AEMSUCA R3 makes your battery life longer
A project log for Solar harvesting into supercapacitors
This is a 0.8x0.6 inch board with AEM10941 solar harvesting IC charging supercapacitors
jasper-sikkenJasper Sikken • 12/26/2020 at 20:17•0 Comments
In revision 2 the PCBA was pre-configured to output 3.3V and 1.8V on the HV and LV outputs and these levels could not be adjusted. Now in Revision 3 you can lower the HV output to 2.5V using a solder jumper. When R4 is placed the HV output is 3.3V. When R3 is placed the HV output is 2.5V
In my board R3 and R4 define CFG[0] is 1 or 0, see the table below (from E-peas AEM10941 datasheet)
If your processor can run on 2.5V then you can run the supercapacitors down to 2.8V instead of 3.6V. This is a big battery lifetime  increase for your application.
