• How to create your own custom boot image
    Marcel Thürmer08/31/2018 at 17:43 0 comments
    I wrote a tutorial on my Github wiki, on how to create your own custom image for the Blueberry PI.
    Since the Allwinner V3s only has 64Mb of RAM, it is a very smart decision to customize your image to fit your needs.
    You only need a running Ubuntu / Debian (or other distros) on your PC.
    However some knowledge about the Linux terminal is required.
  • Successfully tested the parallel RGB Interface
    Marcel Thürmer08/25/2018 at 16:58 1 comment
    Since the V3s has a parallel RGB interface, it can directly drive LCD's like the  AT050TN33 (480x270) or other even bigger LCD's like the HW800480F-3E-0B-10 (800x480). The Blueberry PI is compatible with every 40 pin RGB LCD.
    Since many people were really interested in buying a Blueberry PI, I fixed some minor issues on the current PCB and ordered new PCB's. I will start selling the Blueberry PI on Tindie in the near future.
