Z80-MBC2: a 4 ICs homebrew Z80 computer
Homemade 8MHz Z80 SBC, 128kB banked RAM, RTC, SD (HD emulation), Basic and Forth interpreters, CP/M 2.2 and 3, cross Assembler and C (SDCC)
The Z80-MBC2 is an easy to build Z80 SBC (Single Board Computer).It is the "evolution" of the Z80-MBC (https://hackaday.io/project/19000), with a SD as "disk emulator" and with a 128KB banked RAM for CP/M 3 (but it can run CP/M 2.2, QP/M 2.71, UCSD Pascal and Collapse OS too).
It has an optional on board 16x GPIO expander, and uses common cheap add-on modules for the SD and the RTC options. It has an "Arduino heart" using an Atmega32A as EEPROM and "universal" I/O emulator (so a "legacy" EPROM programmer is not needed).
It is a complete development "ecosystem", and using the iLoad boot mode it is possible cross-compile, load and execute on the target an Assembler or C program (using the SDCC compiler) with a single command (like in the Arduino IDE).
* * HARDWARE OVERVIEW * *
The needed ICs for the "base system" are:
  • Z80 CPU CMOS (Z84C00) 8Mhz or greater
  • Atmega32A
  • TC551001-70 (128kB RAM)
  • 74HC00
If you want the 16x GPIO expansion (GPE option) add a MCP23017 too.
The schematic and the BOM are attached in the Files section. The MCU Atmega32A is used as universal I/O subsystem, as Eeprom, and as reset and 4/8MHz clock generator for the Z80 CPU.
Inside the Atmega32A it is flashed an Arduino bootloader taken from here, and it is possible to use the Board Manager of the Arduino IDE to "import" it.
Flash the Arduino bootloader at first (with the method you prefer), next you can upload the IOS "sketch" (the I/O Subsystem that interacts with the Z80 bus and "virtualizes" the EEPROM and all the peripherals seen by the Z80 CPU) using Arduino IDE.
You can use the on board ICSP port J3 (also called ISP port) to write the bootloader, but remember to disconnect any other connector when using it. Also both SD and RTC modules (if present) must be removed from the board when the ICSP port is in use.
As clock source for the Z80 CPU it is used the 16MHz Atmega32A oscillator, so the "external 16MHZ osc." bootloader variant must be chosen when flashing the bootloader from the Arduino IDE!.
The 74HC00 is used as RS flipflop to stop the Z80 CPU during I/O operation, giving the needed time to the Atmega32A to interact with the Z80 bus, and as part of the MMU.
Note that only the CMOS version of the Z80 CPU can be used here. This because only CMOS version, under given condition that are respected in this schematic, has logical levels compatibles with Atmega32A and 74HC00.
NOTES ABOUT THE COMPONENTS:
You should use a  Z80 CMOS speed grade of at least 8MHz for full speed, but setting the clock speed at 4MHz you can use a 4MHz Z80 CMOS version too (or you can try to overclock it at 8MHz...). The 74HC00 can be substituted with a 74HCT00 if you already have one. The RAM chip TC551001-70 can be substituted with any suitable 128kB SRAM).
Please note that the USER led  * must * be blue or white (or pink... I've some pink leds that seems to have a Vf like blue one. May be I'll do a board with them...) just to be sure that V(forward) is >= 2.7V (otherwise the USER key may not work as expected).
The J4 connector (AUX_P) is not currently supported and is not populated by default.
The three solder jumpers (SJ1-3) on the bottom side are not currently supported and must  be left opened (as stated in the schematic).
THE SERIAL PORT:
The  SERIAL port (J2, see schematic) can be connected with a TTL-RS232 adapter, or with a serial-USB adapter.
I've used a serial-USB adapter that acts also as power source for the Z80-MBC, and has the DTR signal for the "autoreset" driven from the Arduino IDE. For a terminal that has a serial TTL port no adapter is needed.
Of course to upload a "sketch" from Arduino IDE you need to use a serial-USB adapter connected to the SERIAL port.
Note that the RTS and CTS pins of the SERIAL port are not currently supported and must be left not connected (as the NC pin!).
The 3V3 pin of the serial-USB adapter must be left disconnected.
You should use those Serial-USB adapters that have the DTR pin on the connector. It is suggested to have also the CTS/RTS signals available for future upgrades:
THE OPTIONAL RTC MODULE:
The RTC is a common module based on a DS3231  RTC  like this one:
This cheap modules have a trickle charging circuit that may cause the "explosion" of the battery if you use a standard CR2032 cell. More, it can damage also a rechargeable LIR2032 cell. For more information and how to fix it see here.
The RTC module has it's own pullup resistors on SDA and SCL. Because the value is 4k7 (the same value used inside the Z80-MBC2 board), the resulting value will be:
4k7 // 4k7 = 2k3
Because this value is fine there is no need to take away the pullup on the RTC module....
SD-S220718-R240620-v1.zip
The content of the microSD needed to run CP/M 2.2, CP/M 3.0, QP/M 2.71, UCSD Pascal and Collapse OS with IOS S220718-R240620. Adds Collapse OS.
Zip Archive - 3.69 MB - 06/25/2020 at 10:41
Download
S220718-R240620_IOS-Z80-MBC2.zip
The sketch for the IOS (with the needed libraries). Unzip into a folder and open the .ino file (with Arduino IDE). IOS must be uploaded into the Atmega32A flash. Adds support for Collapse OS.
Zip Archive - 37.34 kB - 06/25/2020 at 10:40
Download
S220718-R240620_IOS-Z80-MBC2.ino.with_bootloader_atmega32_16000000L.hex
The sketch for the IOS in executable format (.HEX) with the bootloader. This executable file is intended for use with a programmer as the Atmel Ice or AVRISPmkII or others (Fuse bits: High Byte 0xD6, Low Byte 0xAF, Lock Byte 0xCF)
x-hex - 55.76 kB - 06/25/2020 at 10:39
Download
STARTREKV2.BAS
The famous game Super Startrek kindly debugged by a RetroBrew Computer Forum user. Play with Caps-Lock activated! Now the animation works...
bas - 20.18 kB - 08/07/2018 at 16:32
Download
TREKINST.BAS
Instructions for STARTREKV2.BAS
bas - 6.80 kB - 08/04/2018 at 21:48
Download
View all 11 files
  • 1 × See the file "A040618 BOM v2.ods" in the FILES section.
  • Collapse OS on the Z80-MBC2!
    Just4Fun06/25/2020 at 10:54 0 comments
    Collapse OS is now supported on the Z80-MBC2:
    Update both the IOS firmware and the SD image.
    For more info the Collapse OS site is here.
  • UCSD Pascal for the Z80-MBC2!
    Just4Fun09/01/2019 at 15:45 3 comments
    Thanks to Michel Bernard (a member of the Z80-MBC2 User Group on FB) who did the porting, now UCSD Pascal is running on the Z80-MBC2!
    Michel Bernard originally used the trick to create a custom autoboot.bin file to be used with the "Autoboot" boot selection to load the OS.
    Because this porting is so cool, I've done a new IOS version and a new SD image to support UCSD Pascal in the same way as the others previous OS, adding a new "Disk Set" selection:
    To run UCSD Pascal you just need to update the new IOS and the new SD image (in the Files section) and select it from the usual "Select boot mode or system parameter" menu:
    In the new SD image there are two volumes (disks) SYS1: and SYS2:
    Here the execution of an example (SINE.CODE) already compiled on the SYS2: disk:
    In the folder "UCSD Pascal" inside the SD there are the original files and sources provided by Michel Bernard.
    A lot of documentation and books about UCSD Pascal can be found here.
  • uCom is out!
    Just4Fun05/29/2019 at 09:20 0 comments
    I've done a separate "project page" for uCom (RS232 add-on card for the Z80-MBC2) here.
    The uCom board, as the uTerm VT100 board, has a "transparent" USB-serial adapter connector, so you can upload firmware to the Z80-MBC2 (using Arduino IDE) or load an Intel-Hex file (with iLoad) or use XMODEM to exchange files with a PC (running a terminal emulator that supports XMODEM file transfer) while the uCom is in use.
    Both the "mixed" power supply scenarios (USB-serial adapter not powered from USB but Z80-MBC2 powered and vice-versa) are managed by the HW, so you don't need to worry about it.
    uCorm can be mounted horizontally or vertically to the Z80-MBC2.
    The 3D printed custom angled brackets .STL files are the same of the uTerm.
    Here connected with a "vintage" RS232 terminal (Ampex 210 relabeled Kyber):
  • FuzixOS preview: Unix for Z80!...
    Just4Fun05/21/2019 at 17:14 2 comments
    First test with FuzixOS on the Z80-MBC2 (many many thanks to Alan Cox...)!:
    Stay tuned...
  • uTerm is out!
    Just4Fun05/14/2019 at 07:40 0 comments
    I've done a separate "project page" for uTerm here.
    uTerm can be mounted horizontally or vertically to the Z80-MBC2.
    All the details including the 3D printed custom angled brackets .STL files are there.
    uTerm is a VT100 terminal with VGA out and  PS/2 keyboard with a power supply (for the Z80-MBC2 too). It has a "transparent" USB-TTL adapter connector, so you can upload firmware or load an Intel-Hex file (with iLoad) while the card is inserted. Both the "mixed" power supply scenarios (USB-TTL adapter not powered from USB but Z80-MBC2 powered and vice-versa) are managed. The video terminal is based on the ChibiTerm (https://hw-by-design.blogspot.com/2018/07/low-cost-vga-terminal-module-project.html).
  • uCom preview: a RS232 adapter for the Z80-MBC2...
    Just4Fun04/05/2019 at 17:00 0 comments
    Currently working on a RS232 add-on card for the Z80-MBC2.
    As the uTerm board, it has a power supply for the Z80-MBC2 and a "transparent" USB-TTL adapter connector, so you can upload firmware or load an Intel-Hex file (with iLoad) while the card is inserted. Both the "mixed" power supply scenarios (USB-TTL adapter not powered from USB but Z80-MBC2 powered and vice-versa) are managed.
    Here connected to an Ampex 210 terminal (sold and relabeled by Kyber):
    Stay tuned...
  • New IOS for XMODEM support
    Just4Fun03/10/2019 at 10:54 5 comments
    Because some people requested to use the XMODEM protocol to exchange files through the serial port, I've added the support for this protocol into CP/M 2.2 and CP/M 3 (banked only).
    XMODEM needs a full 8 bit binary data transfer, and this is not possible with the CON port (the CP/M port used for the console) with a "legacy" CP/M system installation because the CP/M Alteration Guide says to strip the eight parity bit when reading a byte from the console input.
    More, because the Z80-MBC2 uses a virtual serial port without handshaking there is also a timing problem when dealing with the 128 bytes packets used by the XMODEM protocol.
    So the support to the XMODEM protocol has requested changes in the IOS and  in the CP/M BIOS, and also in the Arduino core to extend the serial input buffer.
    Please note that with the new IOS the default speed of the serial port is now 115200 bps.
    To have the XMODEM support active, before the update of the new IOS firmware and the new SD image (see in the Files section),  you have to manually create a new "board variant" in the Arduino IDE and then change the default Rx input buffer size to 128 bytes in the "core" of this new variant.
    If you aren't interested into the XMODEM support, you can simply update the IOS and the new SD image as usual  without the need to create the new board variant. In this case the XMODEM will not work in the receive direction, but only in the send direction (from the Z80-MBC2 to a PC with a terminal emulator).
    HOW MANUALLY CREATE A NEW BOARD VARIANT (LINUX)
    In the following I'll assume an Arduino IDE 1.8.5 installation on a linux host and the MightyCore ver. 1.0.8. Anyway I've tried to make the procedure enough general to be used for other versions too.
    The first thing is find the directory where the MightyCore is located.
    If you have installed Arduino IDE 1.8.5 and then installed the MighyCore with the Board Manager with the usual .json "pointer", the MightyCore is located in the "~/.arduino15/packages/MightyCore" directory:
    Now you must locate the "~/.arduino15/packages/MightyCore/hardware/avr/1.0.8/cores" directory (note that the "1.0.8" part of the directory name depends on the MightyCore version, and so can be a different number if you have a different version of the MighyCore):
    ... Read more »
  • uTerm preview: a VT100 terminal for the Z80-MBC2...
    Just4Fun12/28/2018 at 10:16 2 comments
    Currently working on a VT100 terminal with VGA out and  PS/2 keyboard with a power supply (for the Z80-MBC2 too). It has a "transparent" USB-TTL adapter connector, so you can upload firmware or load an Intel-Hex file (with iLoad) while the card is inserted. Both the "mixed" power supply scenarios (USB-TTL adapter not powered from USB but Z80-MBC2 powered and vice-versa) are managed. The video terminal is based on the ChibiTerm (https://hw-by-design.blogspot.com/2018/07/low-cost-vga-terminal-module-project.html).
    Stay tuned...
    Working on a new revision (A071218-R250119):
    Waiting the new PCB, I'm playing with the current PCB "patched" to perform like the new one.
    Here a session with Wordstar 4 configured to use all the 30 rows of uTerm:
    In the photo you can see that also the serial-USB adapter is attached to the uTerm using the "transparent" port. This allows to use two keyboards and two monitors in the "same" time (one keyb and monitor attached directly to the uTerm, and another keyb and monitor of the terminal emulator on a PC connected with the serial-USB). This allows also to use XMODEM (e.g. between the Z80-MBC2 and a PC) or to flash the Atmega firmware with the uTerm connected.
    Or you can use the monitor attached to the uTerm and the keyboard of the terminal emulator on a PC. This is exactly the "configuration" I used in the photo to make the test (as you can see, there isn't any keyb attached to the uTerm).
    Catchum demo with uTerm (a sort of Pacman...). Leaving the game alone, after a while the "demo mode" starts:
    Here last version assembled horizontally with the Z80-MBC2:
    Currently making custom 3D printed mounting brackets for a solid vertical assembling:
  • Overclocking the Z80-MBC2...
    Just4Fun11/02/2018 at 09:51 4 comments
    Because the Mighty Core gives the chance to choice a 20MHz bootloader, I've decided to try to "overclock" the Atmega32A using a 20MHz quartz:
    You don't need others HW changes, just use a 20MHz quartz instead of a 16MHz one. The Z80 clock speed will be at 10MHz.
    You have to select the "20MHz external" option in the "Toos" menu of Arduino IDE before flashing the 20MHz bootloader:
    Of course you need to load the sketch again (using the "20MHz external" option). IOS will display the new clock speed:
    Remember that using a 20MHz quartz you are out of the Atmega32a specifications (the Atmega32a is rated at 16MHz max.), so you are in a "grey area" where things "may works"...
  • CP/M 3 up and running on the Z80-MBC2!
    Just4Fun10/11/2018 at 06:58 0 comments
    With the latest IOS revision and the corresponding new SD image (see the Files section) there is one more option: the CP/M 3.0!
    With CP/M 3.0 it is possible use the 128KB banked RAM to have a wider user area (TPA) for programs and a more "evoluted" OS.
    TWO VERSIONS
    Just as example of how it is easy with CP/M 3.0 manage multiple configurations, I've done also a "non-banked" 64KB version. The switch from one version to the other can be done simply running a batch from the console itself.
    I've prepared two simple batch files to do that. From drive A: the command:
    submit sys64
    will set the 64KB "non-banked" version and then reboot the system.
    To activate again the 128KB "banked" version give the command (from drive A:):
    submit sys128
    NEW DISKDEFS FILE
    To use cpmtools or cpmtoolsGUI with the virtual disks of the CP/M 3.0 environment, you must update the DISKDEFS definition file (from the SD in the folder <SD>/cpmtools/) and use the "z80mbc2-cpm3" entry for all the 16 disks:
    Please note that for the CP/M 3.0 environment all the 16 virtual disks have the same structure and for this there is only one entry for all the CP/M 3.0 virtual disks.
    AUTOEXEC
    The AUTOEXEC switch for CP/M 3.0 works in a different way from the CP/M 2.2 and QP/M 2.71 implementations.
    Now there is a custom utility (AUTOEXEC) that checks the IOS flag and sets the exit code accordingly (using the BDOS function 108). This allow to use the CP/M 3.0 batch conditional execution (see the CP/M 3 Programmer Guide par. 1.6.3) to run any wanted command or program based on the status of the IOS AUTOEXEC flag.
    I've prepared an example using an other CP/M 3.0 feature, the "PROFILE.SUB" batch that is automatically executed at cold boot (if it exists). To activate it (in the drive A:) rename the file PROFILE.SU as PROFILE.SUB with the command:
    ren profile.sub=profile.su
    Now you can see how it works setting the AUTOEXEC flag on or off with the IOS "Select boot mode or system parameters" menu.
View all 13 project logs
makegeneve wrote 04/17/2019 at 18:06 point
I just assembled my kit from Mc John https://shop.mcjohn.it/en/diy-kit/22-32-kit-z80-mbc2.html.  Worked first time.  Excellent work.  Thank you everyone!  Now I'm battling cpm tools on MacOS Mojave to try to transfer a few things across.  It feels very early 80s. :-)
Frank N. Stein wrote 04/04/2019 at 19:29 point
Hi,
your "LADDER" is really nice! - I found only V1.10 on the web and have problems to configure it. :-(
Where did you get your V1.30? - and how did you configure it??? Did you defined "Digital VT100" manually?
Just4Fun wrote 04/05/2019 at 10:44 point
Here: http://web1.foxhollow.ca/Foxhollow-cpm.zip
Ladder 1.30 wortks "out the box"...
Frank N. Stein wrote 04/05/2019 at 19:36 point
Thanks for your link! - It is really called "ladder" in this ZIP-file? I can't find it... :-(
villaromba wrote 04/06/2019 at 15:16 point
Ladder, along with many other games is in the packages folder ( games.pkg). You need to use the instructions at https://web1.foxhollow.ca/cpm/ if you haven't used depkg before.
Just4Fun wrote 04/08/2019 at 09:26 point
Exactly... :)
Frank N. Stein wrote 04/10/2019 at 17:27 point
Thanks! I didn't know DEPKG yet...
Is there actually a way to open these packages under Windows to look inside?
villaromba wrote 04/10/2019 at 20:35 point
Not so sure you can under windows but it's not difficult in CP/M :-
Although you can use xmodem to transfer a single file to your CPM machine, it is
a time consuming task to transfer software collections with large numbers of files.
Step 1: Using the "Binary to CPM Package" utility, you can combine many files to a single file called a package.  (games already packaged)
Step 2: Use xmodem to transfer the package & depkg.com into CPM.
Step 3: Use depkg.com to extract the original files.
Example:  depkg games.pkg
Frank N. Stein wrote 04/14/2019 at 16:33 point
@villaromba: Thanks for your detailed explanation - that works!
Frank N. Stein wrote 03/12/2019 at 08:24 point
@Fabio:
Many, many thanks for the X-Modem implementation!!! Can you maybe post the matching Arduino HEX file? - that would surely be easier than rebuilding the whole Arduino IDE...
THANK YOU VERY, VERY MUCH FOR YOUR EFFORT!!!
Just4Fun wrote 03/12/2019 at 14:21 point
Ok, I'll upload the .hex executable (version with the bootloader included) this evening...
Just4Fun wrote 03/12/2019 at 16:50 point
Done!
Frank N. Stein wrote 03/12/2019 at 20:19 point
FANTASTIC! Xmodem works like a charm! Really super! This is a great enhancement!!! Thank you very much!
UPDATE:
I have problems with "GPELED.BAS", "RTC.BAS" and "USERLED.BAS" - it seems that all programs don't work anymore?!?
Just4Fun wrote 03/13/2019 at 18:05 point
Just tested now... They works now only with QP/M 2.71 that I left untouched and uses the old serial I/O mode.... hmmm...
I think to have an idea of the problem, and it should affect only "slow" interpreted programs (not the compiled one...)...
Further analysis is required...
Just4Fun wrote 03/14/2019 at 07:35 point
I think to have found the cause... now thinking to a possible solution...
Frank N. Stein wrote 03/25/2019 at 12:10 point
Your "SD-S220718-R260119-v2.zip" works very well (I tested Xmodem, "RTC.BAS", "USERLED.BAS" and my own programs on CP/M 3 - it seems that everything is now working properly)! THANKS!
asorc wrote 03/04/2019 at 18:52 point
First time It started I selected basic... Then, It appeared memory top? message, and since then, when I press reset, It says cold or warm start? If I select cold, It becomes crazy, if I select warm, It says ok. I am confused.
Just4Fun wrote 03/04/2019 at 19:23 point
You must press "Return key" at "Memory top?" and then select cold...
asorc wrote 03/04/2019 at 15:44 point
Is It needed a vt 100 terminal to run the z80-mbc2? Or any serial monitor works the same?
Just4Fun wrote 03/04/2019 at 15:52 point
You can use any serial monitor. Some programs (video editors...) require a defined kind of monitor to work properly (generally they have a sort of config). Try and see...
asorc wrote 03/04/2019 at 18:45 point
Ok. Well... Something happened. I changed the baud option of the serial monitor of arduino ide, and It works for 9600 baud. Now, what's the different between cold and warm start? And What does "memory top?" means?
georgedb wrote 02/15/2019 at 11:07 point
Sorry, one more: can a 1N5819 be used instead of the 1N5817? When I look here [https://www.vishay.com/docs/88525/1n5817.pdf], I see slightly different parameters, and possibly the most important, slightly different forward voltages...
Just4Fun wrote 02/15/2019 at 12:20 point
I think yes...
georgedb wrote 02/15/2019 at 14:08 point
Will give it a try once I have received the components I don't have, and will report here.
georgedb wrote 02/15/2019 at 08:29 point
What a great project! I looked at the BOM, and there are quite a few components I already have. I tried to find (European) replacements for Q1/2 (2N2907), but failed. I guess this transistor is not critical in terms of parameters? Can any PNP transistor with the same pinning be used in this place, or are there specific parameters that play a role? And/or, does anybody know a good (European) replacement?
What I got in my parts bin: BC213, BC516, BC557, BC558, BC560C, ZTX213, ZTX550, ZTXC551
Just4Fun wrote 02/15/2019 at 08:46 point
Hi, you can use any "generic" PNP transistor. BC557 / BC558 will do the job...
-> NOTE: Check on the datasheet if they have the same pins placement!!! <-
georgedb wrote 02/15/2019 at 10:58 point
Perfect, thnx for your help! Always better to use what I already have ;-)
Linker3000 wrote 02/17/2019 at 22:34 point
I know you may not have them, but 2N3906 is a good replacement, has the same pinout and is easier to source; that's what I am using because I had some in my stock.
Peabody1929 wrote 02/12/2019 at 21:40 point
I built a second system.  It is up and running just fine with a HM628128ALP-7 SRAM as well.  To test the board I booted CP/M and ran MBASIC.  I opened the "Examples with Basic" on my PC, copied the USER LED BLINK example and pasted it into Tera Term at the MBASIC prompt.  This is a very easy way to get a program into the system.  Then I did SAVE "BLINK",A to put the app into the SD Card disk file.  RUN executed the app and blinked the LED.  All in all, it took about a minute the run the app to test the LED.  Very nice!
Linker3000 wrote 02/09/2019 at 13:55 point
Just FYI, the board works fine with HM628128ALP-7 SRAM and should also be OK with AS6C1008-55PCN.
asorc wrote 02/07/2019 at 16:15 point
Hello,
Let's see if some of you have had the same or a similar issue. So, I do not have a way to upload sketches in windows 7, but I do have a raspberry pi model b. Therefore, I use it to upload hex files to a blank atmega32a. I compile the sketches with the mightycore library, wire, etc. in windows 7, using arduino ide, and then take the hex files to burn them with the raspberry pi to the atmega32a using six wires and the GPIO connections of the raspberry pi. The result I get when I set up the computer to power it on and start the serial monitor of arduino ide, is that the IOS led starts to blink, but at a quite slow rate, and when I open the terminal, nothing happens. Has any of you had a similar problem? I uploaded a hex file that has the bootloader included according with its name, but I do not know if everything has gone really well, apparently avrdude tells me so, or if any IC is damaged. Thanks to all, in advance.
jmarik wrote 02/07/2019 at 21:16 point
Are the fuses set correctly? I used CF, D9.
asorc wrote 02/07/2019 at 22:24 point
I don't remember which ones come in the configuration of avrdude, because I have not touched anything else appart from the GPIO pins I use. I will have a look at it.
Linker3000 wrote 02/09/2019 at 14:09 point
Confirming the fuses (CF D9).
I ended up using a TL866 programmer because I could not get ICSP/USBASP to work. When I went back to basics later, I found that one of the wires in the ribbon cable I was using between the USBASP and the board header was open circuit! I only discovered this later when I could not get serial comms to work using the same cable! It's always the 'little things'!
asorc wrote 02/10/2019 at 01:01 point
Are these fuses the high and the low respectively? What about the lock byte?
I see there are different settings. I have seen the boards.txt of mightycore library, but It is not entirely clear to me which fuses It burns.
Frank N. Stein wrote 02/08/2019 at 09:00 point
I used "optiboot_flash_atmega32_UART0_115200_16000000L.hex" with
High Byte 0xD6
Low  Byte 0xAF
Lock Byte 0xCF
and it works very well...
asorc wrote 02/08/2019 at 12:48 point
Thanks for showing me where the problem is mostramos likely to be. I am checking the avrdude.conf file, in the m32 section, and I see some subsections memory lfuse, memory hfuse and memory lock, and below, without a write option, memory signature, memory calibration.
Definitely I have to get more knowledge. I guess these are some default values I can change there or externally, without modifying this. I have seen ways to do It with avrdude. I will have a look at it.
Thanks, any help is very very welcome.
Frank N. Stein wrote 02/06/2019 at 13:27 point
Hi, has anyone managed to send files with Kermit, Xmodem, Qterm or similar via the console interface? I have tried different versions of Kermit (with Terraterm on the PC side) that should have worked - unfortunately without success...
Z80-MBC2 does not support hardware handshaking, but Kermit should also work without it... :-(
Any help is appreciated!
RWDEANE wrote 02/12/2019 at 15:22 point
Currently there is  probably a bug in the z80mbc2 serial handling. An earlier message states that xmodem needs hw handshaking but this is untrue if configured correctly. Xmodem for RC2014 works by default without handshaking using console con: rather than more specific hardware access, I have used that on several flavours of rc2014 computer. I would expect the same version of xmodem to work on z80mbc2. Xmodem is expected to work to the same port that the serial terminal console is using (i.e. the one CON:)
Generic Kermit should work if the system bios supports IOBYTE (it does on rc2014) but I've never tried that on a one serial port system. It is possible that use of Kermit to con: would conflict with use on the same con: for the system console. If Z80MBC2 supported Xmodem and CPM BIOS IOBYTE then I would try Kermit to see how it behaves.
I believe Qterm makes too much detailed access to hw ports which are not virtualised in Z80MBC2 so Qterm cannot work. It may be possible that someone has made a more generic patch for Qterm, but again only worth considering when Xmodem is known to work.
It would really turn Z80MBC2 into an ace system if it supported Xmodem, currently that is blocking me from giving the system a higher star rating.
Michael Fong wrote 01/22/2019 at 07:43 point
vt100 card is a great addition.  If you're looking at doing another revision, I wonder if you'd consider some additional mounting holes at each corner of the card for horizontal mounting? Then you could mount it in a flat rectangular box.
Just4Fun wrote 01/22/2019 at 08:46 point
Hi, there are already two more holes for horizontal assembling... they aren't exactly on the corner, but a little more internal.
I'm "running" an other addition board, uCom (https://twitter.com/Just4Fun_J4Fun/status/1083675698412249089) that shares same dimension and holes position...
Michael Fong wrote 01/22/2019 at 11:31 point
Ooopppsss sorry didn't see them. Nice!  My friend and I really looking forward to building it.
Great work :-)
RWDEANE wrote 01/21/2019 at 21:48 point
I've just launched my Z80MBC2 with CPM3. I like it! I had a problem initially in getting the software into the atmega32 via serial or ISP. My serial didn't support DTR. Took me a while to figure out that I need to hold shift while starting upload in Arduino IDE via ISP, otherwise I just get another upload of MightyCore bootloader.
Now I'm looking for a version of XMODEM with generic CPM3 support of CON: so that I can upload and download files within CPM3 via the single serial connection. Does anyone know of an xmodem version that works for this?
Any chance of a Z80MBC3 design with a second serial port ?  :) And faster?
RWDEANE wrote 01/22/2019 at 08:08 point
I am told that the xmodem from the cpm section on foxhollow.ca (popular with RC2014) works unmodified on cpm3 but I cannot get it to work under  z80mbc2 with cpm3. Can anyone else get it to work? I've only tried so far under cpm3.
Just4Fun wrote 01/22/2019 at 08:48 point
Hmmm, I don't know... may be... it's too early to think about a  Z80-MBC3...
Frank N. Stein wrote 01/24/2019 at 13:59 point
First of all (@Fabio): MANY, MANY THANKS FOR THIS FANTASTIC PROJECT!
And then:
It looks like XMODEM needs a hardware flow control. (see "tera-term-serial-port.png" at Foxhollow) - ...and unfortunately this is not implemented in this Arduino! :-( In addition, RTS/CTS must be connected to the USB/RS232 converter and SJ2 must be shorted with a solderblob. )
I don't think we need a Z80-MBC3 for that...
An additional serial interface would be great! Would it be possible to use a SC16IS750 (or similar) on the I2C bus??
I LOVE MY LITTLE Z80-MBC2!!! :-)
Just4Fun wrote 01/25/2019 at 07:26 point
Thanks!
SC16IS750: Yes, but you need to modify accordingly the IOS FW and the OS (CP/M)...
RWDEANE wrote 02/12/2019 at 15:27 point
The right version of Xmodem does not require hardware handshaking, the version on foxhollow can work to con: and not require hardware handshaking. I use it on several flavours of rc2014 inc Bill Shen's ZZ80CF (see Retrobrew under Plasmo)
georgedb wrote 01/19/2019 at 11:19 point
Very cool, what a great project! Bought a PCB via an auction, now a scavenge hunt for the parts ;-)
I still got two (huge) 8" floppy disk drives, what would be needed to connect those (the 24V power supply has already been taken care of)?
A lot of Z80 info and other retro processors as well as some related projects can also be found on the website of Grant Searle. RC2014 is another website with interesting info on Z80 retro computing.
Just4Fun wrote 01/22/2019 at 08:50 point
There is no chance to connect a physical floppy disk, unless you design a proper controller and modify accordingly the IOS FW and the OS (CP/M)...
thumper109 wrote 01/19/2019 at 06:58 point
Just got mine working and I love it. Thanks for such a cool little Z80. Magic.
Just4Fun wrote 01/19/2019 at 08:30 point
Thanks so much! More has to come...  :)
Bartosz Makara wrote 01/01/2019 at 17:14 point
Hi, I have three questions:
1. I've copied the content of the SD-S220718-R191018-v1.zip archive to the MicroSD card. This system boots up and I was able to change CP/M 2.2 to QP/M 2.71. But how can I change to CP/M 3.0? I don't know which disk image to choose.
2. Is there any tool like CPMTools for Linux? I don't have a Windows system here.
3. The blue User-LED is not lightning up on my board at any time, even when I press the User-Button. Is this correct?
Thanks again for this project! :)
yeti wrote 01/02/2019 at 06:17 point
@2: http://www.moria.de/~michael/cpmtools/ ... look if your distribution already has it.
Bartosz Makara wrote 01/02/2019 at 11:35 point
Thank you! My question was really unnecessary. The official Linux Mint repository has the "cpmtools" included.
Just4Fun wrote 01/02/2019 at 08:43 point
@1: Enter into the "select boot mode..." menu, press 8 and then press any key (not ESC)  repeatedly until you select the wanted OS, then press CR to activate.
@3: Try USERLED.BAS example.
Bartosz Makara wrote 01/02/2019 at 11:42 point
@1: OK this was much easier than I've imagined. Thank you, this works! :D
@3: Although I've listed the disk image files and seen the USERLED.BAS I haven't tried it till now. I've started it and it tells me the LED is blinking but it isn't. I will solder another one on the board maybe it was broken before I've soldered it. Thanks again!
Just4Fun wrote 01/02/2019 at 11:52 point
@3: check the led polarity too...
frank maertin wrote 12/21/2018 at 20:47 point
Got  my 5  pcb's today. Does anybody needs one?
Shipping only to Germany. 1 Toshiba RAM, ATMEGA and Z80 are also avialable, if needed.
SupraJames wrote 11/25/2018 at 22:05 point
Just want to share something I’ve found tonight. I had an ESP8266 module in my collection and using esp-link (https://github.com/jeelabs/esp-link) my Z80-MBC2 is on my wireless network and I can play with it from anywhere using telnet - and even remotely reset the board and re flash the Arduino part via a web page. It’s beyond cool! Just connected the ESP8266 instead of the USB serial module.
villaromba wrote 11/26/2018 at 09:58 point
Interesting concept, had a read on jeelabs and thought I would give it a go. The ESP8266 is only a few dollars from Aliexpress as well - so well affordable !!!
citizen38 wrote 10/27/2019 at 16:43 point
Hi James, how are you managing the remote reset function? I'm using esp-link for serial comms already. Is it a DTR function?
Just4Fun wrote 11/25/2018 at 10:12 point
Thanks guys..!
BTW: Currently I'm "playing" with a new "thing":
https://www.retrobrewcomputers.org/forum/index.php?t=msg&th=223&goto=560555&#msg_5605
Stay tuned.... :)
John wrote 11/23/2018 at 22:15 point
Thank for a great project. Been wanting to run CP/M on a real Z80 now i have it :)
Regards
Jman
