SAMD V2 Fusee Payload Injector
A mini SAMD21 board with CR2032 backpack. Can be used for fusee gelee or other DIY projects
Like many others, I spliced a trinket onto a CR2032 battery holder in order to boot hekate and back up the NAND on my switch. It worked, but was a bit ugly and hacky so I decided to integrate it all into a single PCB.
V2 is now here with onboard USB C! Also with a beautiful enclosure designed by Hatch - see the feed below for updated Thingiverse files if you want to print your own case!
NOTE: I do not endorse or condone piracy or unauthorized backups. My usage is limited to NAND backups, and I suggest the same to you. Backup loading and other hacking can be detected, resulting in a ban from online gaming. Don't do anything you don't understand, and don't engage in hardware hacking unless you accept the risk that you alone are responsible for any damage you may cause to your equipment.
This project is a small dongle carrying a SAMD21 from Atmel along with a CR2032 battery holder and USB b port for use as a portable fusee launcher.
I built it to get a little more familiar with the Cortex M0 offerings from Atmel, as well as to make myself a nice, compact device that I could use for Switch experimentation as well as other projects.
This project is using the UF2 bootloader, which is the most amazing idea that anyone has ever come up with - thanks, Microsoft!  The UF2 bootloader impersonates a virtual flash drive when plugged into USB and reset is double clicked, allowing reading and writing firmware with a simple drag/drop operation.  Very slick!
The project is also compatible with the Arduino platform using the bossac loader.  Personally, I use an STM32 blue pill flashed to CMSIS-DAP to do my low-level programming, but for a simple setup Arduino can't be beat!
If you are interested in purchasing the V2, you can check out the Tindie project page here.  Hatch (the designer of the open-source case) gets 10% of every sale of board+case!
https://www.tindie.com/products/14767/
If you would like to purchase the original board without USB B, it is also available on Tindie here
https://www.tindie.com/products/13711/
The badass open source case design is available on Thingiverse here:
https://www.thingiverse.com/thing:3062284
The github containing all code for the product is here:
https://github.com/electronrancher
And the discussion thread of me chatting during the build is on gbatemp
https://gbatemp.net/threads/my-dongle-project-internal-external-samd-loader-with-cr2032-holder.513755/
Firmware files for the three most popular loaders (hekate, ReiNX, and SXOS) are found below in the files section.  To switch, plug the board into USB, double click reset, and drop the UF2 file onto the drive called FIRMWARE that pops up
SAMD_ReiNX_1p7_Launcher.UF2
Updated payload for launching ReiNX 1.7
uf2 - 512.00 kB - 09/28/2018 at 02:08
Download
UF2_Splicer.zip
A free tool by bundat on gbatemp to make new payloads. Just drop a bin file onto the bat file to generate a custom UF2 for flashing. Source included!.
x-zip-compressed - 45.55 kB - 09/19/2018 at 23:25
Download
SAMD_hekate_v4p1.UF2
Hekate v4.1 payload for the SAMD Loader - UF2 (drag & drop) format
uf2 - 512.00 kB - 09/19/2018 at 23:23
Download
SAMD_hekate_v4p0.UF2
Hekate v4.0 payload for the SAMD Loader - UF2 (drag & drop) format
uf2 - 512.00 kB - 09/19/2018 at 23:22
Download
SAMD_Multiloader_V1p0.UF2
Multiloader contains hekate, SXOS, and ReiNX all in one! Ground D1 to select, ground D0 to store selection - new double button board coming soon to support!
Download
View all 8 files
  • Your Pikmin has sprouted a leaf
    electronrancher09/01/2018 at 04:08 0 comments
    V2 is coming!
  • openocd flash script
    electronrancher08/11/2018 at 03:53 2 comments
    Turns out, openocd is hard for people to use!   It's true that it has a billion obscure options, but once you've gone through the pain of using it on a few chips, it just makes sense!
    I wanted to add my flashing script (openocd.cfg) here to show an example of a working setup using openocd 0.10 and an STM32 Blue Pill flashed to the CMSIS-DAP firmware.  This is what I use to do the initial flash on my boards.
    My bin file contains both the UF2 bootloader as well as a fimware, but it's really only necessary to use openocd to flash the bootloader on a fresh chip.  After UF2 is on there, you can use USB to drag and drop firmware on very easily.  However, it saves a step for me if I flash both of them at once so that's the way I do it.
    As for how you merge the bootloader and firmware into a single bin file?  Don't ask, it's a bit messy.  If you want this bin file just PM me.  Cheers!
    interface cmsis-dap
    transport select swd
    #Target
    set CHIPNAME at91samd21e18
    source [find target/at91samdXX2.cfg]
    #source [find target/stm32f1x.cfg]
    init
    targets
    reset halt
    at91samd chip-erase
    reset halt
    at91samd bootloader 0
    program D:/projects/SAMD_Loader/Firmware/all.bin verify
    at91samd bootloader 8192
    reset
    shutdown
  • Github links for Firmware and Bootloader
    electronrancher08/10/2018 at 02:01 0 comments
    Here are the Github links for the source code used in this project.  If you want to go a-hacking, you will most likely want the Launcher firmware.  The bootloader code is included for those who are interested, but it's not needed unless you are starting out with a factory-fresh chip.  After the initial bootloader flashing, all further flashing of firmware, etc is done either through Arduino, or better yet - by dropping a UF2 file onto the USB device itself.  (Double click reset to open the USB firmware drive for drag & drop flashing)
    Launcher Firmware Source Code (Arduino Sketch)
    https://github.com/electronrancher/sam-fusee-launcher
    Bootloader Source Code
    https://github.com/electronrancher/uf2-samdx1
  • 8/4/18 - It's Alive!
    electronrancher08/05/2018 at 18:08 0 comments
    Here is a quick demo of the SAMD Loader in action.  It's a pretty straightforward operation:
    1) Paperclip or use a RCM clip on the right hand joystick slot
    2) Power up SAMD Loader, get a fast blue blink (Looking for USB)
    3) Hold Vol + and Power up, blinking will pause for a moment as USB enumerates.
    4) Short/Long blink (Ta Daa!) signifies sending and launching the payload
    5) Enjoy!
    Here I am sending SX Launcher, as I just use my own hekate build stored on SD.  But I have a firmware that sends hekate directly if preferred.  Really, the firmware can be recompiled with any payload you like. To convert a bin file payload to a header for inclusion in the firmware, just use the "bin2header" tool from github to convert.
  • 8/4/18 - Flashing the firmware
    electronrancher08/05/2018 at 17:58 0 comments
    I flash my firmware using openocd and an STM32 "Blue Pill" flashed to the CMSIS-DAP firmware.  I use openocd to flash a bin file that contains both the UF2 bootloader as well as the fusee firmware.  It's a bit more convenient to do it all in one shot than to flash the bootloader first and then switch to USB or arduino for the firmware.  After this initial programming, I use the USB virtual flash drive from the UF2 bootloader to modify or change firmware as openocd is no longer needed.
    For this project, I just use the blue pill to directly contact the four programming pads I placed on the SAMD board.  A little bend in the blue pill headers give a nice springy connection that I can pop on and use to hold the board steady while flashing.  This initial flash takes about 30 seconds, so it's pretty quick to do a batch of 10 or 20.
  • 8/4/18 - Placing the SAMD Loader
    electronrancher08/05/2018 at 17:31 0 comments
    Here you can see a video of the placer building the very first SAMD loader.  Fingers Crossed!
  • 8/3/18 (Late o'clock) Pick and Place Programmed
    electronrancher08/05/2018 at 17:18 0 comments
    It always takes a few hours to program the pick & place.  Here I am using a bunch of components on cut tape, so I just stick them to a board and use the vision system to set the location of the first and last part.  That's the first part of project setup for the placer, and takes an hour or so unless you bump a strip of 0603 LEDs and have half of them jump out into a scattered pile.  Then, it takes longer.  :)
    Here you see the PCB panel on the right, and components stuck to a wooden plank on the left.  From left, it's Battery Clip, Switch and Reset Button above it, USB socket, SAMD and LDO above that, then two rows of LEDs - blue and green.
    Some components like caps are already mounted in reels on the side of the machine, but there are always a handful of custom components (or ones that are too expensive to buy a full reel!!) that I use cut tape for.
    The next part of setup is verifying the placement and orientation by running a placing cycle (usually for one component only) with double face tape on the PCB.  The machine grabs the part, checks it, and sticks it where Eagle said it should go.  It's usually perfect, but a few oddball devices like the USB port had a center location different from what Eagle outputs and need editing.
    It's tedious, but if you're making a bunch of boards it is much easier to take the pain now in exchange for MUCH faster assembly than doing it by hand.
  • 8/3/18 - Boards Arrive
    electronrancher08/05/2018 at 17:04 0 comments
    After a bit of weather delay in transit, boards for the SAMD Loader have arrived!  Everything looks good, time to start programming the pick & place
View all 8 project logs
