Redox codename Ultron pt.11
A project log for Redox keyboard
The Redox project is an open-source, QMK (Quantum Mechanical Keyboard Firmware) powered, ergonomic split mechanical keyboard.
mattia-dal-benMattia Dal Ben 10/20/2018 at 10:440 Comments
Battery usage quick update and Redox Wireless release.
Here's the latest measurements. The batteries seems to have stabilized around these values, I might need to find a multimeter with higher resolution to better check the voltage.
Left hand voltageRight hand voltage
30/09/20182.983.04
06/10/20182.982.99
13/10/20182.962.97
20/10/20182.972.98
I now feel sufficiently confident with the power consumption to release the PCB files as open source on the Redox project repository. Here you'll find:
I'm also merging the Redox firmware sources into the QMK firmware project. I'll still monitor the battery usage in the following weeks and report regularly.
See ya next time!
