Wi8x8_sketch_and_library.zipWi8x8.ino, esp8266 web-control of an LED matrix.Modified version of Adafruit_LED_Backpack (1.1.6) x-zip-compressed - 8.02 kB - 08/25/2018 at 00:21 |
WiLight.inoArduino IDE script to program ESP-01 module to control a Neopixel ring.ino - 15.93 kB - 08/22/2018 at 22:17 |
playlists.zipCollection of .m3u playlist files, each containing the url of a single radio stream.[Directory: ~/.mpd/playlists] x-zip-compressed - 3.51 kB - 08/15/2018 at 20:12 |
VoiceBox.zipMain Google Assistant + Flask server.[Directory:~/AIY-projects-python/src/VoiceBox] application/x-zip-compressed - 400.24 kB - 08/05/2018 at 20:18 |
Blinkter.zipWeb server controlling Blinkt RGB LED array.[Directory: ~/Python/Blinkter] application/x-zip-compressed - 1.54 MB - 08/02/2018 at 21:08 |
piHole.zipText-to-speech message server.[Directory: ~/Python/piHole] application/x-zip-compressed - 86.19 kB - 07/31/2018 at 22:00 |
sysinfo.zipModified copy of Ashok Raja's system information server.[Directory: ~/Python/sysinfo] application/x-zip-compressed - 129.04 kB - 07/31/2018 at 16:27 |
VoiceBox_STL_files.zipSTL files for printing VoiceBox enclosure. Choose between, e.g., VoiceBox_rear_fan.stl & VoiceBox_rear_no_fan.stl.x-zip-compressed - 120.17 kB - 07/31/2018 at 16:16 |
Raspberry_Pi_Model_Bplus.STLModel of Pi, for visualization in OpenSCAD only. DO NOT PRINT!Standard Tesselated Geometry - 4.52 MB - 07/29/2018 at 22:21 |
Utilities.scadUtilities used by VoiceBox.scad. Install to "Utilities" sub-directory or edit "use" statement in VoiceBox.scad to match location.scad - 4.56 kB - 07/29/2018 at 21:56 |
VoiceBox.scad*** START HERE ***- 9.60 kB - 07/29/2018 at 21:54 |
