Hackaday.io Hackaday.io
Sign up Log in
Simple electric motor using a single magnet
Simple electric motor using a single neodymium magnet sphere 19 mm, a coil iron less, small solar panel, reed switch, rectifier (optional )
sciencetoolbarsciencetoolbar
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
0 comments
1 followers
  • Description
  • Details
  • Files 3
    • View all
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
  • The 2018 Hackaday Prize
View Gallery
Public Chat
375
0
1
1
Team (1)
  • sciencetoolbarsciencetoolbar
Join this project's team
  • htttp://sciencetoolbar.com
completed project
MISC
simple project 2018hackadayprize simple motor SIMPLE ELECTRIC MOTOR pulse motor SIMPLE PULSE MOTOR
This project is submitted for
  • Human Computer Interface Challenge
This project was created on 08/01/2018 and last updated 8 years ago.
Description
Simple electric motor using a single neodymium magnet sphere 19 mm, a coil iron less, a small solar panel, rectifier (optional ) . A pulse motor using a single neodymium sphere VIDEO : <a target="_blank" rel="noopener noreferrer" href="https://www.youtube.com/watch?v=SSwhofB7v5oA">https://www.youtube.com/watch?v=SSwhofB7v5oA</a> pulsed motor uses short pulses of current to drive the motor, making it spin.<br>The neodymium magnet sphere is acting as a flywheel.<br>The pulse motor is one of the simplest motors and works very well under low voltages.<br>When magnet gets close to the reed switch, the two contacts inside the glass tube get magnetized and touch each other.<br> The coil iron &#x2013; less pushes magnet away and making it spin.<br>The rotor continues to spin due to inertia until the magnetic field gets in working range of the reed switch again.
Details
Files
JPEG Image - 11.10 kB - 08/01/2018 at 08:52
Preview
JPEG Image - 7.27 kB - 08/01/2018 at 08:52
Preview
neodymium sphere 19 mm
JPEG Image - 13.19 kB - 08/01/2018 at 08:45
Preview
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
You should have bought an electric coffee grinder.
Project Owner Contributor
SHUBEG (coffee grinder)
hello42worldhello42world
DIY extremly low current pulse motor from old relays
Microwatt Pulse Motor
mircemkmircemk
Finding an alternative spindle motor or using an external spindle controller on the Roland MDX-15
Roland MDX-15 Mill - Spindle Motor Alternative
jackjameshowardJackJamesHoward
pulse motor using 6 neodymium magnets powered with solar panels https://www.youtube.com/watch?v=mW8fpOU5eNU
pulse motor powered with solar panels
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Simple electric motor using a single magnet", please tell us the reason.
Send message
Remove Member
