1FINALIZING COMPONENTS REQUIRED
- PlutoX
- PrimusX board
- PrimusX breakout board
- High Sensitive Microphone Sound Sensor Detection Module
- Resistor
- Capacitor
2GETTING THE HARDWARE READY
- Clap sensor need a 5V Input.
- Solder a berg strip to Connect the sensor to Breakout board
- Connect the Ground and 5V in supply
- Connect the Digital Out to any of the ADC pins. (I am using pin 13)
3GETTING THE SOFTWARE READY
- Github link to read the sensor data
- Convert the input data to equivalent voltage
- Set some specific threshold, If the sensor data is greater than a threshold ARM the drone and Set a Specific height to take off.
