Si5351 built
A project log for X-UHF
X-UHF is a project to build a low cost RF prototyping system for experimenting in VHF and UHF bands.
colin-alstonColin Alston 08/19/2018 at 20:280 Comments
Just a quick photo-op of the completed SI5351 bolted onto a SA612 mixer.
This 5351 design uses a big external crystal because I don't have the tiny SMD ones, but when I do another component order I'll get some of the ones used in the Etherkit 5351 breakout and send the board to a PCB fab. For now this is fine for a test to see if the design makes sense.
