Z80-MBC2: a 4 ICs homebrew Z80 computer
Homemade 8MHz Z80 SBC, 128kB banked RAM, RTC, SD (HD emulation), Basic and Forth interpreters, CP/M 2.2 and 3, cross Assembler and C (SDCC)
The Z80-MBC2 is an easy to build Z80 SBC (Single Board Computer).It is the "evolution" of the Z80-MBC (https://hackaday.io/project/19000), with a SD as "disk emulator" and with a 128KB banked RAM for CP/M 3 (but it can run CP/M 2.2, QP/M 2.71, UCSD Pascal and Collapse OS too).
It has an optional on board 16x GPIO expander, and uses common cheap add-on modules for the SD and the RTC options. It has an "Arduino heart" using an Atmega32A as EEPROM and "universal" I/O emulator (so a "legacy" EPROM programmer is not needed).
It is a complete development "ecosystem", and using the iLoad boot mode it is possible cross-compile, load and execute on the target an Assembler or C program (using the SDCC compiler) with a single command (like in the Arduino IDE).
* * HARDWARE OVERVIEW * *
The needed ICs for the "base system" are:
  • Z80 CPU CMOS (Z84C00) 8Mhz or greater
  • Atmega32A
  • TC551001-70 (128kB RAM)
  • 74HC00
If you want the 16x GPIO expansion (GPE option) add a MCP23017 too.
The schematic and the BOM are attached in the Files section. The MCU Atmega32A is used as universal I/O subsystem, as Eeprom, and as reset and 4/8MHz clock generator for the Z80 CPU.
Inside the Atmega32A it is flashed an Arduino bootloader taken from here, and it is possible to use the Board Manager of the Arduino IDE to "import" it.
Flash the Arduino bootloader at first (with the method you prefer), next you can upload the IOS "sketch" (the I/O Subsystem that interacts with the Z80 bus and "virtualizes" the EEPROM and all the peripherals seen by the Z80 CPU) using Arduino IDE.
You can use the on board ICSP port J3 (also called ISP port) to write the bootloader, but remember to disconnect any other connector when using it. Also both SD and RTC modules (if present) must be removed from the board when the ICSP port is in use.
As clock source for the Z80 CPU it is used the 16MHz Atmega32A oscillator, so the "external 16MHZ osc." bootloader variant must be chosen when flashing the bootloader from the Arduino IDE!.
The 74HC00 is used as RS flipflop to stop the Z80 CPU during I/O operation, giving the needed time to the Atmega32A to interact with the Z80 bus, and as part of the MMU.
Note that only the CMOS version of the Z80 CPU can be used here. This because only CMOS version, under given condition that are respected in this schematic, has logical levels compatibles with Atmega32A and 74HC00.
NOTES ABOUT THE COMPONENTS:
You should use a  Z80 CMOS speed grade of at least 8MHz for full speed, but setting the clock speed at 4MHz you can use a 4MHz Z80 CMOS version too (or you can try to overclock it at 8MHz...). The 74HC00 can be substituted with a 74HCT00 if you already have one. The RAM chip TC551001-70 can be substituted with any suitable 128kB SRAM).
Please note that the USER led  * must * be blue or white (or pink... I've some pink leds that seems to have a Vf like blue one. May be I'll do a board with them...) just to be sure that V(forward) is >= 2.7V (otherwise the USER key may not work as expected).
The J4 connector (AUX_P) is not currently supported and is not populated by default.
The three solder jumpers (SJ1-3) on the bottom side are not currently supported and must  be left opened (as stated in the schematic).
THE SERIAL PORT:
The  SERIAL port (J2, see schematic) can be connected with a TTL-RS232 adapter, or with a serial-USB adapter.
I've used a serial-USB adapter that acts also as power source for the Z80-MBC, and has the DTR signal for the "autoreset" driven from the Arduino IDE. For a terminal that has a serial TTL port no adapter is needed.
Of course to upload a "sketch" from Arduino IDE you need to use a serial-USB adapter connected to the SERIAL port.
Note that the RTS and CTS pins of the SERIAL port are not currently supported and must be left not connected (as the NC pin!).
The 3V3 pin of the serial-USB adapter must be left disconnected.
You should use those Serial-USB adapters that have the DTR pin on the connector. It is suggested to have also the CTS/RTS signals available for future upgrades:
THE OPTIONAL RTC MODULE:
The RTC is a common module based on a DS3231  RTC  like this one:
This cheap modules have a trickle charging circuit that may cause the "explosion" of the battery if you use a standard CR2032 cell. More, it can damage also a rechargeable LIR2032 cell. For more information and how to fix it see here.
The RTC module has it's own pullup resistors on SDA and SCL. Because the value is 4k7 (the same value used inside the Z80-MBC2 board), the resulting value will be:
4k7 // 4k7 = 2k3
Because this value is fine there is no need to take away the pullup on the RTC module....
SD-S220718-R240620-v1.zip
The content of the microSD needed to run CP/M 2.2, CP/M 3.0, QP/M 2.71, UCSD Pascal and Collapse OS with IOS S220718-R240620. Adds Collapse OS.
Zip Archive - 3.69 MB - 06/25/2020 at 10:41
Download
S220718-R240620_IOS-Z80-MBC2.zip
The sketch for the IOS (with the needed libraries). Unzip into a folder and open the .ino file (with Arduino IDE). IOS must be uploaded into the Atmega32A flash. Adds support for Collapse OS.
Zip Archive - 37.34 kB - 06/25/2020 at 10:40
Download
S220718-R240620_IOS-Z80-MBC2.ino.with_bootloader_atmega32_16000000L.hex
The sketch for the IOS in executable format (.HEX) with the bootloader. This executable file is intended for use with a programmer as the Atmel Ice or AVRISPmkII or others (Fuse bits: High Byte 0xD6, Low Byte 0xAF, Lock Byte 0xCF)
x-hex - 55.76 kB - 06/25/2020 at 10:39
Download
STARTREKV2.BAS
The famous game Super Startrek kindly debugged by a RetroBrew Computer Forum user. Play with Caps-Lock activated! Now the animation works...
bas - 20.18 kB - 08/07/2018 at 16:32
Download
TREKINST.BAS
Instructions for STARTREKV2.BAS
bas - 6.80 kB - 08/04/2018 at 21:48
Download
View all 11 files
  • 1 × See the file "A040618 BOM v2.ods" in the FILES section.
  • Collapse OS on the Z80-MBC2!
    Just4Fun06/25/2020 at 10:54 0 comments
    Collapse OS is now supported on the Z80-MBC2:
    Update both the IOS firmware and the SD image.
    For more info the Collapse OS site is here.
  • UCSD Pascal for the Z80-MBC2!
    Just4Fun09/01/2019 at 15:45 3 comments
    Thanks to Michel Bernard (a member of the Z80-MBC2 User Group on FB) who did the porting, now UCSD Pascal is running on the Z80-MBC2!
    Michel Bernard originally used the trick to create a custom autoboot.bin file to be used with the "Autoboot" boot selection to load the OS.
    Because this porting is so cool, I've done a new IOS version and a new SD image to support UCSD Pascal in the same way as the others previous OS, adding a new "Disk Set" selection:
    To run UCSD Pascal you just need to update the new IOS and the new SD image (in the Files section) and select it from the usual "Select boot mode or system parameter" menu:
    In the new SD image there are two volumes (disks) SYS1: and SYS2:
    Here the execution of an example (SINE.CODE) already compiled on the SYS2: disk:
    In the folder "UCSD Pascal" inside the SD there are the original files and sources provided by Michel Bernard.
    A lot of documentation and books about UCSD Pascal can be found here.
  • uCom is out!
    Just4Fun05/29/2019 at 09:20 0 comments
    I've done a separate "project page" for uCom (RS232 add-on card for the Z80-MBC2) here.
    The uCom board, as the uTerm VT100 board, has a "transparent" USB-serial adapter connector, so you can upload firmware to the Z80-MBC2 (using Arduino IDE) or load an Intel-Hex file (with iLoad) or use XMODEM to exchange files with a PC (running a terminal emulator that supports XMODEM file transfer) while the uCom is in use.
    Both the "mixed" power supply scenarios (USB-serial adapter not powered from USB but Z80-MBC2 powered and vice-versa) are managed by the HW, so you don't need to worry about it.
    uCorm can be mounted horizontally or vertically to the Z80-MBC2.
    The 3D printed custom angled brackets .STL files are the same of the uTerm.
    Here connected with a "vintage" RS232 terminal (Ampex 210 relabeled Kyber):
  • FuzixOS preview: Unix for Z80!...
    Just4Fun05/21/2019 at 17:14 1 comment
    First test with FuzixOS on the Z80-MBC2 (many many thanks to Alan Cox...)!:
    Stay tuned...
  • uTerm is out!
    Just4Fun05/14/2019 at 07:40 0 comments
    I've done a separate "project page" for uTerm here.
    uTerm can be mounted horizontally or vertically to the Z80-MBC2.
    All the details including the 3D printed custom angled brackets .STL files are there.
    uTerm is a VT100 terminal with VGA out and  PS/2 keyboard with a power supply (for the Z80-MBC2 too). It has a "transparent" USB-TTL adapter connector, so you can upload firmware or load an Intel-Hex file (with iLoad) while the card is inserted. Both the "mixed" power supply scenarios (USB-TTL adapter not powered from USB but Z80-MBC2 powered and vice-versa) are managed. The video terminal is based on the ChibiTerm (https://hw-by-design.blogspot.com/2018/07/low-cost-vga-terminal-module-project.html).
  • uCom preview: a RS232 adapter for the Z80-MBC2...
    Just4Fun04/05/2019 at 17:00 0 comments
    Currently working on a RS232 add-on card for the Z80-MBC2.
    As the uTerm board, it has a power supply for the Z80-MBC2 and a "transparent" USB-TTL adapter connector, so you can upload firmware or load an Intel-Hex file (with iLoad) while the card is inserted. Both the "mixed" power supply scenarios (USB-TTL adapter not powered from USB but Z80-MBC2 powered and vice-versa) are managed.
    Here connected to an Ampex 210 terminal (sold and relabeled by Kyber):
    Stay tuned...
  • New IOS for XMODEM support
    Just4Fun03/10/2019 at 10:54 5 comments
    Because some people requested to use the XMODEM protocol to exchange files through the serial port, I've added the support for this protocol into CP/M 2.2 and CP/M 3 (banked only).
    XMODEM needs a full 8 bit binary data transfer, and this is not possible with the CON port (the CP/M port used for the console) with a "legacy" CP/M system installation because the CP/M Alteration Guide says to strip the eight parity bit when reading a byte from the console input.
    More, because the Z80-MBC2 uses a virtual serial port without handshaking there is also a timing problem when dealing with the 128 bytes packets used by the XMODEM protocol.
    So the support to the XMODEM protocol has requested changes in the IOS and  in the CP/M BIOS, and also in the Arduino core to extend the serial input buffer.
    Please note that with the new IOS the default speed of the serial port is now 115200 bps.
    To have the XMODEM support active, before the update of the new IOS firmware and the new SD image (see in the Files section),  you have to manually create a new "board variant" in the Arduino IDE and then change the default Rx input buffer size to 128 bytes in the "core" of this new variant.
    If you aren't interested into the XMODEM support, you can simply update the IOS and the new SD image as usual  without the need to create the new board variant. In this case the XMODEM will not work in the receive direction, but only in the send direction (from the Z80-MBC2 to a PC with a terminal emulator).
    HOW MANUALLY CREATE A NEW BOARD VARIANT (LINUX)
    In the following I'll assume an Arduino IDE 1.8.5 installation on a linux host and the MightyCore ver. 1.0.8. Anyway I've tried to make the procedure enough general to be used for other versions too.
    The first thing is find the directory where the MightyCore is located.
    If you have installed Arduino IDE 1.8.5 and then installed the MighyCore with the Board Manager with the usual .json "pointer", the MightyCore is located in the "~/.arduino15/packages/MightyCore" directory:
    Now you must locate the "~/.arduino15/packages/MightyCore/hardware/avr/1.0.8/cores" directory (note that the "1.0.8" part of the directory name depends on the MightyCore version, and so can be a different number if you have a different version of the MighyCore):
    ... Read more »
  • uTerm preview: a VT100 terminal for the Z80-MBC2...
    Just4Fun12/28/2018 at 10:16 2 comments
    Currently working on a VT100 terminal with VGA out and  PS/2 keyboard with a power supply (for the Z80-MBC2 too). It has a "transparent" USB-TTL adapter connector, so you can upload firmware or load an Intel-Hex file (with iLoad) while the card is inserted. Both the "mixed" power supply scenarios (USB-TTL adapter not powered from USB but Z80-MBC2 powered and vice-versa) are managed. The video terminal is based on the ChibiTerm (https://hw-by-design.blogspot.com/2018/07/low-cost-vga-terminal-module-project.html).
    Stay tuned...
    Working on a new revision (A071218-R250119):
    Waiting the new PCB, I'm playing with the current PCB "patched" to perform like the new one.
    Here a session with Wordstar 4 configured to use all the 30 rows of uTerm:
    In the photo you can see that also the serial-USB adapter is attached to the uTerm using the "transparent" port. This allows to use two keyboards and two monitors in the "same" time (one keyb and monitor attached directly to the uTerm, and another keyb and monitor of the terminal emulator on a PC connected with the serial-USB). This allows also to use XMODEM (e.g. between the Z80-MBC2 and a PC) or to flash the Atmega firmware with the uTerm connected.
    Or you can use the monitor attached to the uTerm and the keyboard of the terminal emulator on a PC. This is exactly the "configuration" I used in the photo to make the test (as you can see, there isn't any keyb attached to the uTerm).
    Catchum demo with uTerm (a sort of Pacman...). Leaving the game alone, after a while the "demo mode" starts:
    Here last version assembled horizontally with the Z80-MBC2:
    Currently making custom 3D printed mounting brackets for a solid vertical assembling:
  • Overclocking the Z80-MBC2...
    Just4Fun11/02/2018 at 09:51 4 comments
    Because the Mighty Core gives the chance to choice a 20MHz bootloader, I've decided to try to "overclock" the Atmega32A using a 20MHz quartz:
    You don't need others HW changes, just use a 20MHz quartz instead of a 16MHz one. The Z80 clock speed will be at 10MHz.
    You have to select the "20MHz external" option in the "Toos" menu of Arduino IDE before flashing the 20MHz bootloader:
    Of course you need to load the sketch again (using the "20MHz external" option). IOS will display the new clock speed:
    Remember that using a 20MHz quartz you are out of the Atmega32a specifications (the Atmega32a is rated at 16MHz max.), so you are in a "grey area" where things "may works"...
  • CP/M 3 up and running on the Z80-MBC2!
    Just4Fun10/11/2018 at 06:58 0 comments
    With the latest IOS revision and the corresponding new SD image (see the Files section) there is one more option: the CP/M 3.0!
    With CP/M 3.0 it is possible use the 128KB banked RAM to have a wider user area (TPA) for programs and a more "evoluted" OS.
    TWO VERSIONS
    Just as example of how it is easy with CP/M 3.0 manage multiple configurations, I've done also a "non-banked" 64KB version. The switch from one version to the other can be done simply running a batch from the console itself.
    I've prepared two simple batch files to do that. From drive A: the command:
    submit sys64
    will set the 64KB "non-banked" version and then reboot the system.
    To activate again the 128KB "banked" version give the command (from drive A:):
    submit sys128
    NEW DISKDEFS FILE
    To use cpmtools or cpmtoolsGUI with the virtual disks of the CP/M 3.0 environment, you must update the DISKDEFS definition file (from the SD in the folder <SD>/cpmtools/) and use the "z80mbc2-cpm3" entry for all the 16 disks:
    Please note that for the CP/M 3.0 environment all the 16 virtual disks have the same structure and for this there is only one entry for all the CP/M 3.0 virtual disks.
    AUTOEXEC
    The AUTOEXEC switch for CP/M 3.0 works in a different way from the CP/M 2.2 and QP/M 2.71 implementations.
    Now there is a custom utility (AUTOEXEC) that checks the IOS flag and sets the exit code accordingly (using the BDOS function 108). This allow to use the CP/M 3.0 batch conditional execution (see the CP/M 3 Programmer Guide par. 1.6.3) to run any wanted command or program based on the status of the IOS AUTOEXEC flag.
    I've prepared an example using an other CP/M 3.0 feature, the "PROFILE.SUB" batch that is automatically executed at cold boot (if it exists). To activate it (in the drive A:) rename the file PROFILE.SU as PROFILE.SUB with the command:
    ren profile.sub=profile.su
    Now you can see how it works setting the AUTOEXEC flag on or off with the IOS "Select boot mode or system parameters" menu.
View all 13 project logs
Arthur wrote 11/21/2020 at 07:19 point
Hi guys, i have a problem with my mbc2. After the boot menu is displayed i choose basic or something else, nothing is starting. Only this message appears:
IOS: Loading boot program... Done
IOS: Z80 is running from now
I have no SD Card installed. Can someone help me? Thank you
DarS wrote 09/28/2020 at 20:29 point
Thanks for a plenty of joy with Z80-MBC2 !  I just assembled my copy and spent few evenings trying to understand the details. A kind of a user guide was crafted with all the information I could gather from different sources. If you find it useful, feel free to use/share:
https://github.com/DarS007/Z80-MBC2_guide
ermanno wrote 09/04/2020 at 18:08 point
To format the sd card I have to use fat or fat32 and what size of the allocation unit?
Or it doesn't matter.
Just4Fun wrote 09/05/2020 at 08:42 point
You can use both FAT or FAT32. The micro-SD can be a legacy one (max 2 GB if I remember well) or a SDHC. Nothing more. No others special setting are needed.
Vinicius Monteiro wrote 08/19/2020 at 00:13 point
Hey so i'm kinda noob in those stuffs (besides having a technical degree in eletronics, I never really had time to mess around with them in my spare time) and I have like a very, very limited knowledge in Arduino. How can I import a bootloader to the ATMega? Thanks everyone, and mainly for the chap who post the project.
Peter Tabatt wrote 08/04/2020 at 15:51 point
Hello,
an other day an other question. I use the hex-file S220718-R280819_IOS-Z80-MBC2... on the Atmega 32 and after starting the Z80-MBC2 i got the boot-menu. So far so good! I explored the menu-entries and after choosing Forth, I run into Forth on every reboot. How can I get back to the boot-menu at startup?
villaromba wrote 08/04/2020 at 16:38 point
Easiest way is to press both RESET & USER keys, release the RESET key holding the USER key down until the IOS led starts to blink, or you see the menu on the screen.
Peter Tabatt wrote 07/30/2020 at 17:11 point
What a cool project! It's like time-travelling for me, I feel backsituated to my time as student. My first homecomputer had a Z80-clone but no CP/M. Z80-MBC2 is a very cool project! I assembled two and they are up and running.
Now I have one question: How can I put some programs into the disk-images on the sd-card?
Is there a tool to fill the disk-images on a PC? Under Windows?
villaromba wrote 07/31/2020 at 21:45 point
If you scroll down on the 'Logs' menu you'll find  CPMtools GUI and instructions. on how to use it. (You can of course use XMODEM  to transfer files over to disk directly.)
Jonathan Guthrie wrote 07/29/2020 at 16:30 point
Thank you for this most excellent project!
I built this recently.  It works fine for me, and now I'm trying to figure out what I want to do with it.
Sigmar Roßmann wrote 07/13/2020 at 12:04 point
Hello
I am trying to compile the S220718-R260119_IOS-Z80-MBC2.ino in the Arduino studio.
If I uploaded the HEX file with the Atmel studio on the Z80-MBC2, everything works.
But the serial interface does not print any characters.
Does somebody has any idea.
Excuse my English.
greeting
Sigmar
Sigmar Roßmann wrote 07/13/2020 at 12:32 point
Hello
already solved
I had to change the HardwareSerial.cpp in one place.
Sigmar Roßmann wrote 07/06/2020 at 16:34 point
Hello everybody,
can someone explain to me what in the Arduino * ino
the
"void serialEvent ()
// Set INT_ to ACTIVE if there are received chars from serial to read and if the interrupt generation is enabled
{ if ((Serial.available ()) && Z80IntEnFlag) digitalWrite (INT_, LOW);
Interupt on Z80 is triggered?
greeting
Sigmar
Just4Fun wrote 07/07/2020 at 13:43 point
As explained in the comment it triggers the INT line when a char is ready to be read by the Z80 CPU and the INT trigger flag is enabled in the IOS firmware.
This mode is used only by the stand-alone ROM Basic.
(Not sure to have understood the question...)
Sigmar Roßmann wrote 07/11/2020 at 16:14 point
Thanks that was exactly the right answer.
ermanno wrote 06/15/2020 at 20:12 point
just4fun you're right I confused it with the pinout of the bc 557 which is inverted.
ermanno wrote 06/15/2020 at 17:20 point
The transistors 2n2907 if inserted as in the serigraphy would have the collector connected to vcc, instead it is the emitter that must be connected to vcc, therefore the flat part of the transistor goes towards the Z80 and not towards the LEDs. However inserted in one way or another they work equally. How should these transistors be inserted ...
Just4Fun wrote 06/15/2020 at 17:38 point
Stephan Kraus wrote 04/12/2020 at 20:57 point
Hi!
Thanks for the great project!
I am wondering if there is the chance to add a second serial port to hook up a printer or paper tape reader?
Best regards
Stephan
Sebastiano Grimaldi wrote 03/29/2020 at 17:51 point
I've just checked the SD card board with an Arduino uno board. I've correctly write and read file in the SD. I understand that the SD card board is working! Thanks a lot to give me some idea for additional debug.
Just4Fun wrote 03/29/2020 at 18:38 point
If you press and release the RESET key, D11 must do a single very fast blink (also if the SD module is not present) just before the IOS SD error is "printed" on the serial port. If you don't see it there must be an assembling error/fault.
Sebastiano Grimaldi wrote 03/31/2020 at 18:17 point
Thanks for the suggestion, I've fixed the problem. Now my MBC2 is perfectly running! Best regards, Sebastiano
Sebastiano Grimaldi wrote 03/29/2020 at 13:43 point
Very compliment for this fantastic project!
I build MBC2 everything it's working fine except the SD card!
Using the lite IOS I run BASIC and FORTRAN then the system is working.
Loading on the ATMEGA32 the IOS with SD management I got the following error:
Z80-MBC2 - A040618
IOS - I/O Subsystem - S220718-R280819
IOS: Z80 clock set at 8MHz
IOS: Found RTC DS3231 Module (29/03/20 15:34:36)
IOS: RTC DS3231 temperature sensor: 19C
IOS: CP/M Autoexec is OFF
IOS: Select boot mode or system parameters:
 0: No change (3)
 1: Basic
 2: Forth
 3: Load OS from Disk Set 1
 4: Autoboot
 5: iLoad
 6: Change Z80 clock speed (->4MHz)
 7: Toggle CP/M Autoexec (->ON)
 8: Change Disk Set 1
 9: Change RTC time/date
Enter your choice >1  Ok
IOS: SD error 2 (NOT_READY on MOUNT operation)
IOS: Check SD and press a key to repeat
There is not any activity on the LED D11, I've cheched all the route trace, no error.
Any help, please?
Just4Fun wrote 03/29/2020 at 14:21 point
That error says that there isn't any SD card inserted into the SD module...
BTW: Are you sure to have inserted the SD card module correctly (as shown in the photos)?
Sebastiano Grimaldi wrote 03/29/2020 at 17:05 point
Thanks for fast response! The sd card is correctly installed with the proper contents as per your zip archive. Best regards, Sebastiano
m.uhlmann.zwickau wrote 06/10/2020 at 06:18 point
I have also this error some times. After reconnect the sd-card or the board it works.
mikeh32217 wrote 03/25/2020 at 07:02 point
Awesome project, great fun and perfect for the era of the shutin!
Thanks for the effort!
[deleted]
[deleted]
Edgar Salgado wrote 06/09/2020 at 19:32 point
Hello! Any chance you are willing to sell me a spare PCB? :)
O.E wrote 02/16/2020 at 17:47 point
Hi,
After i setud circuit i connected to computer using FTDI programmer leds blinking correctly but terminal is not  open in computer when  pressing buttons.
Just4Fun wrote 02/17/2020 at 11:18 point
Hi,
have you set the sw terminal at 115200 8N1 (No HW handshaking)...? Are you sure to have connected RX/TX correctly...? An other "source" of common problems is a wrong fuse setting when flashing the bootloader first time...
wojtek.p wrote 01/13/2020 at 12:20 point
Hi,
Does anyone have 3D models (step format) for Z80-MBC2, uCom and UTerm? I want to design a 3D printing case and it would be helpful. If anyone has, please send to wojtek.p@onet.pl
Thanks
Wojtek
wenij wrote 01/12/2020 at 09:55 point
hi,
have any one knows how to build the Z80-MBC2_figforth130.asm source code?  which tools set to build?
thanks.
wenij
WestfW wrote 01/16/2020 at 23:41 point
For the MBC1, I used the TASM3.2 cross assembler for DOS/Win, which you can apparently download from: https://www.ticalc.org/archives/files/fileinfo/250/25051.html
Tony Nicholson wrote 10/12/2019 at 11:32 point
This is a fantastic little board.  I'm now starting to tinker with things a bit and I'll be attempting to combine the CP/M 3 bios modules with Simeon Cran's ZPR3 replacement BDOS routines (obtainable from the Tesseract RCPM+ archives - volume 93 at http://www.classiccmp.org/cpmarchives/cpm/mirrors/www.triton.vg/TesseractRCPM+Catalog.html#vol93 ).
Before doing this I thought I'd attempt to reconstruct the supplied CPM3-128.SYS system from sources and I'm not having much success - in particular with all the choices when running GENCPM.  Would you be able to share the build procedure and corresponding GENCPM.DAT file?  Thanks.
