micropower micrologger [mPmL]
A set-and-forget I2C/digital datalogger. Size: 25.3x 18x 10mm incl. battery. Runtime: > 1year
janJan
This is a logical development from my first and second logger projects. The idea is simple: The logger needs to be small enough to fit inside small spaces, e.g. a bee hive.
With the press off a button it starts/stops logging. The casing can be as simple as shrink tubing!
You can find the original project here.
Features at a glance
  • small: only 25.3x18x8mm incl. battery holder
  • low power: runtime 2 years (with a CR1632 120mAh coin cell, 4 logs/hr)
  • versatile: use I2C or digital sensors (board runs from 3.3 to 1.8V)
  • 1x temperature sensor on-board, accuracy ± 0.5°C (TMP112, NIST-traceable)
  • data retention > 200 years (depends on EEPROM manufacturer)
  • data transfer via standard 9600 baud serial protocol (or faster, you decide!)
Functional specification
The following table shows the most important features I expect from my logger. There are of course more (e.g. LED for signaling, reset button, ...) but those will make it into the final design anyway!
PARAMETERVALUE/DATAIMPORTANCESTATUS
size
≤25.4x25.4mm (1 square inch)
(preferably 25x20mm)
height < 10mm
REQUIRED
DESIRED
DESIRED
operational life
> 1 year on a CR1225 button cell (48mAh)
> 2 years on a CR1632 button cell (120mAh)
REQUIRED
DESIRED
RTCtemp. compensated RTC (DS3231MZ+)
REQUIRED
accuracyT ± 0.5°C
REQUIRED
ext. sensor size
small for hive "in cell" measurement
DESIRED
memory(timestamp + 4x temperature) * 1 year
REQUIRED(✔)
easy data transfer
3 wire interface (RX, TX, GND)
REQUIRED
Here's a quick jump-to to all of my log entries (latest changes are bold):
ENTRYLAST CHANGED
01 – choice of components
Tuesday, Oct. 2nd, 2018
02 – data storage
calendar week 39
03 – test placement of componentsWednesday, Oct. 10th, 2018
04 – logger and sensor positionSaturday, Aug. 18th, 2018
05 – PCB finalizedSunday, Aug. 19th, 2018
06 – PCB finalized again and orderedMonday, Aug. 20th, 2018
07 – shitty TMP11x breakout boardsMonday, Aug. 20th, 2018
08 – my own deadline + thoughts on suppliersThursday, Aug. 23rd, 2018
09 – it's alive!Saturday, Sept. 22nd, 2018
10 – usagecalendar week 39
11 – final picturesSaturday, Sept. 29th, 2018
12 – soldering 1.6x1.6mm (SOT-563) sensors to leadsMonday, Oct. 8th, 2018
mPmL_basicLogger_works_2018-10-03_2055.zip
Just a first version of the logger-code which works. Its far from perfect and even more far from done. But hey, it works for now. Nev revisions coming soon!
x-zip-compressed - 9.21 kB - 10/03/2018 at 19:16
Download
FirstDemo.mp4
Quick demo showing an early stage of the logger.
MPEG-4 Video - 31.69 MB - 10/01/2018 at 12:59
Download
mPmL_EEPROM_test.zip
code to read temperatures from the TMP11x sensor and write three blocks to the EEPROM. It reads them back over serial to verify your data
x-zip-compressed - 2.47 kB - 09/29/2018 at 10:37
Download
mPmL_setRTC_over_Serial.zip
code to set the DS3231M RTC. Uses https://github.com/JChristensen/DS3232RTC. See examples from that library to use/set the alarms etc as well!
x-zip-compressed - 2.13 kB - 09/23/2018 at 08:13
Download
mPmL_BlinkPowerDown.zip
code to test the onboard LED. features rocketscreams low power library to save precious power while doing nothing between LED flashes :)
x-zip-compressed - 1.06 kB - 09/22/2018 at 15:04
Download
View all 7 files
  • 1 × Atmega328P-MU Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
  • 1 × TMP112 0,5°C onboard temperature sensor
  • 1 × DS3231M (SOIC8 package) Clock and Timer ICs / Real-Time Clocks
  • 1 × M24M02 Memory ICs / EEPROMs, alternatives are e.g. 24LC512, 24AA512, ...
  • 1 × Keystone 3012 button cell holder for CR16XX cells
View all 10 components
  • Next stop: 18x13x6mm. 35nA (0.000035mA) sleep current.
    Jan02/25/2019 at 18:12 0 comments
    The micropower micrologger project is not dead. Quite the contrary is true. I've been testing this even smaller logger for a while now, in a basic (not fully assembled) variant:
    It is working well. Power source is a CR1225 (on the back of the PCB). The timing is not done with an RTC but an TPL5110 nanopower timer. The next version will be even smaller, as I found a smaller battery holder from Linx Technology. The reset button will be removed as well.
    The board uses 35nA in shutdown mode. The TPL5110 is activated at a set intervall and powers up the whole board. The Atmega does its job and sends an signal to turn off to the TPL5110 chip, when done.
    Timing is only accurate to a few seconds (details see the datasheet!) due to being set by a resistor. But for this type of logger, the exact time is not critical.
    The EEPROM will be a 2Mbit one, the sensor is the really small TMP112. Just recently @Edward Mallon posted a guide to use an onboard crystal/oscillator to measure temperatures. For this small logger this looks like an cool approach to save some money on the sensor (around 90 cents). But it needs per-logger adjustments, so I am not sure yet...
  • 12 – soldering 1.6x1.6mm (SOT-563) sensors to leads
    Jan10/08/2018 at 18:23 4 comments
    TL;DR it is possible by hand
    HOW TO
    Here is my first try soldering 0.15mm (0,0059") wire to a TMP112 sensor. These come in an SOT-563 package with 0.5mm pitch.
    Copyright ON-Semi
    I made a cutout in a piece of cardboard, glued it to a piece of aluminum (we know it's aluminium, right?) and tried soldering wires to it. Worked OK, though I had to use a really fine tip for that. Took me around 10 minutes.
    sketchy setup but it worked
    The main problem is, the wire lengthens a bit while soldering, so it easily slides off the pad. Should I need to solder a few of them I need to add a weight or spring to one side which compensates for that.
    directly after soldering
    After cleaning a bit, this is what I ended up with:
    Of course opposite pins are still connected to each other, but that will be corrected when doing my next tests with a better setup. I think I know how this will work much better...
    BTW: Cutting the leads in between with a side-cutter didn't work well (topmost contacts), using a cutter knife does a good job though:
  • 11 – final pictures
    Jan09/29/2018 at 13:11 0 comments
    Updated – 01.10.2018
    Here's a short video of the working logger.
    click to play in new tab (hosted @hackaday.io, not youtube)
  • 09 – it's alive!
    Jan08/27/2018 at 14:11 0 comments
    Update – 22.09.18
    I finally had the time to "fully" assemble everything. All things work as expected, RTC, EEPROM, LED, temperature sensor.
    A few components are extras and do not need to be placed!
    I will upload code snippets to test all the components, should anyone want to build that little thingy!
  • 08 – my own deadline + thoughts on suppliers
    Jan08/23/2018 at 06:30 0 comments
    Update 01.09.2018 – Project halted for two weeks
    Fortunately, the deadline has been pushed to October. This is great news, as I won't find any time working on it the next two weeks. After that I'll complete it and present my fully populated board. It's just soldering the EEPROM, RTC and a few passives anyway.
  • 07 – shitty TMP11x breakout boards
    Jan08/20/2018 at 20:38 2 comments
    As I need to try and connect up to four TMP112 sensors to my logger, I decided to make some breakout boards for them. Individual board will be around 6.5x3.5mm.
    Address can be changed to one of 4 hex-values by a multi-solder bridge. I did not do fancy panelizing, instead I just chose 0.8mm board and added silkscreen lines where I need to cut the boards with a Dremel or knife:
    [+/-/C/D] are the I2C connections, [1/2/3/4] is the address select solder bridge (connect one of them to the longer middle pad) and on the other side is the SOT563 pad with longer pads for easier hand soldering. I'll use a hot air station anyway.
    There's space around the lines so I can use up to 1mm cutting disks without damaging the traces.
  • 06 – PCB finalized again and ordered
    Jan08/20/2018 at 18:53 0 comments
    So, even "final" PCBs are never finished. Just slept over it a night and added this and that, removed this and that as well.
    I ordered them at @oshpark today. Material will be 0.8mm thick, with 2oz copper.
    I couldn't find a free to download model of the keystone 3012 battery holder, so I made one myself. This was quicker than registering somewhere and downloading it :)
    It's not 100% to spec, but the outer dimensions are correct, that's what I wanted.
  • 05 – PCB finalized
    Jan08/18/2018 at 13:53 0 comments
    Update 19.08.2018 – PCB is done
  • 04 – logger and sensor position
    Jan08/12/2018 at 13:23 0 comments
    Update 10.10.2018 - sensor glued into comb for test purposes
    Today I tried "melting in" a sensor into a pre-formed comb / foundation. The 4-stranded copper wire is wrapped around the stainless steel wire with 3 turns, then the wax foundation is laid on top of it. Later, the stainless wire is heated by putting some amps through it and the foundation sinks in a bit. (Haven't done this step here).
    What I have done is the wrapping part and aligning the test-sensor:
    Then I heated a small metal rod and pressed it on the sensor so it melts into the wax foundation:
    The other side looks like this:
    I added a drop of molten wax so the bees won't abandon the cell because of a foreign body. Hope that'll do :)
  • 03 – test placement of components
    Jan08/11/2018 at 08:18 0 comments
    Edit August 15th, 2018: Parts ordered.
    All parts are ordered and are expected to arrive in around two weeks from china. I hope to finish my board this weekend to send it to the fab as well, so I can start my first assembly.
    The final design will look quite different from the mock-up...
View all 11 project logs
greg davill wrote 10/01/2018 at 10:20 point
Neat project and nice execution!
