Plugtite
DIY Long Term Plug Safety
Lamps, alarm clocks, pencil sharpeners .. we leave some plugs in outlets for years unnoticed and hidden by furniture .. but over time these plugs can become loose and exposed .. leading to dangerous conditions.
Plugtite is your do-it-your-self-tho-Vije-did-it-for-you 3D printed solution to secure your plugs for life .. so that your home can safely burn down around you for a cadre of other reasons.
Notation(s)
1. Shout-out to https://www.theio.nyc/
2. Use a heated soldering iron shaft or stove to soften the legs for bending.
3. Dependent on print quality .. sanding the mounting feet may be required.
4. For narcissism's sake; the quality of the opening scene is rubbish due to now redundant voluntary third-world-prison filming conditions.
Download(s)
https://cdn.hackaday.io/files/1602396855665376/plugtite_018_2.stl
https://cdn.hackaday.io/files/1602396855665376/plugtite_018_2.skp
Archive
http://vijemiller.com/index.php?entry=entry180810-222114
https://hackaday.io/project/160239-plugtite
https://www.thingiverse.com/thing:3046608
SSEYO Koan Play File - 740.23 kB - 08/09/2018 at 23:30
Download
Standard Tesselated Geometry - 107.99 kB - 08/09/2018 at 23:30
Download
  • 1 × PLA
View all 3 project logs
0
3
Project Owner Contributor
Sanding disc Holder
GiovanniGiovanni
