added ability to calibrate temp easy
A project log for spi write up to 64 colors at a time on Arduino!
amg8833 equivilent sensor thermal cam is a perfect example of how to write faster with spi lcd displays. 128x128 sample fast on Arduino.
jamesdanielvjamesdanielv 11/30/2018 at 22:030 Comments
more of a fine tune offset
https://github.com/jamesdanielv/thermalcam/blob/updates-(possibly-unstable)/Thermal_cam_ili9341_64x64_V4.zip
just change the setting tempOffsetFloat 2.0 to a lower or higher number then upload sketch.
tempOffsetFloat is in deg C.
