Part 3: Measurement Setup
A project log for Computer Lab Box
This Lab contains all important tools used for developing on embedded PCs without the need to have the board next to you.
nikolaNikola • 08/19/2018 at 08:51•0 Comments
The third part of this project is the measurement setup. I don’t want to leave my PC to check some pins or LEDs. For this I want to have a simple web cam and a simple logic analyzer.
Camera:
For the camera I am using the “Raspberry Pi Camera Module V2” together with the software “motion”. How to install and setup the software I found here:
https://hackernoon.com/spy-your-pet-with-a-raspberry-pi-camera-server-e71bb74f79ea
Logic analyzer:
For the simple logic analyzer, I will use “wiringPi” which is already installed by default in Raspbian. With this library I can check the pin status of the J8 header, without initializing the GPIOs before.
First I thought to program a better logic analyzer, but for the projects that I plan in the near future I don’t need a better tooling and if I would need something better, I would use “piscope” ( à http://abyz.me.uk/rpi/pigpio/piscope.html) on my “Raspberry Pi Zero W”. So that I don’t lose any performance on the main Raspi.
