09/01/18 - The proper RV09 potentiometers arrive
A project log for Rachel's Nightmare, a distributed polyphonic synth
Uses multiple Arduino Nano and a passive mixer to generate multiple voices simultaneously.
arduino-enigmaArduino Enigma 09/09/2018 at 18:490 Comments
The proper pots arrive. The next board revision will definitely need more space between them.
These are 10K and will be used in a second voice board.
Some 100K pots also came in the mail and will be used soldered in a voice board that will function as an 8 channel passive mixer.
One board, multiple uses.
Instagram post:
https://www.instagram.com/p/BnfTwZzg4RB/
