Ardumower Arctic Hare X2
3D-printed chassi for Ardumower
So, recently, I was asked to design a concept for an already existing project (Ardumower).<br>The goal of this project is to be able to print the chassi in a 20x20x20 3D printer.<br>This project will be designed after existing Hardware that one can buy from <a target="_blank" rel="noopener noreferrer" href="http://marotronics.de">marotronics.de</a><br><br>The mower can be built either as a single mower or a double version. Your budget can decide. For questions about Hardware or code I refer to (Ardumower).<br><br>This is a great project if you want to build your own robot lawnmower.<br>Designed in Fusion360 and will be available to download when it is ready! :-)<br>If you like what I do, give me a shout at Twitter @r_frojd
Design concept:
  • Body almost done
    Robin Fröjd • 08/07/2018 at 05:48 • 0 comments
    The body for the Ardumower is almost done. Fully 3D-printable in a 20x20x20 printer. Designed in Fusion360. The body was sliced in 17 parts. Next up is a finishing and painting. Total print time around 200h with 0.6mm nozzle and 0.28 layers. Here is a snapshot from behind
  • More 3D-printing
    Robin Fröjd • 08/04/2018 at 07:02 • 0 comments
    Front nose 1/2 just finished! Right side is almost completed.
    Body assembly
    Body on chassis
    charging pin
  • More 3D-printing
    Robin Fröjd • 08/03/2018 at 19:14 • 0 comments
    Another part just finished!
    next part is already printing and will be finished tomorrow.
  • More 3D-printing
    Robin Fröjd • 08/02/2018 at 22:47 • 0 comments
  • 3D Printing wheel arches
    Robin Fröjd • 08/02/2018 at 10:08 • 0 comments
    Small update:
    wheel arches fresh from the printer! All parts is completely untouched and no after finishing.
    Starting to look good!
View all 5 project logs
Piotr Baranowski wrote 05/30/2022 at 13:24 • point
Is that project dead?
Josh Starnes wrote 08/04/2018 at 19:20 • point
Ah ok, so shouldnt be a problem, honestly im cheap, i really dont wanna buy the aluminum frame pieces, I may print those in solid PTEG or something. I am looking at making a commertial ardru mower type robot that I can rent out to customers to upkeep their yards during warm months, which here is about 1/2 the year.
Robin Fröjd wrote 08/04/2018 at 21:31 • point
aha ok. I think the aluminum will be cheaper the PETG. The price is around 10euro/M. I will share everything when it’s done ;)
Josh Starnes wrote 08/03/2018 at 19:47 • point
what machine are you printing with? I have Robo 3 R1 plus printers with 9 x 11 bed
Robin Fröjd wrote 08/03/2018 at 19:49 • point
I am printing with a Raise3D N2+. But all parts is modeled to print in a 7.87x7.87x7.87 printer!
