this is amg8833 sensor running on an Arduino uno equivalent with software. it uses 23878 bytes flash and 1068 bytes ram. i'm working on software that enhances detail and outputs resolution so far at 64x64 resolution with some built in filtering to reduce noise, and increase detail and auto temp. shown in image is my leg, the temp and surrounding temp with a built in color bar to show range. it is auto ranging temp. it is doing about 10 frames a second at 64x64 detail with subsampling, and filtering features enabled.
Portable Network Graphics (PNG) - 360.78 kB - 09/23/2018 at 10:49
Preview
Download
new housing for device. updates on thingiverse
https://www.thingiverse.com/thing:3050327
this has a base that has better balance and is resistant to tipping.
Portable Network Graphics (PNG) - 49.65 kB - 09/16/2018 at 07:06
Preview
Download
this is image of my hand from 64x64 and enhanced mode of thermal cam sensor amg8833 there are still artifacts that i need to remove. files are now removed and linked to locations in github, it allows for proper tracking of updates.
Portable Network Graphics (PNG) - 260.07 kB - 09/09/2018 at 06:56
Preview
Download
thermal_cam_9_8_working_bugs.zip
Newer versions with bugs fixes are on github
sketch uses 952 bytes ram 26950 bytes flash, 64x64 sub sample. still fixing bugs, have some block effects, so i think there are errors in how the color information is handled. still shrinking code, and reducing ram. uno has about 5-6k to program other functions.
Zip Archive - 370.78 kB - 09/09/2018 at 06:47
Download
