Automated mouse homecage two-bottle choice test v2
Version 2: A homecage-fitted apparatus for automated, photobeam-based detection of licks in a two-bottle choice task.
Public Chat
This is an update to the original automated mouse two bottle test.  It performs the same function as the last version but it has been revamped to make it battery powered and include a screen to display data.  It lasts about 2 weeks on the battery, making it a truly mobile drinking monitor!
This design fits into our colony caging (Allentown NextGen) while on the rack, for different caging you may have to modify the 3D design.
Sipper-053122.zip
Updated code with sleep enabled to get more battery life, more accurate sensing, and better control over outputs. Also fixes SD card bug with older Adafruit SAMD board definitions.
x-zip-compressed - 10.77 kB - 05/31/2022 at 19:47
Download
SipperLibraries102420.zip
Libraries to use with Sipper-102420Stable code
x-zip-compressed - 4.09 MB - 08/24/2021 at 19:05
Download
Sipper base.stl
3D design file for the main piece
Standard Tesselated Geometry - 319.22 kB - 07/16/2019 at 12:08
Download
Sipper cover.stl
3D design file for the cover
Standard Tesselated Geometry - 38.56 kB - 07/16/2019 at 12:08
Download
Mini sipper tube holder.stl
Mini single tube holder
Standard Tesselated Geometry - 67.66 kB - 08/11/2019 at 04:39
Download
View all 9 files
View all 14 components
  • Updated firmware
    Lex Kravitz08/19/2021 at 14:35 0 comments
    We updated the Sipper firmware (see files area for Sipper-102420Stable.zip)!  The new features/changes are:
    1. It puts the processor to “sleep” in between each mouse interaction.  This results in a ~2x increase in battery life.
    2. It has an additional lower power mode where it also turns off the screen whenever it’s sleeping.  To activate this, once you start a program hit “B” and it will say “DISPLAY OFF”.  This saves about 1mA which should add a couple days in theory (the processor sleeping in point #1 is more power savings).  The display will still turn on for a couple seconds whenever the mouse interacts with it.  You can hit “B” again to leave the display on full time again too.
    3. It has a more accurate way of measuring sipper interaction duration.
    4. A little circle appears on the screen next to each sipper when it is in use to help with troubleshooting
    5. You can hit “C” when a program is running to see the filename and elapsed time for the session.
    6. On the start-up screen you can hold “B” to set the date/time/sipper number as before.
    7. We added the ability to use an additional output:
      1. Pins A1 and A3 are programmed to go high whenever the sipper is broken (this was true in the old code as well).  You can use these to drive external stimuli, or log sipper interactions with ephys, etc. see: https://hackaday.io/project/160388-automated-mouse-homecage-two-bottle-choice-test-v2/log/153925-ttl-output-when-mouse-interacts-with-sippers
      2. We now added the ability to send output on a 3rd pin, dependent on the Left/Right Interactions.  The idea was to use this to control a foot shock as a specific probability to study compulsive behavior.  Ie: if he interacts with the Left sipper on 10% of the trials he gets shocked, while on the Right sipper on 30% of the trials he gets shocked.   To use this, on the start-up screen you can now hold “C” to set “probabilities” on the Left and Right sipper.  Based on these probabilities, the sipper will output a HIGH pulse on pin 12 for 1 second.
    8. This updated firmware has not been extensively tested beyond our lab,  please comment here if you discover any bugs!
  • Mini tube holder!
    Lex Kravitz08/11/2019 at 04:38 0 comments
    For a different project we needed a simple tube holder to fit in a cage without a wire rack.  The sipper design was perfect, and we printed this small part of it:
    This hangs over the cage edge like this:, providing a simple way to use a sipper tube as a water bottle, or for simple manual measurement.  STL in the files area!
  • Editable 3D design
    Lex Kravitz03/06/2019 at 16:04 0 comments
    The 3D design was developed in TinkerCAD and an editable design is available here:
    https://www.tinkercad.com/things/gPan0GUSNkd
    Please don't judge us! This device went though a very iterative design process so the current design build is a bit complicated.  We'll hopefully re-design this more simply and update in the future (or if someone does this please let us know so we can post better design files!).
  • Troubleshooting
    Lex Kravitz02/04/2019 at 17:03 0 comments
    This log is about troubleshooting.  I'll add to it as we identify troubleshooting issues.  Please leave a comment if you know of any others!
    1) Sipper position
    While the electronics on the sipper device are pretty much bulletproof, we have noticed the position of the sipper tubes can shift a bit, so these should be checked carefully.  Specifically, it's possible for one tube to move out of the detection beam, which obviously introduces error into the experiment.  Here's an example, with the red line estimating the position of the detection beam.  The sipper on the right is positioned too far from the detection beam.
    We're working on updating the 3D design to reduce this possibility, but either way it's a good idea to check this before putting them in with mice!
  • Quick video
    Lex Kravitz02/01/2019 at 19:37 1 comment
    Quick video of sippers in action, showing water vs. chocolate
  • Rat v2.0 design coming soon!
    jkhokhar11/07/2018 at 19:06 0 comments
    We are getting closer to a finalized design for use with rats v2.0. Hope to upload it all here by the end of the month. This version has a much smaller footprint compared to the previous version. We are just working on finalizing the mounting via suction cups and the code for the volume measurement. Stay tuned!
  • Modification for rats!
    Lex Kravitz10/23/2018 at 23:07 0 comments
    Dr. Jibran Khokhar at the University of Guelph has modified this sipper device to measure liquid intake in rats.  Really cool!  He also added an eTape liquid level monitor to measure actual intake as well as the number of interactions with the sipper.  He plans to put the full design online soon, but in the meantime here are some photos!
  • TTL output when mouse interacts with sippers
    Lex Kravitz10/06/2018 at 17:12 0 comments
    We made a slight update to the code and design to give the sippers 2 TTL output connections that can sync sipper interactions with external equipment such as a fiber photometry or ephys recording system.  There is now an optional step in the instructions for which pins to solder these BNC connectors (to A1 and A3), and an update to the code to enable these pins as outputs.
  • Homecage validation!
    Lex Kravitz09/16/2018 at 14:33 0 comments
    We made some tweaks to the 3D design to allow the sipper device to mount onto rack-mounted vivarium cages.  This will allow for higher-throughput experiments.
  • First validation!
    Lex Kravitz08/15/2018 at 15:06 0 comments
    Earlier this week we assembled a sipper device and filled one tube with water and the other with diluted (1:2) chocolate ensure. We placed it in a mouse cage overnight.
    Some glamour shots of the device in a mouse cage:
    The next morning, guess what??  One tube was completely empty... the other untouched
    First data!
View all 14 project logs
  • 1
    Download Arduino IDE
    Before starting with building anything you should make sure your computer can communicate with the Adalogger M0 board and that you can flash sketches to it.  This should reduce frustration later.  Start by installing the Arduino IDE.
  • 2
    Install Arduino boards files to let the Arduino IDE flash the Adalogger M0
    The Adafruit M0 Adalogger board is not natively supported by the Arduino IDE.  Follow instructions here to install support for this board in the Arduino IDE.  After completing these steps make sure you can flash the example sketch "Blink" to the Adalogger board before continuing.  To do this, open the Blink example in File>Examples>Basic>Blink.
    "Double-click" the small physical button on the Adalogger board to put it in bootloader mode, set Board to "Adafruit Feather M0" and port to the correct COM port and click upload (the right arrow at the top of the Arduino IDE). You should see "Upload complete" in the bottom feedback window and the red LED on the board should blink once per second.
    Congratulations, you have configured your Arduino IDE and uploaded a sketch to the Adalogger!
  • 3
    Install relevant libraries
    The Sipper device requires the following libraries:
    #include <Adafruit_SSD1306.h>
    #include <Wire.h>
    #include <RTCZero.h>
    #include <SPI.h>
    #include <SdFat.h>
    #include <Adafruit_GFX.h>
    #include <TimeLib.h> //include the Arduino Time library
    #include <stdio.h>  // include the C++ standard IO library
    These are available for download as a single zip file from the files area, or you can search for them online.  Download the zip file and extract into your Arduino/libraries directory.  When you're done it should look something like this:
    If this doesn't work, or you'd prefer to install libraries a different way there are instructions here for how to manually add libraries.
View all 15 instructions
Flora D'oliveira Da Silva wrote 03/27/2024 at 21:51 point
Hello,
I keep having sippers randomly turning off or resetting themselves during the experiment... If anyone as a clue on why is that happening and how to fix this that would be really helpful
roz.quincey wrote 12/20/2022 at 01:17 point
Hello,
I am hoping to use the sippers in conjunction with an infusion pump. Is it possible to use the BNC test lead capability to pair a lick to an infusion in a fixed ratio - e.g. 1 lick = 1 pump of infusion?
Thanks so much :D
Will Fan wrote 11/22/2022 at 17:53 point
Hello,
I'd like to use the sippers for 20-minute choice tests in water-restricted mice. Has anyone done anything like this before?
To train mice to consume their daily fluid intake within the 20 min window, I water-deprived them for 24 hours and placed them in an arena with just the sipper for 20 minutes. However, none of my mice drank during this habituation trial. Should I do overnight habituation in the home cage first?
Another question:
I tested the sippers by poking the valves with a rod, and I noticed that sometimes a drop of water was released by my poke but the contact was not registered. I'm concerned that some sippers may have differential sensitivity on the left and right sides, which would interfere with the result. Do you have any tips for making the detection more reliable?
Thanks!
Flora D'oliveira Da Silva wrote 03/27/2024 at 16:33 point
Hello,
I've noticed that mice tend to first be anxious around the device so habituation to it seems necessary to me to get reliable results. I place the device in their home cage 1hour per day for a week before starting running tests. I've noticed that females "burry" the device with bedding the first 3 or 4 habituation sessions which is why I do at least a week. But one or two overnight sessions could totally work.
Ally Nowlan wrote 09/20/2022 at 20:47 point
Hi,
I'm having a similar "Check SD card!" issue as users below. I've downgraded to 1.5.5 Adafruit SAMD package, am using the most recent Arduino SAMD package, and am using a SanDisk 64GB microcard. I couldn't find the "Check SD" code in the default library as a previous user suggested. I don't actually want to store licking data on the card and am planning on using the device with a fiber photometry recording system (neurophotometrics FP3002). Any suggestions would be greatly appreciated. Thanks!
Kai Poletti wrote 09/14/2022 at 19:31 point
Hello!
What type of plastic are you printing with? The PLA we're trying to use is too jagged. We were suggested to find someone to print with resin, but it's way more expensive and I wanted to see what you all printed with before I tried to order another prototype with a different plastic.
Thanks!
ShannonMThompson wrote 07/27/2022 at 16:53 point
Hi all,
First awesome design set up! Thank you for making this available for all. I'm building my first set of these for our lab and had a quick question bout the one of the connectors. Adafruit seemed to have the right one (2.0mm Pitch 3-pin Cable Matching Pair - JST PH Compatible), though you would have to by the connecter from them as well. I was wondering if anyone has tired this? We have way to many hoops to jump through to order from new suppliers and if I can use the one Adafruit with out issues I would like to get it from them. Any thoughts on this? Much appreciated for any discussion.
Andre Maia Chagas wrote 06/21/2022 at 14:35 point
hi folks,
thanks for putting this design out in the open!
I had some trouble 3D printing the current model and also changing the design... so I took a bit of time and tried to make an almost 1-to-1 copy of your design, but with less blocks and also in a way that it is easier to 3D print untested design (printing the first model now) here https://www.tinkercad.com/things/bckWmv0TgYV
gerramosfl wrote 02/05/2022 at 15:42 point
Hi! Great Project! I´d like to know how to make the device check the sippers every second instead of every 10 seconds. How Should I set the code up?
Tiange wrote 01/05/2022 at 16:46 point
Hi, I am trying to make these electronic parts for 2BC choice, and I have some problems.
1. I can see 'press to start' on the screen, but I cannot press ABC to change the date set
2. when I press A to start, I can see 'left and right,' but they did not count; I am not sure the problem is because the soldering parts are wrong or the lines connected to the two photo-interrupters is incorrect. I am wondering whether I can get some instructions for the electric lines connection between M0 to 2 photo-interrupters.
Appreciate!
Michael wrote 01/03/2022 at 19:40 point
The proper contact for the valves is this very nice person:
Tiffany Dunmire
Operations Coordinator
Tiffany.Dunmire@AvidityScience.com
Hydropac, LLC
1361 Brass Mill Road, Suite J
Belcamp, Maryland 21017
o:
+1-410-306-6345;3001
e:
w:
www.AvidityScience.com
Michael wrote 12/17/2021 at 16:53 point
So, official update to the previous:
1. Used 1.5.5 Adafruit SAMD package and most recent Arduino SAMD package
2. Used hackaday library paired with appropriate stable version of code
3. Used a SanDisk 4GB card
Everything worked in this configuration.
If you're not sure about the problem and getting the Check SD card! message, run the "Check SD" code from either the default library or the updated one, and use the serial COM port output window to see what happens. Even if your SD card is formatted in FAT16 (<4GB) or FAT32 (>4GB), it might not work, as I found to my annoyance. If the Feather isn't recognizing the card architecture in CheckSD, it won't recognize it in Sipper.
Michael wrote 12/14/2021 at 00:40 point
I'm having the "Check SD card!" issue as well. Installed the most recent stable version of SipCounter using SAMD version 1.5.5, 1.5.1, as well as the most recent SAMD build (1.7.5) using an SD card formatted using FAT32 as well as FAT16. I upload SipCounter to the Feather M0, attach the OLED, and... all it does is flash the LEDs and tell me to check the SD card. Any thoughts?
Update: I can flash the SetClock and it shows a time display, and "Reflash sipper code." When I reflash the sipper code, it goes back into "Check SD card!" This is somewhat frustrating.
Update 2: So... Don't buy off-brand microSD cards. The SanDisk 4GB card worked straight out of the box.
Lex Kravitz wrote 12/14/2021 at 22:31 point
Hey Michael - this stuff is frustrating but we can figure it out.  You should use the latest Arduino SAMD boards package, with version 1.5.5 for the Adafruit SAMD package. For the library versions you can use the versions in the files area.  https://hackaday.io/project/160388/files
Mariam Melkumyan wrote 01/15/2022 at 17:22 point
Hello. I am using the latest version and a SanDisk 8GB card and I am getting the check SD card error. Could you please help? I tried the older version and a different SD card and it still didn't work. It goes away when I load the clock but once I reflash the program, it goes back to check sd card.
Update: I downgraded the board to version 15.5 and it worked!
Michael wrote 11/24/2021 at 19:24 point
Our mouse cages aren't exactly compatible with this design. Does anybody have a version that's editable with Solidworks? TinkerCAD gives me hives.
Lex Kravitz wrote 12/02/2021 at 20:33 point
Our version was designed in TinkerCAD so that's all I have, if you find one in a different format please post it back here!
Michael wrote 12/14/2021 at 01:13 point
When I get some time I can try to replicate the whole design in SolidWorks.
Emilie.doucet wrote 10/13/2021 at 09:57 point
Hi. I am currently trying to implement the two bottle choice test using the hydropac drinking valves in our lab for a preference sucrose test. However all the valves connected to the Falcon with the sucrose are eaten by the mice in one night. Would you have a solution? Many thanks
Lex Kravitz wrote 12/02/2021 at 20:32 point
Hi unfortunately no, we have not experienced this and we use them for many weeks straight.  We use C57Bl6 mice, is it a strain thing?
Letícia Pichinin wrote 10/05/2021 at 01:08 point
Amazing project!!!
We are running a homemade lickometer at the lab too!
But I am having some trouble to analyze the bouts and so, are there any tips? Should I make the dataset binary so I can make those nice "barcodes" graphs?
 @Taylor Woodward  *Yes, here the mice eat the plastic from everywhere, eventhough their cages are enriched
Lex Kravitz wrote 11/05/2021 at 00:41 point
Cool!  For analyzing the data from these sippers check out SipperViz! https://github.com/earnestt1234/SipperViz
wakabayashi-kt wrote 06/11/2021 at 22:53 point
Great project! I'm trying to troubleshoot to see if I have a hardware or some other problem. When the unit was fully assembled, the number in the #: line start incrementing really quickly for both sides, even without the photo detector unit connected. I ended up desoldering all of my connections, but even without any attachments the #: line on both left and right sides increment very quickly (several per second). I am assuming that with no inputs there should be nothing incrementing from that side, am I right? Thanks!
Lex Kravitz wrote 09/18/2021 at 13:15 point
Hi wakabayashi-kt!  If the photo interrupter is not connected it will register as being "triggered", as these photointerrupters register HIGH when they are open, and LOW when closed.  So if you disconnect the photointerrupter (or if it's wired up incorrectly) it will act like it's always being triggered.  So your experience is what I'd predict. Hope this helps!
Milán wrote 07/13/2020 at 17:21 point
Great project! Thank you for these directions!
I need help troubleshooting: Everything went well until I plugged in the battery. Nothing showed up on the screen at all, but there is a blinking red light and a blinking green light coming from the feather. Nothing appears on the screen when I press A, B, or C buttons, but the reset button pauses the light. I am pretty sure I soldered the wires into the right places according to the instructions given. Any suggestions?
Meaghan Creed wrote 07/30/2020 at 03:08 point
Hi - what happens when you flash the time-setting code (SipCounter-SetClock)? Does it have a problem with the screen not showing anything after flashing that?
Meaghan Creed wrote 07/30/2020 at 03:13 point
The blinking red and green lights suggests it could be an SD card error...(although usually the code would tell you that on the screen "Check SD Card!")  You could ensure you're using the libraries here on the hackaday page.
Taylor Woodward wrote 04/23/2020 at 11:10 point
I'm currently working on trying to implement these in our lab- have you had any issues with mice chewing on the plastic while they were housed continuously in the home cage? My animal care facility was wondering.
Taylor Woodward wrote 07/27/2020 at 18:07 point
Follow up: I realized this was in the paper actually.  In our experience they chew the hydropac valves a bit, but it wasn't insane especially if the epoxy was extended to the edge of the valve lip.
Meaghan Creed wrote 07/30/2020 at 03:04 point
Thanks for the tip!  While some mice are prone to chewing (we've observed this to be a trait of some individual mice), we've had the majority of mice in our study successfully drinking out of the same tubes for multiple consecutive weeks, without chewing or otherwise destroying the valves.
jeph wrote 03/16/2020 at 17:02 point
really useful project. Im having trouble getting the sd card to work. all I get is "check sd card"
on the screen. all files were good all uploads are successful ? Please any help appreciated.
Meaghan Creed wrote 07/30/2020 at 03:23 point
Hi - sorry for the delay.  If you've had the issue with multiple SD cards, it could be an issue with the Adafruit SAMD Boards package, which you install in the Boards Manager.  When Adafruit released version 1.5.6 something changed in how the Adalogger communicates with the SD card.  You can work around it by downgrading your Adafruit SAMD Boards package to 1.5.5.  To do this, go to the boards manager, find the "Adafruit SAMD Boards" package and click on the "Select version" drop down menu.  Then choose 1.5.5 and install that.  You should probably re-start the Arduino IDE after that, and then see if you can flash the code.  Can you post back if that solves it?
This suggestion is from @Lex Kravitz, who confirmed that versions including 1.5.5 and below work with his code, while versions including 1.5.6 and above do not (Adafruit is on version 1.6.0 currently).  He posted on the Adafruit forum about this but so far we haven't figured out why this is happening.
bestk1 wrote 02/19/2021 at 15:52 point
Hi there, I'm also having this issue but I've triple checked that my Adafruit SAMD Boards package is version 1.5.5. and the unit is still presenting the "Check SD Card" error when I connect it to battery. It says that it's successfully flashing the programs to the Adafruit board, so do you have any other suggestions for resolving the "Check SD Card" error? I would love to get this to work because it seems like a really great behavioral apparatus!
Dan Covey wrote 05/27/2021 at 23:21 point
I am having the same problem. I have version 1.5.5 but I still get "Check SD Card" when I flash the sipper code. Thanks.
Lex Kravitz wrote 12/02/2021 at 20:34 point
Did this work?  If not please send me an email and we can try to work it out over email.  It could be a library issue, did you try installing the Arduino libraries from the files area?
Michael wrote 12/14/2021 at 03:04 point
Yep, I'm having the same issue as all of the people below.
mwblab wrote 04/27/2019 at 01:46 point
Very cool project! I didn’t see this in the components list - what is the red part between the falcon tube and the supper valve?
Lex Kravitz wrote 11/30/2019 at 22:24 point
Sorry for the delay - that was a little 3D printed ring we were using early on.  It's not necessary so it's not in the components list.  We found the best way to attach the valves to the sipper tube is hot glue - just melt it all around and push the valve into place!
