Instruction translator board for ALU/RegFile
A project log for ECM-16/TTL homebrew computer
16 bit Computer made from ttl logic chips
pavelPavel 08/16/2021 at 15:380 Comments
This board with a handful of chips serves as control interface between Calculating Core (ALU/RegFile assembly) and the rest of CPU.
It mostly does decoding of ALU instructions into ALU control signals, constant value, and register addresses. It also takes in ~R, clk, and a couple of control signals from Control Unit (yet to be developed) and distributes them to Calculating Core accordingly.
Here is the board:
And here are a couple views of testing process for the whole calculating core:
