardware flow control. (see "tera-term-serial-port.png" at Foxhollow) - ...and unfortunately this is not implemented in this Arduino! :-( In addition, RTS/CTS must be connected to the USB/RS232 converter and SJ2 must be shorted with a solderblob. )
I don't think we need a Z80-MBC3 for that...
An additional serial interface would be great! Would it be possible to use a SC16IS750 (or similar) on the I2C bus??
I LOVE MY LITTLE Z80-MBC2!!! :-)
Just4Fun wrote 01/25/2019 at 07:26 point
Thanks!
SC16IS750: Yes, but you need to modify accordingly the IOS FW and the OS (CP/M)...
RWDEANE wrote 02/12/2019 at 15:27 point
The right version of Xmodem does not require hardware handshaking, the version on foxhollow can work to con: and not require hardware handshaking. I use it on several flavours of rc2014 inc Bill Shen's ZZ80CF (see Retrobrew under Plasmo)
georgedb wrote 01/19/2019 at 11:19 point
Very cool, what a great project! Bought a PCB via an auction, now a scavenge hunt for the parts ;-)
I still got two (huge) 8" floppy disk drives, what would be needed to connect those (the 24V power supply has already been taken care of)?
A lot of Z80 info and other retro processors as well as some related projects can also be found on the website of Grant Searle. RC2014 is another website with interesting info on Z80 retro computing.
Just4Fun wrote 01/22/2019 at 08:50 point
There is no chance to connect a physical floppy disk, unless you design a proper controller and modify accordingly the IOS FW and the OS (CP/M)...
thumper109 wrote 01/19/2019 at 06:58 point
Just got mine working and I love it. Thanks for such a cool little Z80. Magic.
Just4Fun wrote 01/19/2019 at 08:30 point
Thanks so much! More has to come...  :)
Bartosz Makara wrote 01/01/2019 at 17:14 point
Hi, I have three questions:
1. I've copied the content of the SD-S220718-R191018-v1.zip archive to the MicroSD card. This system boots up and I was able to change CP/M 2.2 to QP/M 2.71. But how can I change to CP/M 3.0? I don't know which disk image to choose.
2. Is there any tool like CPMTools for Linux? I don't have a Windows system here.
3. The blue User-LED is not lightning up on my board at any time, even when I press the User-Button. Is this correct?
Thanks again for this project! :)
yeti wrote 01/02/2019 at 06:17 point
@2: http://www.moria.de/~michael/cpmtools/ ... look if your distribution already has it.
Bartosz Makara wrote 01/02/2019 at 11:35 point
Thank you! My question was really unnecessary. The official Linux Mint repository has the "cpmtools" included.
Just4Fun wrote 01/02/2019 at 08:43 point
@1: Enter into the "select boot mode..." menu, press 8 and then press any key (not ESC)  repeatedly until you select the wanted OS, then press CR to activate.
@3: Try USERLED.BAS example.
Bartosz Makara wrote 01/02/2019 at 11:42 point
@1: OK this was much easier than I've imagined. Thank you, this works! :D
@3: Although I've listed the disk image files and seen the USERLED.BAS I haven't tried it till now. I've started it and it tells me the LED is blinking but it isn't. I will solder another one on the board maybe it was broken before I've soldered it. Thanks again!
Just4Fun wrote 01/02/2019 at 11:52 point
@3: check the led polarity too...
frank maertin wrote 12/21/2018 at 20:47 point
Got  my 5  pcb's today. Does anybody needs one?
Shipping only to Germany. 1 Toshiba RAM, ATMEGA and Z80 are also avialable, if needed.
SupraJames wrote 11/25/2018 at 22:05 point
Just want to share something I’ve found tonight. I had an ESP8266 module in my collection and using esp-link (https://github.com/jeelabs/esp-link) my Z80-MBC2 is on my wireless network and I can play with it from anywhere using telnet - and even remotely reset the board and re flash the Arduino part via a web page. It’s beyond cool! Just connected the ESP8266 instead of the USB serial module.
villaromba wrote 11/26/2018 at 09:58 point
Interesting concept, had a read on jeelabs and thought I would give it a go. The ESP8266 is only a few dollars from Aliexpress as well - so well affordable !!!
Just4Fun wrote 11/25/2018 at 10:12 point
Thanks guys..!
BTW: Currently I'm "playing" with a new "thing":
https://www.retrobrewcomputers.org/forum/index.php?t=msg&th=223&goto=560555&#msg_5605
Stay tuned.... :)
John wrote 11/23/2018 at 22:15 point
Thank for a great project. Been wanting to run CP/M on a real Z80 now i have it :)
Regards
Jman
asorc wrote 11/23/2018 at 20:28 point
Hello,
I ordered 5 pcbs and I've received them today. I am looking at the layout guide, and I have a question about the legend which says 10 k 8. What does it mean? What's that? I've read something about SIP. But I do not know what's that. Could anyone help me? Thanks a lot  in advance.
villaromba wrote 11/23/2018 at 20:58 point
You'll find in the Bill of Materials (In Files section) the parts list.
The SIP used is 8 x 10k resistors in a Single Inline Package (SIP) with a common pin for all 8 resistors making 9 pins in total. They are also called a Resistor Array Network.
Jeff Davis wrote 11/24/2018 at 02:14 point
I made a google docs BOM with corrections and longer item descriptions: https://drive.google.com/open?id=145w-IAsDimTIEjg6kTirIJTWtZTU7UPEflaH5Kcza1Q
asorc wrote 11/24/2018 at 13:33 point
Thanks a lot. I've read about resistors array later on. I do not have much knowledge... Btw, I have around 1n5819 instead of 1n5817, and 2n3906 instead of 2n2907. Could I use them?
Just4Fun wrote 11/25/2018 at 10:06 point
Yes, you can do it for both the components. The 2N3906 must be in TO-92 package, so the pins are in the right place...
SupraJames wrote 11/23/2018 at 17:21 point
I am pleased to show my first proper Z80 assembler program. It's a memory tester, which might be useful in the homebrew world. It does bank switching so we can test almost all the 128k which the Z80-MBC2 has, except for the little area where the program runs!
Just paste the .hex into iLoad to give it a go, or look at the source.
Comments? https://github.com/SupraJames/z80-mbc2
villaromba wrote 11/23/2018 at 22:11 point
Nice one, just ran a quick mem test - perfect!! Will check out monitor late weekend ....
SupraJames wrote 11/13/2018 at 21:51 point
i noticed that the old MBC was using the serial port at 38400 baud but the new one is 9600 only. Is there a technical reason for that?
Jeff Davis wrote 11/14/2018 at 08:47 point
I changed the avr ios program's serial from 9600 to 38400, compiled and uploaded to the avr, and it seems to run just fine (played startrek), which makes sense since the serial port is handled by the avr cpu. 9600 just feels more retro I think since the terminal draws a lot faster at 38400.
nemfield wrote 11/11/2018 at 21:05 point
Hi. I have read through this (mostly) and it looks like fun.  I live in Ontario Canada and if anyone has a spare PCB I'd appreciate it. I can paypal you for the cost. Thank you.  Gabe (nemfield@gmail.com).
nemfield wrote 11/11/2018 at 22:33 point
OK. Replying to my own comment. I ordered 5 boards. I used China Post. I'm in Canada. when I get them I'll share them for postage costs to others near me. I advice you do NOT use DHL. Here in Canada they always add some silly brokerage fee and hold you hostage unless you pay it. They are a great service, but do not come clean on all charges.
Yann Guidon / YGDES wrote 11/11/2018 at 22:35 point
That's basically their business model...
Bartosz Makara wrote 11/12/2018 at 09:35 point
I'm living in Germany and when I'm ordering from outside the EU I'm always trying not to choose DHL because I know I have to pay some extra fees. It's terrible! If you order ar PCBway you can also choose E-Packet. I think this is a little bit faster than China Post and costs only a little bit more. And I've never had any problem with extra costs with this shipping way.
Bartosz Makara wrote 11/11/2018 at 13:59 point
Hello, I have two questions about the used parts where I am not completly sure about.
1. question: The "user LED" should be a 2.7V version or higher but what about the voltage of the other five LEDs? Since nobody else asked this here I'm pretty sure I've overseen some information or simply I'm too stupid. :D
2. question: The two tactile switches used in the schematics are per default closed and interrupt the ground line, right? Or do I have to use a reversed switch version? The more I'm trying to get it the less I'm sure about this.
villaromba wrote 11/11/2018 at 20:13 point
Q1: ther 5 LEDs aren't 'critical' but if you want to keep to the original design I've copied below from the BOM. (In FILES)
D1  LED-3MM  HALT Red
D11 LED-3MM SD Red
D2 LED-3MM  DMA White
D3 LED-3MM  IO_OP White
D4 LED-3MM  IOS Green
D5 LED-3MM  USER Blue
Q2: The 2 switches are normally open (standard tactile switch!) as per the schematic. Depress switch to operate.
Bartosz Makara wrote 11/12/2018 at 09:33 point
Oh great, thank you very much! :)
I knew I'm overlooking something!
Bartosz Makara wrote 11/07/2018 at 07:48 point
Does anybody know a good DIY project to build a serial terminal with a samll display which would work with this little Z80-machine? Probably something based on an Arduino Uno (I have a sapre one here ;). Unfortunately I'm not good in developing something like this for myself.
Mc John wrote 11/07/2018 at 08:13 point
This is a complete ASCII VT100 compatible video terminal in a single chip RS232/USB
http://geoffg.net/terminal.html
Bartosz Makara wrote 11/07/2018 at 12:09 point
Awesome! :) Thank you very much!
mustower wrote 11/03/2018 at 17:07 point
Hi, I am new to hackaday.io. This project ist really amazing. I wondering how I can get a PCB ? Any help/infos are apreciated.
Just4Fun wrote 11/03/2018 at 17:24 point
Thanks!. I've prepared an "easy link" to order a small lot (5 pcs min.) here: https://www.pcbway.com/project/shareproject/Z80_MBC2__4ICs_homemade_Z80_computer.html or you may ask if someone has a spare PCB... (my last spare PCB is now in Sweden...)
SupraJames wrote 11/03/2018 at 22:04 point
if you are in the UK I’d be happy to post you one of my PCBs which should be here in a couple of weeks
villaromba wrote 11/04/2018 at 16:06 point
I too have a spare PCB  you can have FOC  if you are in the UK !!!
