EmotiGlass Breadboard Prototype Code v9.0
A project log for EmotiGlass
A new device to change the user's emotional perception of reality.
david-prutchiDavid Prutchi 08/22/2018 at 20:010 Comments
The code is running (but may still contain some bugs and leftover debugging/engineering lines), and control is via BLEusing theBluefruit Control Pad running on the iOS Bluefruit app.
Here is the prototype Arduino code to run the EmotiGlass breadboard:
*  EMOTIGLASS BREADBOARD PROTOTYPE LIQUID-CRYSTAL GOGGLES  *
(c) 2018, David Prutchi and Jason Meyers
Licensed under the MIT License
Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated
documentation files (the "Software"), to deal in the Software without restriction, including without limitation
the rights to use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of the Software,
and to permit persons to whom the Software is furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO
THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS
OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR
OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
ABOUT THIS PROGRAM:
Runs on Adafruit Feather M0 Bluefruit
Uses two DOGM128E-6 LCD displays made by "Electronic Assembly" and two small liquid-crystal shutters
driven by two MCP4725 digital-to-analog converters through DC-AC converter.
Control is via Bluefruit Control Pad running on iOS Bluefruit app
This version implements:
  Mode 1 = Lateralized occlusion
  Mode 2 = Cardiac-synchronized lateralized occlusion
  Mode 3 = Automatic light-controlled sunglasses
v.9 Adds control of two MCP4725A1 DACs to control contast of side shutters
#include <Arduino.h>
#include <string.h>
#include <SPI.h>
// DOG128E-6 LCD display
#include <dog_7565R.h>  //Library for DOG128E-6 displays (dog_7565R is the LCD controller)
// Adafruit BLE
#include "Adafruit_BLE.h"
#include "Adafruit_BluefruitLE_SPI.h"
#include "Adafruit_BluefruitLE_UART.h"
#include "BluefruitConfig.h"
// Asafruit MCP4725 digital-to-analog converters
#include <Wire.h>
#include <Adafruit_MCP4725.h>
*  Pin connections between LCDs and M0 Feather Board:             *
*  LCD           Arduino                                          *
*  40 (CS)       Specific to LCD:   Right Front 10, Left Front 12 *
*  39 (Reset)    5                                                *
*  38 (A0)       9                                                *
*  37 (SCL)      SPI SCK                                          *
*  36 (SI)       MOSI                                             *
Available functions in dog_7565R (LCD controller) Library:
  void initialize  (byte p_cs, byte p_si, byte p_clk, byte p_a0, byte p_res, byte type);
  void clear       (void);
  void contrast    (byte contr);
  void view        (byte direction);
  void string      (byte column, byte page, const byte *font_adress, const char *str);
  void rectangle   (byte start_column, byte start_page, byte end_column, byte end_page, byte pattern);
  void picture     (byte column, byte page, const byte *pic_adress);
  Use of rectangle
  Description:Draws a filled rectangle on the screen. The filling is given through the pattern byte
  Name:void rectangle (byte start_column, byte start_page, byte end_column, byte end_page, byte pattern);
  Vars:start column (0..127 / 0..131), start page (0..7 / 0..3), end column (0..127 / 0..131), end page (0..7 / 0..3), pattern-byte to fill area
//Define operating mode
int mode=1;
    APPLICATION SETTINGS
    FACTORYRESET_ENABLE       Perform a factory reset when running this sketch
                              Enabling this will put your Bluefruit LE module
                              in a 'known good' state and clear any config
                              data set in previous sketches or projects, so
                              running this at least once is a good idea.
                              When deploying your project, however, you will
                              want to disable factory reset by setting this
                              value to 0.  If you are making changes to your
                              Bluefruit LE device via AT commands, and those
                              changes aren't persisting across resets, this
                              is the reason why.  Factory reset will erase
                              the non-volatile memory where config data is
                              stored, setting it back to factory default
                              values.
                              Some sketches that require you to bond to a
                              central device (HID mouse, keyboard, etc.)
                              won't work at all with this feature enabled
                              since the factory reset will clear all of the
                              bonding data stored on the chip, meaning the
                              central device won't be able to reconnect.
    MINIMUM_FIRMWARE_VERSION  Minimum firmware version to have some new features
    MODE_LED_BEHAVIOUR        LED activity, valid options are
                              "DISABLE" or "MODE" or "BLEUART" or
                              "HWUART"  or "SPI"  or "MANUAL"
    #define FACTORYRESET_ENABLE         1
    #define MINIMUM_FIRMWARE_VERSION    "0.6.6"
    #define MODE_LED_BEHAVIOUR          "MODE"
// Create the Bluefruit object
/* ...hardware SPI, using SCK/MOSI/MISO hardware SPI pins and then user selected CS/IRQ/RST */
Adafruit_BluefruitLE_SPI ble(BLUEFRUIT_SPI_CS, BLUEFRUIT_SPI_IRQ, BLUEFRUIT_SPI_RST);
// DAC Control
Adafruit_MCP4725 dac;
// A small helper
void error(const __FlashStringHelper*err) {
Serial.println(err);
  while (1);
// function prototypes over in packetparser.cpp
uint8_t readPacket(Adafruit_BLE *ble, uint16_t timeout);
float parsefloat(uint8_t *buffer);
void printHex(const uint8_t * data, const uint32_t numBytes);
// the packet buffer
extern uint8_t packetbuffer[];
int button=0;
// define LCD and liquid crystal shutter control pins
int rightfrontCS = 10;  // right front LCD chip select
int rightsideCS = 11;   // right side (peripheral vision) shutter select
int leftfrontCS = 12;  // left front LCD chip select
int leftsideCS = 13;   // left side (peripheral vision) shutter select
// define plethysmography sensor power pin and Arduino analog input pin for plethysmography sensor
int plethPin = A0;  // Analog output pin for plethysmography sensor
int plethPower = 0; // Pin use to power plethysmography sensor
//  define light sensor power pin and Arduino analog input pin for light sensor
int lightPin = A5;  // Pin for light sensor
int lightValue = 0; // Variable for light sensor
// define analog input pins for UI potentiometers
int pot1Pin = A1;   // Pin for potentiometer 1
int pot1Value = 0;  // Variable for pot1 measurement
int pot2Pin = A2;   // Pin for potentiometer 2
int pot2Value = 0;  // Variable for pot2 measurement
int pot3Pin = A3;   // Pin for potentiometer 2
int pot3Value = 0;  // Variable for pot2 measurement
int pot4Pin = A4;   // Pin for potentiometer 2
int pot4Value = 0;  // Variable for pot2 measurement
// define variables
int change = true; // Variable for GUI change
int rightfrontContrast = 0;  // Variable for contrast of right eye front contrast (0...63)
int oldrightfrontContrast =0;
int rightsideContrast = 0;  // Variable for contrast of right eye side contrast (0...63)
int oldrightsideContrast =0;
int leftfrontContrast = 0;  // Variable for contrast of left eye front contrast (0...63)
int oldleftfrontContrast =0;
int leftsideContrast = 0;  // Variable for contrast of right eye side contrast (0...63)
int oldleftsideContrast =0;
int rightSpan = 0;  // Span of occlusion for right eye
int oldrightSpan = 0;
int rightfrontStart=0;  //Occlusion start for right front LCD
int rightfrontEnd=0;    //Occlusion end for the right front LCD
int rightsideEnable=0;  //Occlusion for right side shutter
int leftSpan = 0;  // Span of occlusion for left eye
int oldleftSpan = 0;
int leftfrontStart=0;  //Occlusion start for left front LCD
int leftfrontEnd=0;    //Occlusion end for the left front LCD
int leftsideEnable=0;  //Occlusion for left side shutter
int baroreceptor=0;   //Duration of occlusion after detection of baroreceptor activation
int plethValue = 512;           // holds the incoming raw plethysmography sensor data (0..1023)
int plethThreshold = 550;       // Plethysmography signal threshold for beat sensing
/* These variables are the output of the windowLCD function.  In a nice language I could have the function
 *  return multiple values, but not in C++ without using structures or pointers.
   Screw C++ !!  I'm declaring these as global variables and will use them only in windowLCD
int frontStart = 0;
int frontEnd=0;
int sideEnable=0;
dog_7565R DOG;
void windowLCD(int Span){
/* windowLCD - Function to calculates start and end of occlusion for LCDs
Input:
  Span (0..255)
Returns:
  frontStart
  frontEnd
  sideEnable
  sideEnd
   if (Span < 128) // occlusion is fully within front LCD
          frontStart=0;
          frontEnd=Span;
          sideEnable=0;
    else
          frontStart=Span-128;
          frontEnd=127;
          sideEnable=1;
// End of function windowLCD()
void updateLCDs(int rightfrontStart, int rightfrontEnd, int rightfrontContrast, int rightsideEnable, int rightsideContrast, int leftfrontStart, int leftfrontEnd, int leftfrontContrast, int leftsideEnable, int leftsideContrast){
updateLCDs - Function to Update LCDs
rightfrontStart = Occlusion start for right front LCD (0..127)
rightfrontEnd = Occlusion end for the right front LCD (0..127)
rightfrontContrast = Contrast for the right front LCD
rightsideEnable = Occlusion enable for right side liquid-crystal light shutter
rightsideEnd = Occlusion end for right side LCD
rightsideContrast = Contrast for the right side LCD
leftfrontStart = Occlusion start for left front LCD
leftfrontEnd = Occlusion end for the left front LCD
leftfrontContrast = Contrast for the left front LCD
leftsideEnable = Occlusion enable for left side liquid-crystal light shutter
leftsideContrast = Contrast for the left side LCD
    // Update Right Front LCD
    DOG.initialize(rightfrontCS,0,0,9,99,DOGM128);  // Reset pin is identified as '99' so that it doesn't reset LCDs
    DOG.view(VIEW_BOTTOM);  //default viewing direction
    DOG.contrast(rightfrontContrast);  //contrast (0..63)
    DOG.rectangle(rightfrontStart,0,rightfrontEnd,7,0xFF);
    // Update Left Front LCD
    DOG.initialize(leftfrontCS,0,0,9,99,DOGM128);  // Reset pin is identified as '99' so that it doesn't reset LCDs
    DOG.view(VIEW_TOP);    //alternate viewing direction
    DOG.contrast(leftfrontContrast);  //contrast (0..63)
    DOG.rectangle(leftfrontStart,0,leftfrontEnd,7,0xFF);
    // Update Right Side shutter
    digitalWrite(rightsideCS,rightsideEnable);    // Enable right side shutter
    // Update Left Side shutter
    digitalWrite(leftsideCS,leftsideEnable);    // Enable left side shutter
// End of function updateLCDs()
void clearLCDs()
clearLCDs - Function to Clear LCDs and side Liquid Crystal Light Shutters
    // Clear Right Front LCD
    DOG.clear();
    // Clear Right Side Shutter
    digitalWrite(rightsideCS,LOW);    // Disable right side shutter
    // Clear Left Front LCD
    DOG.clear();
    digitalWrite(leftsideCS,LOW);    // Disable right side shutter
// End of function clearLCDs()
void setup()
//  The next two lines force the Feather to be connected to a computer and the serial
//  terminal activated.  Comment them after debugging so that board can work independently
//  while (!Serial);  // Wait for serial terminal in Arduino IDE to be opened
//  delay(500);
  Serial.begin(115200);
  Serial.println(F("Goggles are Controlled by Adafruit Bluefruit App Controller"));
  Serial.println(F("-----------------------------------------------------------"));
  /* Initialize the Bluefruit LE module */
  Serial.print(F("Initializing the Bluefruit LE module: "));
  if ( !ble.begin(VERBOSE_MODE) )
    error(F("Couldn't find Bluefruit, make sure it's in CoMmanD mode & check wiring?"));
  Serial.println( F("OK!") );
  if ( FACTORYRESET_ENABLE )
    /* Perform a factory reset to make sure everything is in a known state */
   Serial.println(F("Performing a factory reset: "));
   if ( ! ble.factoryReset() ){
      error(F("Couldn't factory reset"));
  /* Disable command echo from Bluefruit */
  ble.echo(false);
  Serial.println("Requesting Bluefruit info:");
  /* Print Bluefruit information */
  ble.info();
  Serial.println(F("Please use Adafruit Bluefruit LE app to connect in Controller mode"));
  Serial.println(F("Then activate/use the game controller"));
  Serial.println();
  ble.verbose(false);  // debug info is a little annoying after this point!
  /* Wait for BLE connection */
  while (! ble.isConnected()) {
      delay(500);
  Serial.println(F("******************************"));
  // LED Activity command is only supported from 0.6.6
  if ( ble.isVersionAtLeast(MINIMUM_FIRMWARE_VERSION) )
    // Change Mode LED Activity
    Serial.println(F("Change LED activity to " MODE_LED_BEHAVIOUR));
    ble.sendCommandCheckOK("AT+HWModeLED=" MODE_LED_BEHAVIOUR);
  // Set Bluefruit to DATA mode
  Serial.println( F("Switching to DATA mode!") );
  ble.setMode(BLUEFRUIT_MODE_DATA);
  //  DOG.initialize using hardware SPI:  CS , 0 , 0= use Hardware SPI, 9 = A0, 5 = RESET, DOGM128-6 (=128x64 dots)
  DOG.initialize(rightfrontCS,0,0,9,5,DOGM128);
  DOG.initialize(leftfrontCS,0,0,9,5,DOGM128);
  // Initialize power pin for plethysmography sensor
  pinMode(plethPower,OUTPUT);
  // Initialize DACs - Adafruit MCP4725A1 address is 0x62 (default) or 0x63 (ADDR pin tied to VCC)
  dac.begin(0x62);
  dac.begin(0x63);
  // Initialize liquid crystal shutter AC drivers
  pinMode(rightsideCS,OUTPUT);
  pinMode(leftsideCS,OUTPUT);
// End of setup()
//main loop
void loop()
  // Poll for new BLE data
  uint8_t len = readPacket(&ble, BLE_READPACKET_TIMEOUT);
  if (len != 0)
    change=true;  // if a button was pressed, then set GUI change flag
  // Read which one of the GUI buttons was pressed
  if (packetbuffer[1] == 'B')
    uint8_t buttnum = packetbuffer[2] - '0';
    Serial.print ("Button "); Serial.print(buttnum);
    button=(int)buttnum;
    // Decode the meaning of the button and update settings
    if (button == 1)
        mode=1;
        digitalWrite(plethPower,LOW);    // Turn off power to plethysmography sensor
    if (button == 2)
        mode=2;
        digitalWrite(plethPower,HIGH);    // Turn on power to plethysmography sensor
    if (button == 3)
        mode=3;
    if (button == 8) { rightSpan=rightSpan+4; }
    if (button == 7) { rightSpan=rightSpan-4; }
    if (rightSpan <0){ rightSpan=0; }  // Don't let rightSpan go below 0
    if (rightSpan>255){ rightSpan=255; } // Don't let rightSpan go above 255
    if (button == 6) { leftSpan=leftSpan+4;}
    if (button == 5) { leftSpan=leftSpan-4;}
    if (leftSpan <0) { leftSpan=0; }  // Don't let leftSpan go below 0
    if (leftSpan>255){ leftSpan=255;} // Don't let rightSpan go above 255
    // Calculate start and end of occlusion for right-eye LCD
    windowLCD(rightSpan);
    rightfrontStart=frontStart;
    rightfrontEnd=frontEnd;
    rightsideEnable=sideEnable;
    // Calculate start and end of occlusion for right-eye LCDs
    windowLCD(leftSpan);
    leftfrontStart=frontStart;
    leftfrontEnd=frontEnd;
    leftsideEnable=sideEnable;
  // Read UI potentiometers
  pot1Value=analogRead(pot1Pin);  // 10 bit A/D so value is between 0 and 1024
  rightfrontContrast = pot1Value/16;  // Contrast (0...63)
  rightsideContrast = pot1Value/16;  // Contrast (0...63)
  leftfrontContrast = pot1Value/16;  // Contrast (0...63)
  leftsideContrast = pot1Value/16;  // Contrast (0...63)
  //pot2Value=analogRead(pot2Pin);  // 10 bit A/D so value is between 0 and 1024
  // rightSpan=pot2Value/4;  //Span is two displays wide, so "curtain" is 128 wide and full window is 256 wide (0...255)
  //pot3Value=analogRead(pot3Pin);  // 10 bit A/D so value is between 0 and 1024
  //leftSpan=pot3Value/4;  //Span is two displays wide, so "curtain" is 128 wide and full window is 256 wide (0...255)
  pot4Value=analogRead(pot4Pin);  // 10 bit A/D so value is between 0 and 1024
  baroreceptor=pot4Value/4; //Duration of occlusion after detection of baroreceptor activation (0..255 ms)
  if (mode == 1)
  // Mode 1 is simple occlusion based on User Interface settings
   // If there were any GUI changes, then update displays
   if (change==true)  // Update LCDs if there were changes in UI
     // Now update the LCDs
     updateLCDs(rightfrontStart, rightfrontEnd, rightfrontContrast, rightsideEnable, rightsideContrast, leftfrontStart, leftfrontEnd, leftfrontContrast, leftsideEnable, leftfrontContrast);
     change=false;  // Reset GUI change flag
  // End of Mode 1
 if (mode == 2)
    // Mode 2 is occlusion that is synchronized to baroreceptor activation
    // Read plethysmography sensor
    plethValue=analogRead(plethPin);  // 10 bit A/D so value is between 0 and 1023
    //Serial.println(plethValue);       // Send the Signal value to Serial Plotter
    if(plethValue > plethThreshold)
     {  // If the signal is above plethThreshold, then occlude vision
        // Now update the LCDs to occlude
        delay(baroreceptor); // Maintain occlusion while baroreceptors are activated by diastolic pressure wave
        clearLCDs();  // Clear LCDs once the baroreceptors are no longer active
        delay(300-baroreceptor);       //  Start a refractory period which ends ~300 ms after trigger
  // End of Mode 2
if (mode == 3)
  // Mode 3 is for automatic sunglasses
   if (change==true)  // Run once when entering mode 3
     rightfrontStart=0;
     rightfrontEnd=127;
     rightfrontContrast=63;
     leftfrontStart=0;
     leftfrontEnd=127;
     leftfrontContrast=63;
     rightsideEnable=1;
     rightsideContrast=63;
     leftsideEnable=1;
     updateLCDs(rightfrontStart, rightfrontEnd, rightfrontContrast, rightsideEnable, rightsideContrast, leftfrontStart, leftfrontEnd, leftfrontContrast, leftsideEnable, leftsideContrast);
    lightValue=analogRead(lightPin);  // 10 bit A/D so value is between 0 and 1024
    rightfrontContrast = lightValue/16;  // Contrast (0...63)
    leftfrontContrast = lightValue/16;  // Contrast (0...63)
    rightsideContrast = lightValue*4;  // Contrast (0...63)
    leftsideContrast = lightValue*4;  // Contrast (0...63)
    dac.begin(0x62);
    dac.setVoltage(leftsideContrast, false);
    dac.begin(0x63);
    dac.setVoltage(rightsideContrast, false);
  // End of Mode 3
// End of main loop()
