This is a dual port EEPROM that can be interfaced through an NFC antenna or Qwiic connector.
The board is 15mm X 15mm
It allows you to create an NFC tag that can be updated over I2C.
WIth standard NFC data formats you could share wireless connection details, URLs or contact information.
It can also be used for two way communication with a custom phone app.
greg
Bob Coggeshall
Kumar, Abhishek
burkethos
The power output is only wired to an LED, not the Qwiic connector. The device is an I2C slave only.
It is basically an NFC tag that can be programmed or read over I2C through the Qwiic connector. For example, you could create an NFC tag that can be remotely updated. A restaurant could rotate random wifi passwords and share them through the NFC tag.
WIth a custom phone app you can implement two way communication with an mcu.
