What I want from my power supply is to be able to drive a nixie clock, so more than 4 tubes.
So the key requirements are:
- DC-DC boost converter
- Vin 5 or 12 V
- Vout around 170 V
- Iout around 50 mA
Now, the idea is to build a boost converter and not a flyback one. This is because for me it is more challenging the boost type and there is no need to use a transformer. In the future maybe I will design also a flyback transformer, eventually involving voltage multiplier stages.
Some inspiration came from:
- This project here on hackaday
- This design based on MAX1771
- A very well made project on how to build the full clock, including the power supply
- Another already available design based on MC34063
- The great design step-by-steb explained by surfncircuits
the idea is to take a lot of inspiration from these great guys, but building something new. So I will use a different IC from the ones that are commonly used in the examples online.
