Hack a Day Menu
  • Projects
  • Lists
  • Contests
  • Stack
  • More
    • Blog
    • Events
    • Hackerspaces
    • Profiles
    • 2018 Prize Entries
    • Store
    • Jobs Board
  • Sign up
  • Log In
E1T tube tester
Self contained board to test the E1T counting vacuum tubes.
consciousfleshconsciousflesh
Following Follow project
Liked Like project
Become a Hackaday.io member
Not a member? You should Sign Up.
Already have an account? Log In.
Forgot your password?
or use these profiles to log in
Sign up with Github
Sign up with Twitter
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
1 followers
  • Description
  • Details
  • Files 3
    • View all
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
91
0
1
2
Team (1)
  • consciousfleshconsciousflesh
Join this project's team
hardware
completed project
Vacuum tube
This project was created on 08/20/2018 and last updated 6 months ago.
Description
The E1T tube is a marvel of the vacuum tube era. It was over 40 times faster than the dekatron tube and displayed the result directly. The E1T tubes were used mostly in scalers used in nuclear physics research . If you want to learn more about the tube check this page : http://www.dos4ever.com/trochotron/TROCH.htmlThe tube needs a bit of electronics to work : the reset circuit and the bias and feedback circuits . It also needs high voltage (300V) and the heater voltage (6.3V) . There are several designs of the E1T tube testers on the internet , but all of them require powering them from external , high voltage power supplies. To make it a bit simpler I designed a self contained tester which has all necessary electronics on one board. All it needs is a 20-24V DC power supply.
Files
E1T_tester.zip
Set of GERBER files for tester's PCB
Zip Archive - 35.84 kB - 08/20/2018 at 20:15
Download
E1T_tester.bom
Bill of materials
bom - 1.52 kB - 08/20/2018 at 20:15
Download
E1T_tester.pdf
Tester schematic
Adobe Portable Document Format - 20.83 kB - 08/20/2018 at 20:15
Preview
Download
Project Logs
Collapse logs
  • E1T tube operation
    consciousflesh • 08/20/2018 at 20:27 • 0 comments
View project log
Log In/Sign up to comment
Become a member
In order to follow projects & hackers or give likes
you need to create an account.
Already a member?
1.2k
44
5
Pulsed-discharge power system suitable for welding, plasma cutting, laser driving, and other high-power equipment.
Project Owner Contributor
Pulsed Capacitive Discharge Power Supply
Jakob WulfkindJakob Wulfkind
27.3k
143
50
A nice little tube amplifier that is low voltage but still has enough power to drive a speaker at a reasonable volume
Low Voltage All-Tube Amplifier
MarcelMarcel
  • The 2016 Hackaday Prize
222
1
1
An EHD Thruster as a modular flexible surface you can add to your own vehicle's airframe.
Practical EHD Thruster Design Pattern
outlawpoetoutlawpoet
Going up?
© 2019 Hackaday
Yes, delete it Cancel
You are about to report the project "E1T tube tester", please tell us the reason.
Send message
Remove Member
