Nixoid use IN-16 nixie tubes to display the time. Specifically for the Nixoid clock we develop an algorithm for synchronous ignition of lamps and anti-poisoning of cathodes, so the resource of the IN-16 indicators increased several times and the viewing of the time became more beatiful.  Nixoid high voltage generation system has a power reserve of 3.57 times, it is very reliable. Specifically for the Nixoid we develop dynamic backlight charging battery level. When the battery is 100% charged, tubes has backlight like nuclear color, during use backlight slowly stay a green color.
Nixoid specs:
  • Time format: 12/24 hour;
  • Date format: DD/MM/YY;
  • Battery: built-in rechargeable lithium-polymer, nonremovable, 220mAh;
  • Power supply: 5V DC;
  • Connection: micro-USB;
  • Operating temperature; 0 to +50c / 32 to 122F;
  • Dimensions: diameter is 55mm, height is 20mm;
  • Strap: 22mm, fully compatible with Gear S3 straps or any 22mm straps.
 You can charge wristwatch via any computer or notebook with USB port. Special charging system keep battery stronger for a long time. During charging, you can turn on the time display mode by simply pressing the button. Nixod autonomity is perfect! From one charge the watch works more than 20 days of normal use and more than 2 months in standby mode. And even if the battery is discharged to 0%, you do not need to adjust the time again, only charge it!
Watch case made from ABS plastic. It does not rust and not amenable to acids. The case is strong and elastic. Each case is handled entirely by hand, passing all the stages - sanding, priming, painting. Every wristwatch is unique.
Wristwatch is desighned for everyday wear, so it are light, compact and work for a long time.
Glower
Glower use IV-9 numitron tubes to display the time. Small filaments are glow in NOS gas. It is look very futuristic. It is a new thing in tube wristwatches era. This watch small and very light. Glower watches use narrowly specialized microcircuits for controlling the filaments in the numitron IV-9 tubes, which made it possible to simplify the clock circuit and reduce the current consumption. We add battery percentage in menu, only long press a button and you can see the information about battery.
Glower specs:
  • Battery: built-in rechargeable lithium-polymer, nonremovable, 200mAh;
  • Dimensions: diameter is 49mm, height is 18mm;
  • During charging, Glower visualise cool effect on a tubes. You can turn on the time display mode by simply pressing the button. Full time of battery charging is above 50 minutes.
