Tone Generator
A project log for Puff-Suck interface for fast text input
A tube connected to a bipolar pressure switch drives an Arduino which translates puffing and sucking into Morse code and then into text.
anaAna 08/04/2018 at 16:580 Comments
Currently, an LED flashes for Morse code, but visual feedback is not good enough. To Morse quickly, you need to have sound feedback. Cat and I will need to find a suitable speaker and turn it on at the same time as the LED, and I'm also working on a way to change the speed at which you Morse.
The Arduino tone() function seems to be good for our purposes, but it does use a timer, so I wrote the code and ran it without connecting the speaker, and it still seems to work fine.
-Ana
