Mutable Instruments Module Tester Build Log
Power, signal generation, and analysis for eurorack modules.
Building the open source module tester from Mutable Instruments.
Eurorack module tester.
This project is a test signal generator for Eurorack synth modules. It also provides frequency/clock measurement tools, and a +/12V and +5V power supply - making it a compact "all in one" box for powering and debugging a module.
Original developer: Olivier Gillet (ol.gillet@gmail.com)
The firmware is released under a GPL3.0 license. The PCB layouts and schematics are released under a Creative Commons cc-by-sa 3.0 license.
sheet - 9.41 kB - 08/03/2018 at 18:27
Download
  • 16 × 1C10Z5U104M050B Capacitors / Ceramic
  • 1 × 3386P-1-502LF Potentiometers, Trimmers, Variable Resistors / Trimmer Potentiometers
  • 1 × LM2990T-12/NOPB Power Management ICs / Linear Voltage Regulators and LDOs
  • 10 × 67996-416HLF Connectors and Accessories / Headers
  • 1 × 163-7620E-E
View all 55 components
View all 4 project logs
