FPGA
I already received my first FPGA board - Tang Nano 9k (it is presumably the best in terms of bang for the buck, with more than 8 thousand LUTs for slightly less than 20 USD, including shipping). The board itself is fairly small and have just a pair of buttons and 6 leds for user interaction, as well as fair number of pins. To have a more hands-on experience, I decided to make an extension board for it, which could also serve as test harness for CPU components implemented with this FPGA.
And I already started my journey into Verilog, making small projects utilizing the prototype extension board mentioned above.
ISA updates
Now, to the CPU itself -- I am now working on some updates to ISA after a closer look of what I have to date. Mostly updates are concerning with redoing bit shifting circuitry, and some slight bit rearrangements in encoding the instructions for more clarity.
I am also thinking about addressing, mostly if there is a need of making it 32 bits. In theory such big address space is good, but given the target speed and just physical availability of SRAM ICs, it looks like 24 bit for addresses would be enough (16MB). This also will make Address Adder narrower, and overall somewhat more manageable wiring for Address Unit. Implementation in FPGA somewhat relaxes this restriction, but I still want to eventually make the real physical processor using discrete logic chips, and this phase of implementing it on FPGA should strive to resemble the intended form as close as possible.
Discussion of bit shifts and rotations
Regarding shifting operations -- in current design there is a shifter circuit that can do 1-bit shift operations, and barrel rotator that is able to rotate bits in word to arbitrary amount in range 0..15 bits. The rotator was an afterthought, and was added mostly because there were unused slots in selector for ALU operations. The functionality and usefulness of this arrangement is questionable. Thus, returning after the years I had not had an attention to this project, I saw an opportunity of improvement in this regard -- to fuse shifter and rotator into one more complex circuit -- the Funnel Shifter, as I found afterwards it is called. This should be able to make arbitrary shifts and rotations in one cycle, and with additional temporary register there is possibility of extending these operations to multi-word shifts / rotations.
Right now I am working on designing it, simulating, and this will be the first CPU part to be implemented on the FPGA.
Plans for hardware build
Afterwards I plan to build up the decoder FSM, ALU, registers and the rest of the CPU; It seems like this whole CPU can be mapped / implemented on the FPGA chip I have with room to spare, so in the end I will have a piece of functional hardware with which I can play further. The Verilog code I intend to write will also serve as blueprint for building with actual logic chips.
Pavel
