I finally managed to make the Noise Nugget play notes from MIDI commands over USB!
I took me some time because there was no USB support in the driver library I'm using, so I had to write a USB stack from scratch :)
The synth code is based on ada-synth-lib from my friend Raphael. I used it to make a simple pulse wave sound with ADSR envelope.
