08/05/18 - Schematics for Passive Mixer
A project log for Rachel's Nightmare, a distributed polyphonic synth
Uses multiple Arduino Nano and a passive mixer to generate multiple voices simultaneously.
arduino-enigmaArduino Enigma 08/10/2018 at 22:010 Comments
Here is a picture of the assembled mixer:
The white wires are signal inputs for each different channel. The blue wire goes to the common
ground. This mixer assumes all channels share a common ground.
The component  values were chosen based on what I had lying around.
Currently waiting for the a shipment of the following potentiometers in order to populate the voice cards.
